Question about GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not freezing
My sideby side is not working properly. The refrigerator side is warm but rhe freezer side is frozen just the back wall the food and ice is thawed. I took the back cover off to make sure that the fan was blowing was but the condensor is frozen solid.Can you please offer a solution
  • 93 Answers
The evaporater is located in the freezer section of unit.Defrost thermostat is cliped on the top of it. This is no doubt the culprit. You will need to check continuity on defrost heater and replace themostat.
Posted on Jul 17, 2008
How dd the freezer get cold all parts
Most problems with lack of freezing in part of the freezer is a matter of overloading the freezer. Things get frozen in the freezer by the circulation of air. If the air gets blocked the food will not freeze, same thing occurs in the fresh foods section, if the air from the freezer is blocked to or from the freezer the fresh food side will not cool properly. Make sure in the freezer there is a path down the back of the freezer and up the front for air to circulate to and from the evaporator coils in the back.
Hope this helps
Feb 15, 2015 | Panasonic NRB30FX1XB Bottom Freezer...
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
to solve the frozen food problem, turn the temp back to 4. this should be the factory recomended setting. the only dispensing crush ice is probably a bad solinoid. you will find this behind the back wall. it engages to lift the thin metal rod on the bottom of the ice bucket to dispense cubed ice. and the ice being frozen in the bucket is probably a bad ice flapper in the door. it's letting warm moist air into the ice bucket that is freezing
Apr 23, 2010 | GE GSH25JFR Side by Side Refrigerator
Freezer and fridge not cooling (halfway)
SxS Amana upper half of feezer and Refrigerator not working
Jun 22, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Freezer not freezing properly, ice on back wall
Ice on the back wall indicates a problem with the defrost cycle. The ice builds up and starts to choke off the air flow, so your symptoms would indicate that may be happening.
Defrost problems are usually any of the three components, the heater element, the defrost termination temp switch, or the defrost timer.
May 29, 2009 | Amana ABB1927DE Bottom Freezer...
Kitchenaid side by side too cold. Freezes everything.
the damper motor on the refrigerator portion is not working properly
Apr 04, 2009 | KitchenAid Superba Architect KSCS25IN Side...
Ge SIde by side SSS25KFMDWW stopped freezing
number one,is the freezer fan working?2,is there frost forming on the back wall of freezer?let me know more-mike
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer works but fresh food seems warm
If you have frost on the back wall of the freezer compartment you have a defrost problem. When the freezer coil does not defrost the refrigerator does not get air for cooling.
May 22, 2008 | Frigidaire Refrigerators
Refrigerator won't get cold
You likely have a defrost cycle failure. The freezer's cooling coils need to be frosty and cold so the air that the fan pulls over them can cool the fridge section. If the defrost cycle fails, the coils freeze up to a block of ice and air flow suffers (fridge is about 55 degrees F). The freezer stays cold only because there's a block of ice in there now... sometimes that cold "sinks" to the bottom and only the food at the bottom stays frozen (and can even freeze food at the bottom of the fridge compartment while the rest is warm). To be sure, you'll need to take the rear interior panel off the freezer back wall and check the coils to see if they are frozen solid. If they are then there's a defrost cycle failure. If they are showing a nice white frosty pattern evenly all over the coils then that's normal and maybe the evap fan (right above the coils) is not blowing air up properly or is not working at all. That fan should run if the compressor is running, etc. the only time it doesn't run is during an actual defrost cycle. Once you find out what condition the coils are in it should be simple to direct you further on the problem.
Jan 05, 2007 | Maytag 22.6 cu. ft. Side-By-Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
94 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
