I HAVE HP 3210 All-in-one, i am trying to instyall to new computer. Problem registry key does not exist and is required for installation
Called HP and they said I needed a Vista cd for new computer because the old one was for XP
Posted on Jul 17, 2008
Cant get it to install
uninstall the existing printer drivers first before you try a reinstall.
Mar 16, 2017 | HP Photosmart 2575 All-In-One InkJet...
Had to install a new harddrive on my HP computer, while installing the HP J4580 software I had a power failure.....rebooted and uninstalled (using the control panel uninstall) the J4580 software. NOW when...
it's sure that the hp j4580 entries are still existing in the computer if the installation was done with the cd-rom then please do the following steps: insert the cd-rom into the computer do not auto-run the cd go to the hp cd icon in my computer right click on cd icon then click on open then look for folder named util under util right click and open folder ccc then under ccc you will look for a file l3 uninstall or uninstall.l3 right click on it and click on open then disconnect the usb cable from the printer(in case it is a wired installation) go on selecting the files that the uninstaller will show then do not restart then go to the control panel go to add or remove programs remove the hp softwares if exists(hp j4580 required software,hp solution centre,hp imaging device,hp customer participation program,shop for hp supplies,etc.. ) then go the start icon go to the run option enter "regedit" then registry opens up click on h-key local machine select software then select hp printer entires that are highlighted then delete them from the registry restart the computer then download the fresh version of j4580 from hp.com then install the software the issue will be resolved for a software download install: go to the folder where the downloaded version is saved then right click on the software and click on `run then close the folder then go the temp folder by writing the command in the run box %temp% then look for a folder that starts with the name"7z........." open that folder then look for util folder then the steps mentioned above will be done please try this and the issue will be resolved if the issue remains unresolved please revert back
Dec 22, 2010 | HP OfficeJet J4580 All-In-One Laser...
Error message: During software installation I receive this error message: "this registry key does not exist and is required for installation to continue"
what are you trying to install ? i guess the software is asking for right Serial or key that would have come when you purchased the software. the one you are entering seems incorrect or else post detailed error
Aug 07, 2009 | HP Scanjet 4370
Need registry key to to install printer
Assuming you are running Windows XP, you may be able to repair this issue if you "restore" your computer to an earlier date.
This is a process by which Windows remembers a time when your computer functioned properly, and sets your computer to those settings. Most of the registry problems can be fixed in this manner.
To access Restore feature, click Start and find Programs, then Accessories, then System Tools, then System Restore.
A window should open that asks if you would like to create a restore point, or restore your computer to an earlier date. Choose this later option.
The next screen should show you a calendar. The dates which are bold are dates that you can choose to restore your computer.
You may not fix the problem on the first try; so choose the most recent bold date, and restore. If the printer still will not install, repeat the process with the next older date.
Unfortunately, if this process does not allow you to repair your computer's software, a reinstallation of the operating system may be required.
Good luck....tony
May 17, 2009 | Office Equipment & Supplies
Instal problame
Try downloading the software and installing it. Make sure that you download for the version of windows that you have.
http://h10025.www1.hp.com/ewfrf/wc/product?product=441115&lc=en&cc=us&dlc=en&submit.y=6&submit.x=2〈=en&cc=us
Dec 30, 2008 | HP PSC1410 Printer
Lost my installation CD and downloaded the software from HP but doesn't work
ok..
remove the old software first
then get another fresh set of drivers, make certain that your operating system has the latest service pack installed.
re install the drivers
try it again
Jun 24, 2008 | HP DeskJet 3940 InkJet Photo Printer
Registry keys
A registry is a very intricate set of software instructions. A cheap registry cleaner can do more harm than good believe me, I have seen registries destroyed by cheap junk! Stay away from free registry cleaners! Try this registry scanner and please let me know if it solved your problem...
Oct 25, 2007 | HP PSC 1610 All-In-One InkJet Printer
Trouble installing HP officejet 5610 all-in-one
slbcsp.dll - this registry does not exist
sccbase.dll - this registry does not exist
gpkcsp.dll - this registry does not exist
Enum - installer can not access
Oct 22, 2007 | HP Officejet 5610 All-In-One InkJet...
Photosmart Essential Lockup
Hey guy don't follow thier suggestion. No one can't do anything for u r problem because Your H.P. inkjet Printer 3210 doesn't work with Vista. I am also faced same problem. It is technical problem. Just change your vista or Printer
Jul 02, 2007 | HP Photosmart 3210 All-In-One InkJet...
5150 installation problems
Does the message specify any particular dll? If you could copy the dll?s exact name and repost this question it might help the community in finding you a better fix. The best I can do considering the situation is refer you to the HP site, to a page there where you can download the relevant drivers: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=304431&lc=en&cc=us&dlc=en&submit.y=9&submit.x=11&lang=en&cc=us download the driver that fits your operating system and follow the instructions. Usually installation doesn?t require much computer savvy, just repeatedly pressing the ok button. Offcourse if you still have the original installation CD that you got with the printer then check to see if the driver is already there. Good luck
Feb 21, 2006 | HP DeskJet 5150 InkJet Printer
23 people viewed this question
jasbo
jasbo
