Question about byD sign 3032 30 in. HD-Ready LCD Television
Peascorn I need a power adapter for my byDsign 3032 30 in TV..can I by pass the power adapte at all..???
  • HollyDolly25
    HollyDolly25 Aug 21, 2008
    I need a power adapter for my byD sign 3032!!!!! Damn moving company lost my cord!!! HELP!!!
  • 3 Answers
I have a New OEM power supply for a byDesign 3032 TV.
If interested, please email me your contact info.
Thanks,
Art
Posted on Mar 19, 2009
How do I connect roku 2xs to sony trinitron tv
If your Tv does not have the HDMI port you can use the RCA cables. If your Tv does not have the RCA video/audio ports you will need an adapter from Radio Shack for hooking up a video camera to a cable Tv. This adapter will allow you to hook the Roku to the adapter with the RCA cables, then the adapter hooks to the Tv with a cable just like a cable box. This adapter is also a pass through for other devices like a cable box and or another DVD player. Hope this helps FixYa up.
Aug 07, 2011 | Sony FD Trinitron WEGA KV-24FS120 24" TV
My tv Adapter is not working and i need another one . this what is at back of the ADAPTER AC ADAPTER SN 0530+___O___- MODEL ;AD0603S110/220-12 INPUT:100-240V~1.5A. 50-60HZ .OUTPUT:12VDC= 5A THAT...
The important information is the output voltage (12 volts DC) and current (5 amps). You need an adapter with those ratings and a plug with the proper size and polarity to fit the TV. If necessary, you can salvage the output cord from the bad adapter and splice it onto a replacement if you can't find one with the right plug. You need to be careful to get the polarity right or you can damage the TV. Most sets have the center pin positive, but you want to check to be sure. The set usually is marked with the information, and it may also be on the old adapter.
You may be able to find an exact replacement adapter by searching for your specific TV brand and model number and "replacement power adapter". Many adapters are available through eBay sellers. Otherwise just look for a 12-volt 5-amp adapter and change the output cord as described if necessary.
Good luck and thanks for using Fixya!
May 16, 2011 | Goodmans 289NS 14" TV
Hi my tv adapter keeps making sparking sounds and is given off a smokey smell. Will not allow my kids to turn it on. We only got it at Xmas
It can be deduced from your problem that the fuse located inside the adapter is burnt out,This occurs as a result of excess voltage which is passed into the adapter,the fuse in the adapter tends to protect excess voltage from going directly into the TV unit,
Hence,when excess voltage gets into the adapter,the fuses burns out and voltage cannot flow into the TV UNIT,
The solution is to take apart the adaptor and replace the cylindrical fuse which is burnt out,or as a better alternative,replace the adapter in order to obtain optimum performance in terms of protection of your TV unit.
Thanks and take care.
Jul 03, 2010 | Televison & Video
Adapter not electricity is not passing through adapter. Electricity flows through plug until the adapter is attached and then not connection to the printer....1240.... Part # 21T0615
Make sure you are plugging the power cord straight to the power outlet in the wall, bypass any surge device or power strip as it may cause power loss. If you have already tried this but still no difference, I suggest you contact Lexmark Technical Support to request for the power adapter. They can send you one for free. Thanks.
Jul 02, 2010 | Lexmark X1240 All-In-One InkJet Printer
I need an AC 12v-5v powr adapter for a PROSCAN TV.
USE a simple laptop adapter thats whhat i did just tell the guy at local comp store 12 volts and 5 amps they should have 1 or able to order it also try a used comp store they abound on craigs list and kijiji canada
Oct 22, 2009 | Proscan 19LA20Q LCD TV
We need a ACPower Adapter# for Protron PLTV-32 LU32A143 LCD TV(not EBay)
If I where you, I would just go to hardware store and get multi-adapter for $10 and make your own
May 20, 2009 | Protron PLTV3250 32 in. LCD Television
Power Adapter
I NEED a new power adapter ttttttttttoo.. can you HELP please,, I allready had a so called TV repaire Man try to fix it he said he cant get a new power adapter for it to be fixed .... I stupidly PAYED him waited 9 months later, and still no TV fixed..Im taking him to smalls claimes court.....Very un happy persone ,I just want a new power adapter,....please some one out there...peascorn...I have d:sign TV 3032- ad-13d-2...
May 25, 2008 | byD sign 3032 30 in. HD-Ready LCD...
Trying to find a power adapter for a bydsign d4032 40" LCD-TV the model # on the part is AD-12C-1. I tried Bydsign's website and all phones have been disconnected. We have a lot of these LCD panels and...
Thank you for the info.
That adapter may not be easy to find with all those specs. It looks like these adapters are only customized to use on this brand of TVs.
My suggestion will be to try to fix them to the component level or if you can find a tech to do it for you.
Good Luck.
Call this guys:
bydsign worldwide
105 SE Executive Dr.
Suite 11
Bentonville, AR, 72712
United States
479-845-0680
Customer Service:
800-770-3771
Mar 14, 2008 | byD sign d:2232 22 in. HD-Ready LCD...
Picture problems
check the inside of the PS2 or make sure the TV is ok or call sony up and use your warranty you should be able to
Jan 31, 2008 | Sony PlayStation 2 (PS2) Console
byD sign 3032 30 in. HD-Ready LCD Television Logo
162 people viewed this question
Top byD sign Televison & Video Experts
Jaime Hernandez
Elise Lacoursiere
Elise Lacoursiere
Are you a byD sign Televison and Video Expert? Answer questions, earn points and help others
