I have a 2001 town & Country my power window does not funtion all the time. it seems when its hot out the window goes down but not all the wat back up. when i stop for a while i shut the car off and start the car back up then I can close the window.what do I do?
    Problem Solver:
  • 63 Answers
Not PC related
Posted on Jul 17, 2008
My wipers...lights..radio and horn went out but I can drive the car..what would cause this?
2008 Chrysler Town & Country Intermittent Electrical Failure ...
www.carcomplaints.com/Chrysler/Town_Country/.../intermittent_electric...
The 2008 Chrysler Town & Country has 25 complaints for intermittent ... The horn,lights, wind shield wipers front and back going crazy could not shut off. .... I was Driving down the road and my van went crazy possessed! ... Electrical checks reveal nothing wrong with the electrical system, and there is power to the radio.
2003 Dodge Caravan ES Electrical Problem - Discussion on Topix
www.topix.com > Dodge Grand Caravan
Aug 7, 2011 - my van was running fine, shut it off, went in for half an hour then it would not ... or the electric doors. windows do and brake lights. heater stays on hot and i can only ... My horn wipers,power windows, radio,blower front and back, headlights, do not work. ... Chrysler Readies Next-Generation Town & Country.Missing: 2004
Thread: I lost almost all of my dash lights, instruments, and ...
forum.chryslerminivan.net/.../7261-I-lost-almost-all-of-my-dash-lights-i...
Jan 17, 2008 - 10 posts - ‎6 authors
I have a 2003 Town and Country mini-van and I lost power to all my ... In addition to this my wipers, headlight controls, blinker controls, power door locks, and A/C/heat controls are out as well. The odd thing is that the power windows work, the power sideview mirrors work, the radio and ceiling lights also work.
Dec 16, 2015 | 2004 Chrysler Town and Country
2001 Chrysler Town & Country getting 9.6 mpg
yes you need a new thermostat or there is low coolant. this will affect the mpg because your overheating and thats why its stalling. dont drive until you fix or you will blow your head gasket if it isnt blown already. change thermostate and check coolant.
Mar 09, 2013 | 2001 Chrysler Town & Country
Heat not blowing hot air and car temp gauge goes high
the way to check the thermostat is with the motor hot feel the upper radiator hose to see if can squeeze it. you should be able to squeeze it. the water pumps is big problem to
Jan 26, 2013 | Chrysler Cars & Trucks
2002 Chrysler town and country power window issue
take the window down all the way and spray soapy water in the window sealing tracks if it goes up easy thats where the binding is. some times with age the rubber comes loose and will cause a bind. peeling window tint sheeting will cause this as well,worst case mechincal problems in regulator or drive motor
Aug 26, 2012 | 2002 Chrysler Town & Country
Gas smell 2001 town and country
My 2001 Town & Country only has gas fumes when it is first started for the day. Then goes away after running for awhile.
May 15, 2010 | 2001 Chrysler Town & Country
2001 Chrysler Town and Country Window problem.
it could possably be the motors for the windows are bad
Aug 02, 2009 | 2001 Chrysler Town & Country
2001 Town & Country power window does not cme up
You will need to replace the motor/regulator assembly. Your local parts store should carry them or order online. These should be in stock as this is a common problem. Removing the motor bolts will be a pain since they have a rubberized nut hold them in the rear. Try a vise grip on them or if all else fails pull on the motor and pop them out. The replacement assembly uses normal nuts. Pay close attention on how the old assembly bolts up (take a picture before you remove it) since you will have to move the assembly to wrestle it out of the door. Reinstall assembly and check operation before you put door panel back on.
Aug 01, 2009 | 2001 Chrysler Town & Country
Describe your 2001 Chrysler Town &
Shouldn't set off air bag if you are taking off door panel. You could always disconnect negative battery cable to be extra careful. I have replaced both passenger and drivers windows with battery connected. Take your time in removing door panel so avoid breaking plastic retaining clips.
One nasty part of this job is removing bolts that hold window motor to the door. They have a rubberized nut on the backside. Sometimes you can hold them with vise grips. I've found if I just pull the motor really hard the bolt and nut slides out of rubber guide.
It is also a little tricky to remove the unit and reinstall it in the door. Just be patient and take your time.
One tip is to leave the door panel off after you install the new door motor/regulator unit. Simply plug in the window switch and make sure all is functioning correctly and then install door panel.
I buy the replacement window units online and save big bucks over the dealer.
Jul 18, 2009 | 2001 Chrysler Town & Country
Describe your 2005 Chrysler Town & Country electric windows.
window cable is breaking. replace window motor and cable assembly.
Jul 12, 2009 | 2002 Chrysler Town & Country
Computers & Internet Logo
David Payne
David Payne
