Question about Goodman Heating & Cooling
When i turn my a/c (goodman) to auto and to cool, nothing is working.and when you go outside by condenser unit and manually push the relay in it trips the circuit breaker. is there any short somewhere or am i not supposed to do that. also i found a blue wire thats connected to the relay had been caught between the covers that have chafe through. is this wire for a thermostat and had cause something not to work. these wires are connected to a small red & white wire. any info would helpful. thanks
  • 41 Answers
First stop pushing the contactor in if it tripped the breaker than you have a short and it need to be checked out the small wires are the t-stat wires could have shorted the control tranformer have the system looked at by your hvac people dan
Posted on Jul 19, 2008
Why my goodman gsx 16 isn't working.
Ensure the compressor is running. It has a large capacitor connected to it that helps the motor to start. They go bad. There is a relay controlled by the thermostat that starts the compressor. It could be as simple as replacing the relay. Now the breaker. There are 2 of them side by side with their handles joined so when one trips so will the other. That isn't always how it works, though. Reset the breaker several times to be sure. There are fuses inside the power disconnect box on the outside of the unit. If one is blown, the compressor won't run
May 10, 2017 | Goodman Heating & Cooling
My air conditioner froze up. We turned it off over night and cleaned the evaporator and condenser now it doesn't cool at all.
is the outside unit running? may have got something wet have someone turn it to cool while your at outside unit see if it's starting up. one line should be warm the other cool.
Jun 18, 2014 | Goodman Heating & Cooling
My breaker trips when the outside unit tries to turn on. The inside furnace runs. I cut the inside unit off and the breaker doesn't trip. I manually turn on the outside unit by depressing the cont
Hello, there is a short to ground somewhere, check all the wiring from the inside un it to the outside unit and make sure nothing is touching metal.
Jun 10, 2012 | Goodman Heating & Cooling
One of the goodman condensing unit for my house starts good every thing works fine, but it runs OK for couple of hours and by then the refrigerant line connecting the unit condenses and it will not blow...
The refrigerant line is actually supposed to condensate, but if you mean "freeze up", thats a problem. The condensation occurs because the line temp is lower than the outside temp, kinda like a soda can outside. From what you described, Im pretty sure you are either over or under charged on refrigerant. The reason it will not come back on for a couple of hours is because the compressor is in "protection" mode and has to cool down before coming back on. When you are low or high on refrigerant, the compressor has to work harder which over heats and trips the internal overload switch. Have the unit charged properly and you shouldn't have a problem.
Jun 13, 2010 | Goodman CKL60AR60 Air Conditioner
My air conditioner doen't start. I have a goodman air cond.
Check to make sure that the power is on to the outdoor unit and the furnce. Check breakers and fuses. There may also be a disconnect outside located by the condenser. It is probably a gray box, loft the cover and make sure the shitch is on. Otherwise if you turn the thermostat to cool, if the furnace blower comes on and the outdoor unit does not check the following. Turn off poer to outdoor condenser and open up the electrical compartment on the condensing unit outside. There is a round or oval cylinder inside. Its probably silver in color. That is the capacitor. If the top is bulged, its a true sign of a capacitor failure. Take the capacitor out and take it to your local HVAC Wholesaler of contractor. The part should cost you around 15 to 25 dollars. If this does not work, let me know.
Jun 04, 2010 | Goodman CLQ36AR49 Air Conditioner
Oustide unit fan won't work
It sure sounds like the out side condenser fan has gone out.If you need to Fix a water hose to run on it like a spray fanning out over the out side coils(condenser)and try and see if it will cool.It will do the trick,until you get it fixed on week days.If I can help,let me know.>>>roniecon@gmail.com
Aug 16, 2009 | Goodman CLQ36AR49 Air Conditioner
Home AC Compressor starts asynchronously with cooling fan
Check outside unit capacitor and the contactor.. I work on Goodman unit sounds like a cap or contactor
Jun 07, 2009 | Goodman CKL24AR24 Air Conditioner
Goodman A/c not working. cannot find manual. landlord away
Try replacing the batteries first. The blinking may be the battery indicator.
The fact that it blows air when you turn the thermostat to cool tells me that the thermostat is probably working. The problem is most likely outside at the condensing unit. There are lots of potential problems that could be found out there. Sounds like you will need a technician.
Jun 25, 2008 | Goodman CLQ36AR49 Air Conditioner
Blower fan keeps shutting on/off,
Your blower fan turning on and off shows your thermostat is working. I am willing to bet you have the fan in the automatic condition. Check for a sticking contactor at the outside unit.
May 31, 2008 | Heating & Cooling
Heating & Cooling Logo
50 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
