TV sensor so... Do I need to replace the senor to switch it back and forth from Video Input? If so, yes I would like to know how to replace it. Thanks
  • 790 Answers
Yes... the sensor is located at the front panel of the TV, but before you get the sensor need to open first the back cover of your unit... after you open the unit please take a picture and upload here to see where is sensor located... the sensor is located in inside of the front panel!
Thanks!
Posted on Jul 19, 2008
Will the crankshaft senor stop the car from starting
Yes, a bad sensor will do that. Reason is, the computer needs the crank sensor information to compute spark timing. With no sensor input, the computer will not cause spark to occur.
Oct 06, 2013 | 1993 Pontiac Bonneville
My son's car 1996 BMW 740il did notm pass the smog test code was senor Fault p0136 Bank 1 senor 2 I want to know how much this will cost to get done. thanks
Thanks for choosing FixYa and welcome. You need to change the 02 sensor. This is the sensor in the back. It is called a oxygen sensor. It is located on the exhaust system.
Apr 28, 2011 | BMW 750 Cars & Trucks
I have a D-VR7KC2 DVD VIDEO RECORDER. Is there any way to hook it up, so that I can record a channel, while watching another channel? I have a digital cable box. I don't mind only being able to record non...
The short answer is "yes", but it really depends on your TV having more than one input.
You would put a cable splitter (see Google images) on the wire that comes out of the wall. One of the OUT connections would be to the cable box, and the other would go directly to your Toshiba unit.
Depending on the outputs of your cable box, and the inputs of your TV, each unit would be connected to a TV input either by cable or video connections. You would then switch back and forth between the input from the cable box - when you wanted to watch live, digital TV - or the Toshiba when you wanted to set up/watch recordings.
Mar 14, 2011 | Toshiba D-VR4 DVD Recorder/VCR
Bought a Soney KDL-46EX500 last week. Still tring to get it set up. Got the digital local stations programed into it today. (finally) Now I can not figure out how to switch back and forth from locals...
Looking at a diagram of the back of your TV I see that you have only one Coax input. You will need to plug either your antenna or the DirecTV in one of the other sources available on the back of the TV.
According to DirecTV's website, their box also uses composite video cables and depending on the age of that box, may have an HDMI connection also.
Looking at the back of your TV, the composite video cable input is the top two rows to the right of the Coax input you are currently using.
Once you have both connected to different inputs, you can use your remote to switch between the sources and watch whichever you like.
May 03, 2017 | Sony Televison & Video
Can not get my speed sensor out. Any tricks I got it to turn back and forth maybe a eight th of a turn thats it.
you can only get the hold down bolt to turn 1/8 turn or senor it self if bolt try using some pentrating oil on it
if you have bolt out and are tring to get senor it self out keep turning it back and forth while pulling up they have a o- ring on them and tend to stick in place
if u can try to pry up GENTLY with screw driver but be careful if u pry to hard they will break
Apr 16, 2010 | 2000 Ford Focus
No remote and cannot change to video mode!
Go to radio shack and get an universal remote control that has a tv/vcr input button. the one i got is a Phillips Universal to switch channels myself.
Sep 13, 2008 | Symphonic ST420FF 20" TV
Need to Switch input on TV with out Remote
Hi
ok the The TV sensor is bad... you want to replace it? if you want i can teach you how to fix this without labor cost for the technician...
thanks!
Jul 16, 2008 | Televison & Video
Back channel turn off and on
Same problem with the 2.1 channel DRA-297. All sound cuts off and screen reads h/p input. I don't even know what that means. What's wrong here?
When it happens, the receiver makes a clicking noise. it goes back and forth from being on to h/p input shutdown. sounds like someone repeatedly flicking a lightswitch.
Thanks to whoever can help!
Jan 28, 2008 | Denon AVR-1700 Receiver
Panasonic tv 27"
I not familiar with this model but, If the video select button is below the screen. I would suspect "windex damage"! Cleaning screen by spraying directly on crt causes this is some sets. The button gets corroded or part of this circuit. If this is the case, replace/ inspect/clean around switches.
Protection diode(s),capacitor across switch, faulty switch or bad processor input are other causes.
Oct 26, 2007 | Sanyo DS27800 27" TV
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
