my router its workin but the light WLAN is off i need instructions step by step to see how can i fixed . cause still dont have signal to my ipod touch .i went to 192.168.0.1 to see if can do something but is dificult to me . please help me! and thaks!
my modem is my router, turned it off for 60 secs and still no luck... whats the diff?my modem is my router, turned it off for 60 secs and still no luck... whats the diff?
You can't post conmments that contain an email address.
Yes there is.. BUT you'll have to set up the security again... Fortunately DLink has a handy setup wizard which you can access here.. http://support.dlink.com/emulators/di514_revc/h_wizard.html
This will work right on your browser. You might want to test that it works on your system before wiping the router. (Just start it up then cancel if it starts)
Find the recessed reset button on back of the router close to the power input. Press and hold it with paper clip or pen tip for 10 - 15 seconds. This will restore it to factory settings.
You should use a wired connection to access the internet after that, no password. Go to the link above and use the online wizard to setup the router with encrytion and new password.
If it all orks wout for you kindly give me a rating. Thanks.
Seems from the manual to be, that there is a problem with the power adaptor. Haven't yet managed to find out if it's the router or the power adaptor that's the problematic part.
But do you have another adaptor with the same specs, you can try using that.
Make sure that your computer is able to go online through the modem. If your computer is not able to go online through the modem then you will need to call ISP first. If your computer is able to go online through the modem then you need to connect the computer to the router and the modem to the router. open the set up page of the router and change the settings of the router according to the ISP. Click Here for step by step by instructions
Only thing that can cause your wlan light not working consistantly or with some blinks (which is normal thing) is bad lan cable which leads from your ADSL modem to your wlan entrance on your wireless router, please check that cable in order to fix that problem. Cable doesnt need to be coaxial so it can have 2 different lan sets (2 poles of exits male and female exit). Thats it ! =)
Security Code is configued in Wireless Router itself.
Please open your Wireless router Admin Panel in Internet Explorer. Please follow this steps.
1. Open Internet Explorer and type : http://192.168.x.x and press enter (x is router IP. Generally its 1.1 or 0.1)
2. Go to Wireless Security Tab and look there for Security code.
Now type that Security code in your Ps3 .
You find all details regarding to access router in internet explorer from Product Manual. (you can download product manual from Manufacturer site)
What is the Operating system on the laptop ? If it is XP then in the bottom right hand corner you will find Wireless network connection ( looks like 1 computer monitor). Use that icon to connect to the wireless network. If it is windows Vista, then in the bottom right hand corner you will find 2 computer monitor icon. Use that icon to connect to the wireless network. If it is Windows 98/ME/2000 then use the adapter utility to connect to the wireless network. For MAC you will see the AIRPORT icon at the top.
Check the wireless settings of the router first . Make sure that you have all the wireless settings of the router. If you are not sure about the settings, then open the router set up and check the settings. Click Here for step by step instructions on how to connect to the wireless network and troubleshooting steps
Log into the router's setup page 192.168.0.1
Type in the password, the default password is admin.
Go to wireless Security and you will see your key there.
You can reset the router to default and set a new password and encryption key. D-Link Router reset Step 1 Locate the reset pinhole on the back of the unit. Step 2 With the unit powered on, press and hold the Reset button. Step 3 Hold the Reset button for about 10 seconds. Step 4 Release the Reset button. Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting. Step 6 The device is now at factory defaults. Note: Do not recycle power during the reset procedure. The default user name for most D-Link devices is admin and the password is left blank. When it says hold for about 10 seconds, don't hold for more than ten seconds or the procedure will likely fail, if ten seconds doesn't work try 5 seconds. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
Orange WLAN light means no connectivity to the network. Try to reconnect to your wireless network and make sure to enter the correct wireless settings like the network key and SSID.
