Question about Hitachi VT-RM391A Remote Control
Buttons stopped working
My remote has worked fine with my Hitachi CT7970B/K TV, but suddenly last week the buttons on the control stopped working except for volume. This means I have to turn the TV on and off manually and manually press the control under the screen to go up a channel. For example, to go from NBC to Turner Classic Movies means pressing that control 82 times to get from 4 to 86!
I've called Hitachi and they don't know what's happened. I even got another remote, but it was the same pattern -- only the volume remote toggle elicits a response.
We suspect we pressed a "wrong" button or did something wrong that incapacitated the remote keypad and channel up-down toggle. Can you help?
Donald Light
dlight@princeton.edu
    Brigadier General:
  • 6,966 Answers
Your concern to my understanding is the TV unit will not respond to the original remote nor to a replacement remote except for volume up/down. Two possible causes:
1. defective IR (infrared) preamplifier circuitry internal to the unit;
2. corrupt EEPROM (possibly due to trial/use of a universal remote or was just zapped).
This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 17, 2008
  • 2,427 Answers
If there is a tv button on the remote, try pressing that..
Chances are its damaged and you might need to order a new one from Hitachi or possibly use a universal.. With remotes there really isnt much you can do when they stop functioning.
Remote control will not operate pioneer XV-dv990 changed batteries, now stuck on DVD player.
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician
Nov 22, 2014 | Pioneer Televison & Video
LE26R74BDX TV Not responding to Remote
there is a easier way to check your remote.
Open your radio on AM frequencies, you don't need to be tuned just noise is perfect, then bring your remote near the antenna and press some button. You will ear the frequency in your radio. If it works this way but not on the TV make sure to press the TV button before using it (if the remote is universal).
Jul 01, 2009 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Need a code for Hitachi Ultravision TV
hold power and tv button same time
until power buttton stays on then
slowly hit power button until tv turns off then hit stop button and tv will work with remote
Jan 15, 2009 | RCA Universal Remote Control
All of a sudden my TV remotes do not work properly
Since you said that the remote that originally came with the television does not work either, it's most likely a problem with the IR sensor in your television.
To make sure that something more important with the television did not fail, the next time this occurs, walk up to the television and attempt to manually change the options using its controls.
Nov 19, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Samsung SPN4235 has a mind of its own
Honestly,your TV should be still under warranty right?I would have Samsung fix it. TV had a serious problem from the beginning.
solutiondoct
Jul 31, 2008 | Samsung SPN4235 42 in. Plasma HDTV
LG HDD DVD Recorder remote control not working with LG TV
I have a rh 265 remote and lg tv. It stopped controlling the tv. I hold the tv power button down on remote then pushed 1 at the same time. It reset it to work with my tv.
May 29, 2008 | LG DE9523P DVD Player
Volume and mute buttons suddenly stopped working
Try changing the batteries. Most times the "tivo" buttons will work but the "tv" buttons will stop working when the batteries are low.
If you have done that, go back into settings and program the remote again for your tv, then give it a shot.
Nov 05, 2007 | Tivo DirectTV Remote Remote Control
Hitachi tv
I have the same problem. I got mine from a friend and my comcast universal remote does not work with it at all. For some reason it does not acknowlege it.
Oct 22, 2007 | Televison & Video
Televison & Video Logo
190 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
