Question about Philips 27PS55S 27" TV
"Digital TV ready"
I have the Philips TV model 27PS55S121. Can you tell me if this model is "digital TV ready" or if it will require a converting box to watch tv after Feb 2009 in the USA? Thanks
  • 2,794 Answers
The minute I searched on your model number on, the answer appeared:
Here is the answer
Posted on Jul 17, 2008
What's your problem?my television show black & white it has no color model no is 27PS55S121 philips, when i check the settings i set on auto, even the tuner is on auto eliud
if can not get with adjustment it could be a problem in the board, tried with re soldering cold soldered component joints at the video section.
Sep 26, 2012 | Philips 27PS55S 27" TV
Does the Phillips 60 HDTV rear projection require an analogue/digital converter?
Unless you are using a cable tv provider to receive your local channels you will definitely need a converter.
Depending on the cable provider will determine if you will need one at that time.
Feb 16, 2011 | Philips 60PP9202 60" Rear Projection...
I would like to know if the Hitachi 51UWX20B television can be connected to the internet.
Your Hitachi 51UWX20B is an HDTV-Ready TV. No Digital Tuner. HDTV-Ready means that your TV set is capable of displaying analog and high-definition digital pictures, but without a digital tuner, it cannot receive the digital signal. An HDTV-Ready requires an external high-definition TV receiver (digital tuner) in order to receive HDTV signals. These external receivers can be called an HDTV Tuner, set-top-box, decoder or DTV Converter Box . So you will be required to purchase a converter box to receive over the air programming from an external antenna.
Jul 03, 2010 | Hitachi 51UWX20B 51" Rear Projection...
My tv 27PS55S121 philips star on and off
This is pretty common. Usually it's because of bad solder connections at a part called the vertical output integrated circuit. Resoldering the bad connections is often all it takes to fix the trouble. While it's a simple repair, unless you have experience doing electronic soldering you should have this done by a professional. It's possible to more damage. Take the set to a shop for an estimate (won't cost as much as a new TV).
Mar 18, 2010 | Philips 27PS55S 27" TV
Is my akai projection tv digital ready or do i need to purchase a converter box.
depends if you have a cable service. Cable companies will still broadcast in analog because they are a closed system same with sat. only other way to tell if you have a digital tuner is by one a cable/satalite card or when doing the tv programing it asks digital?
Apr 14, 2009 | Akai PT4298HD Rear Projection Television
How do I tell if my tv is analog
Hi Dru,
Good news, your 42 inch Phillips has a built in digital tuner, all you need is an antenna.
Please post the model of your other Tv and I will check on the tuner type.
I have provided a link to a site that has good info on antenna types and the channels you will be able to recieve.
Let me know if this was the information you requested and please rate this solution.Lone99star
Jan 25, 2009 | Philips Magnavox 42MF521D/37 Television
Digital boxes
This model only has an analog tuner, so you will require either a converter box or hi-def tuner after the transition.
Dec 07, 2008 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Philips 27PS55S 27" TV Logo
235 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
