Sound but no pic on a sumsung lcd tv LE46M86BD
Hi , my story is like so, i have put the tv on the picture shows breifly for about 5 seconds then disapears the sound stays on though, , iv checked all the cables and connections but these are fine ,my tv set is a sumsung LE46M86BD, please help as my head is abot to explode, oh by the way i have managed to loose the remote control for the last few day too, looked in all the obviose places ( back of the sofa,the washing mashine too but its not there),if you tho have an instant cure without the need for RCU, it'll be gr8 stufffffff, thanks alot
  • bas9 Oct 15, 2008
    same problem over here. Did you contact Samsung about this?
    Champion:
  • 217 Answers
If the tv has backlights it's probably the T-con board, if no backlights it's the power supply
Posted on Jul 20, 2008
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
Power light turns green then red no pic or sound
Hi David,
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Check the cables, connectors and connections.
If your TV, flatscreen, or monitor is more than 5 years old it is more like to have suffered a
component failure.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
May 13, 2015 | Televison & Video
When we turn our TV on we get sound, but our picture is distorted for about 15 min then it's clear. Any sug?
Your TV is about 5 years old.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Dim screen
- Slow start
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Feb 26, 2015 | LG 46LD550 46 in. LCD TV
Lg 26 inch tv flat screen, no picture but sound ok!
The inverter needs replacement. You should be able to get one from www.tvrepairworld.com
Nov 03, 2012 | LG Televison & Video
Shows picture for a second when i press button than goes dark
Issues with back light:
Please do not attempt to diagnose if no competent.
Do at your own risk.
Check for 24 Volts power to the inverter board
No Power---Check Power Supply
Power Present---
Verify status voltage 3v to 5v on inverter board harness (plug)
Replace Inverter Board
Feb 11, 2010 | Tatung V30DMTT 29.6 in. LCD Television
The picture is taking longer and longer to come on. It's not a consistent length, last night had it on several hours, it was off for an hour and a half, turned it back on and it took over 90 seconds for...
if you can get another one for a reasonable i would certainly consider that. the cost to get these lcd's fixed sometimes is not worth it. you seem to have more than one problem with the set.
Oct 30, 2009 | Zenith C32V37 32" TV
LE46M86BD SAMSUNG LCD Picture issues (turning off after 5 secs)
you will need a tech to isolate the fault. could be power supply board or the main board but I suspect it is the lcd panel itself that is failing.
Oct 30, 2009 | Samsung LE46M51B 46 in. LCD Television
No picture
Hav 50 inch lg no pic but got sound wtf how do i fix it an there r 5 flashes b4 green light stayes on at the start
Apr 10, 2008 | LG 42LC2D 42 in. LCD HDTV
The green light on for 2 seconds and off again (Panasonic TH-42PWD5UY)!
PROFESSIONAL REPAIRER OF:
* cd-vcd-dvd-ld player.
* colour tv, Lcd/plasma tv.
* projection tv.
* prologic AMPS
* Grill/microwave oven's
* Digital proffesional camera.
* Digital camcorders.
* LCD/Digital projector.
* Hi-Fi music system.
* FAX machine.
* printer/scanner/copier.
* play station (PS1-PS2).
* X-BOX360.
DIAL..........: 9820380682
Jan 23, 2008 | Panasonic TH-42PWD5UY 42 in. Television
Televison & Video Logo
310 people viewed this question
Top Televison & Video Experts
Electro Med Services...
