I'm using the Comcast Custom DVR 3 Device Remove and am unable to find a code that works for my Philips DVD/VCR Combo (model DVP3340V/17). I've lost the original remote to the Philips.
Thanks!
SOURCE: CONNECTING DVD/VCR TO CABLE BOX & TV ETC
If using 3 color RCA (r/w/y) the red and white is audio and should go into your stereo under video or AUX. The yellow is the only video cable you need, that should go to your TV aux in or video1 or video2. You can also put all 3 colors into the tv and then run another red/white OUT to the stereo AUX in and have stereo sound for whatever you are watching.
Good Day,
The dvd/vcr combo can be hooked up one of two ways. I the TV has yellow/red/white jacks on the back or side, just match up the colors on both sides. Once plugged in you will have to change the source of the TV, to do this you need to press a button on the remote, it can be labeled as input,video1, tv/vcr, or source. However if the TV does not have red white & yellow jacks you have too hook it up using RF.
On the back of the dvd/vcr it should have two coax jacks, on is labeled RF IN the other RF out. Run a cable from RF out directly to the TV. If you have cable or an antennae on the TV now just unplug it and plug it into RF IN on the dvd/vcr.
Hope this helps and good luck
Hi
Configuring codes:
1.Turn on a desired device (VCR or DVD player)
2. On the remote control, press a device key once (i.e., DVD/VCR,
CBL/SAT or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD
Player Combo press DVD/VCR once. After programming a VCR Combo device,
you will be able to control channel selection,volume, and VCR functions.
To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once. After programming a
DVD Combo device, you will be able to control channel selection, volume, and
DVD functions.
To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer's Codes to locate the type of device and brand name and
then enter the first four-digit code for your device. If performed correctly,
the LED will blink twice.
5. Aim the remote control at the device and press POWER once. The device
should turn off. If it does not, repeat steps 2 to 5, trying each code for your
brand until you find one that works. If it still doesn't work, try Searching
For Your Code on next page
Auto Code Scan:
1.On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly press POWER button.Stop when
the TV turns off
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 to 5, but substitute the appropriate device key for the device you are
searching for.
Thank You
I need to remouve the region 1 to region 4 of the my DVP3340 COMBO, because I live in BRAZIL and hear only existe DVD region 4.
Please send me so as so posible the solution of the problem, send by E-mail: [email protected].
Thank you attention,
sincerly,
SERGIO BRAZ GRISOLIA
