Question about Insignia 26 in. LCD Flat-Panel HDTV
Can't get base off 26" Insinia 720p
I finally got the base off but there is still a huge silver circle looking thing attached at the bottom that held the base on. I can not for the life of me figure it out. I can hang it on the wall with it on there but looks very bad and way unfinished.....please help!!!!!!!!!1
  • Anonymous Aug 25, 2008
    We have the same problem - it really seems odd, and we can't find anything about it in the manual.
  • Anonymous Sep 05, 2008
    Same problem here, too.  Silver circle with a bolt sticking out.  Ugly and snares cables.
Okay, I read the above fix and still couldn't get the bloody stand off. LOL... I just figured out that it has nothing to do with the screws on the bottom of the stand, which also have eight screws, they are the other eight ones on the back of the LCD where all the inputs go in. DOH!
Posted on Nov 03, 2008
Dude, perfect, thanks so much!
Posted on Oct 22, 2008
On the back of the set you will see 8 screws just above the stand; remove the screws
and gently slide the stand out. Wiggle it alittle and the stand will come out.
Remove the metal tab you just pulled out by removing the screws at the bottom of the tab (attached to the pivit joint) place the tab back in the bottom of the set( same place you removed it from) and re-install the screws ( don't over tighten them). You are done.
I had the same trouble with this set and the tech support was of no help. Good Luck.
Posted on Sep 08, 2008
The pilot lights and stays lit. When I try to ignite the burner, the pilot goes out as soon as I turn the knob.
follow this steps and fix it. God bless you
  • Disconnect the gas line from the heater by unscrewing the coupler attached to the gas inlet valve near the bottom of the burner or base of the unit.
  • 2 Remove the top cover from the heater, following the manufacturer's instructions. Typically the cover is held on by a screw and nut at the top or multiple screws around the perimeter. You may need a screwdriver to remove the screws.
  • 3 Look at the burner assembly, which is where the flames typically emerge. Open a bottle of rubbing alcohol and saturate the end of a cotton swab with it. Rub the cotton swab over the holes around the perimeter of the burner assembly to clean away grease, dirt and debris that may be clogging it.
  • 4 Look at the back of the burner assembly to find the venturi tubes, which are small silver tubes with holes in the end. Insert a pipe cleaner gently into the end of each tube and push it in until you feel resistance. Twist the pipe cleaner in a circle and pull it straight out to remove any spider webs that are blocking the inside.
  • 5 Reassemble the cover on the patio heater by reversing the steps taken to remove it. Reconnect the gas coupler to the inlet valve and turn on the heater to test the pilot ligh
Nov 23, 2013 | RTO Bernzomatic Brushed Nickel Patio...
My flashlight will not turn off
This is what i did to make it work (by pure guesswork).
1. take the battery holder thing out.
2. see black arrow on side of battery holder, that needs to point toward the led end when you insert it.
3. Look at the end of the battery holder, at the end that will go in first when you insert it. On each end there is that silver metal circle that has some silver metal extensions that go straight across the bottom.
4. look into the flashlight toward the led end. See the green circular circuit board thing. You'll see that equally around that circular base, there are 4 little squares of metal right to the edge of the green base, equidistant around the green circle. Carefully insert the battery holder with the silver metal strip on the holder lined up so each end of that strip will touch one of the 4 little square metal things on the edge of the green circuit board. The goal is that when the battery holder is all the way in, the two metal extensions coming out from the little circular metal piece on the end of the battery holder will each touch one of the little square metal pieces on the green base.
5. Screw on the lid and click the end to turn on the light. I tried this two times and both times it worked. If it doesn't turn on you might want to try to reinsert it again and get it more carefully lined up.
Good luck.
Apr 28, 2013 | Emerson 9X Power LED Flashlight
I fixed my hitachi magic wand, but now I cannot get the silver ring back on during the final steps of reassembly
rotate the head/neck part, one of the sides is not aligned with the notches in the bace of the neck. rotate it to fit right then you should be able to fit it on easily
Jul 16, 2011 | Hitachi Magic Wand Hv250r Hand Held...
Need code for my Cox Remote Control for my 26-inch Olevia 226 T12
We had this same problem as well and we finally found the answer, the code for the COX remote (silver on top black on bottom) is 1240.
Feb 21, 2010 | Olevia LT27HVX 27 in. LCD Television
Just a question as to how the base attaches to the tv?Don't have the unit, at a friends house and wants to know how to remove, looks like it attaches at the bottom, is this correct?
Most tvs have four to six screws that go in the back just above were the mount goes in at the bottom of the unit. look for a 8 to 10 inch raised area or 3 screws in a row, 2 rows. Face the tv face down on the bed with the base hanging over the edge. Some tv's like L.G.base just push into the bottom with 2 or 4 screws holding it in place. The screws will look much heavyer then the ones going around the set. maybe round top not flat topped
Nov 26, 2009 | Sansui HDLCDVD260 26 in. LCD Television
I inherited a G20 gladiator chevy van and cannot figure out how to get the spare tire cover off the back door??? It sounds stupid, I know.
Most likely Gladiator conversion vans disappeared like many of the other conversion van companies. I am not familiar with Gladiator vans, but most of the conversion vans use the same setup. The chrome ring around tire is latched near the bottom, and usually padlocked to keep others from stealing your spare. If that is not the case, try http://www.v-sales.com/repair.htm . They still sell conversion parts and may be able to help you. Hope this helps
Sep 29, 2009 | 1993 Chevrolet G20
Water leaks during final spin cycle only
The first thing to do is get the machine up off the floor onto a base that allows you to slide under machine on your back with a flash light. Make sure whatever you decide to lift machine up onto is very stable and durable. Bricks, blocks, or a utility cart maybe. You need to look under machine to see where the leak is coming from. You want to make sure it is not going to fall on you. The machine is not that heavy, just awkward to lift or move because of it's size. So, you could slide something under each corner, one at a time, or ask a friend to help lift it onto a base. Now you are ready to go. Don't worry, this is really easy.
Get a towel, flashlight, and start machine on a small load with shortest cycle set.(probably delicate). After you start machine, slide under and and try to find where water is leaking from. The pump is going to be a plastic circular shape thing with ridges on outside. Probably dead front center and attached to motor. If water is leaking anywhere from plastic circle thing, then this is your problem. BUT, also follow all the black hoses that are under machine. Sometimes leak can be a cracked hose or loose attachment. That is real cheap and easy. The hoses are attached with metal ring deals. You take a pair of channel locks or big pliers and squeeze them to open. There are 2 or 3 hoses that attach to pump that will need to be removed if this is where leak is coming from. Then, the pump is only attached with metal clips that you pull out to release pump from motor. No tools needed. Take the pump to sears or local appliance shop and I guarantee they will have replacement.
Thank you for contacting Fixya.com
Aug 09, 2009 | Fisher and Paykel WA37T26G Top Load Washer
Bobbin case is disassembled. how do I put it back together?
It should be in your manual.... but if you don't have one, I'm gonna try this out. I don't know the official names, so bear with me.
There should be two plastic arm-lookin things that are turnable. Make sure these are turned outwards.
You should have three silver pieces. The one you need first is a half-moon looking thing with a knob comin out of the middle. (it also has some holes in it)
If you turn the big knob on the right hand side, there should be a moving piece on the inside of the bobbin case.
The half moon needs to fit in with that piece. Don't force anything cause we don't want the machine to break. >< The knob thing needs to be facing the outside, otherwise it's not gonna go in at all.
Once you get the half-moon thing in there, you have two more left. There's a big circle. WOO! CIRCLES! ANYWHO, The big silvery circle.. it has a knotch in it, and a little pokey-outie thing comin' out of it.
It needs to be positioned so that the knotch (on the inside of the circle) is up and the pokey-outie piece (on the outer side of the circle) is on the bottom. On your machine, there should be a place where the pokey-outie piece would fit perfectly into a little hole-type-thing. Put it in. :O
Now it's time to move those little black plastic arms towards the center. On your circle, there should be little grooves that they fit right on top of. ^_^
The only silver piece left should be the actual bobbin case deal. This should be a smaller circle with a movable arm and a silver thing pokin' out of it. (I told you, I'm bad at names!) Before you put this guy in, we need to have your plastic bobbin threaded. (I'm assuming this has already been done, correct me if I'm wrong.... they also have pre-threaded bobbins for sale, but hey, whatever works.)
Your bobbin needs to fit inside this last piece. (my first bobbin didn't, and I freaked out and ran to my dad... LOL) You need to make sure there is a trail of thread coming out of your bobbin that's about two to three inches long. Place your bobbin in the silver guy and there /should/ be a little niche where you can play with the thread and pull it through the silver guy's parts. (Your thread may break, don't worry, just try again)
When you move the thread around, it should come out where the little arm that sticks out is. Keep the 2-3 inch trail goin' on, you'll need it. Remember that first half-moon silver guy? Well, we're gonna stick our little assembly onto his pokey-outie piece.
The silver arm-thing on our assembly needs to go into the knotch that's in our circle, and push in so it clicks. (Sometimes mine clicks twice...) Make sure you have that trail of thread, and go ahead and flip the white plastic up, because you're DONE assembling it.
I'm going to assume you have your top thread in already (again, correct me if I'm wrong..) make sure that your top thread is through the hole in the needle, otherwise we're thoroughly screwed. Pull that thread until you have another 2-3 inch tail, and twist the big white knob on the right side of your machine (same one as before...) TOWARDS you. KEEP HOLDING your top thread, otherwise it'll disappear into the abyss that is your bobbin assembly.
When you turn the knob towards you, your needle should dip down into the abyss and come back up- with your bottom thread! HUZZAH! it SHOULD be a loop around your top thread. (I'd use contrasting colors for practice.. so you know what it'll look like)
The manual says to "grab the bottom thread" but seriously, I can't get me fingers down in there, so I just slide some scissors under the foot and between the two sides of the loop, and just slide 'em left. usually works just fine. Unless my tail for the bottom thread is too short, cause then it'll be hard to grab. You should be good to go!
I know this is pic heavy and kind of long, but I like to provide as much info as possible! Let me know if it helped!!
Jul 19, 2009 | Brother LS-2125 Mechanical Sewing Machine
Cutting holes
My Dremel 300 came without any instructions, so I had to puzzle out how to use the circle cutter. None of the images I managed to find on the Web or elsewhere were any help. I directed my attention to the "spike" on the circle cutter, and eventually I realized that it was on the wrong (top) side of the cutter--perhaps for safety's sake. When I removed it and positioned it on the bottom side of the cutter, things became clearer. The next thing was to locate the correct cutting edge. I had never used Dremel before, so I didn't recognize the cutting "bit", since it looked like a drill bit. The final problem was how to attach the circle cutter to the Dremel tool. I couldn't see any way of fixing the cutter to the tool. I thought perhaps there was something missing--a connector, perhaps. Eventually I found a reference on the Web to "removing the cap" on the tool. I hadn't noticed a "cap", but when I gave it a turn, it began to unscrew, so I knew I was in business. Finally II tried the attachment out on a piece of scrap timber, I found that it worked. A simple instruction manual would have saved me a lot of time. Also, I now discover that the Dremel 400 would be much more useful than the 300. Dremel don't seem to be very customer friendly. I can access the US site, but the UK and Germany website won't let me in!
Sep 01, 2008 | Dremel 764 04 Pumpkin Carving Kit Includes...
Base removal of mounted plasma
Pls do not take any other screws, other than silver screws.if you take the 6 pcs of silver screws and pull the stand it will come out easily.
Sep 01, 2007 | Haier HL32BG 32 in. LCD Television
Insignia 26 in. LCD Flat-Panel HDTV Logo
115 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
