Question about Toshiba Satellite A105-S2716 Notebook
Emachine m5310 laptop
When u turn it on it says windows did not start successfully an gives u options safe mode ,start windows normally , safe mode w/ net working ,an so on. but no matter wich mode u start it in it keeps on rebooting. it will show the windows xp logo like its going to start then it goes back to the windows did not start successfully an gives the same options safe mode , start normal, ect.... what could be the problem?
  • Anonymous Mar 30, 2014
    hello i have a problem with my laptop i can only start it on safe mode i do not know why it doesnt want to start normal one of the emergency lights its on and idk the meaning
    Genius:
  • 2,028 Answers
This generally is the indication that the hard drive has failed and needs replaced. You can try reloading the system, but 99% of the time when I see this the hard drive is shot.
Posted on Jul 17, 2008
  • Jack Jun 23, 2012
    Thanks. Jack
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
Wont boot in safe mode
start your laptop before booting windows press f8 button continuously
ndows 2000 / XP users
bulb.gif If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
Microsoft Windows Vista and Windows 7 users
Sep 27, 2011 | Lenovo G460 Laptop Computer - 06779XU...
When I turn my emachines netbook on, it gives me a error screen saying 'run in safe mode (recommended) and 'start windows normally'. No matter which I choose, it goes to the windows load screen...
there is a recovery tool on emachines usually loaded during you boot the system to safe mode. on my case i restore my machine to its default and reinstall my o/s.. hope it helps
Sep 05, 2011 | eMachines eM250-1915 Netbook
I had accidently turned of the power as my PC was loading up , so then when i turned it back up it has come up in a black screen saying:- We apologize for the inconvenience , but windows did not start...
Now that PC works in Safe mode i suggest you to run the Disk Check.
Step1: Double click on My computer and then right click on C drive.
Step2: Choose properties and then click on tools option.
Step3: Click on the Check Now tab listed under Error Checking.
Step4: Select both the options under "Check Disk Option" then click on start.
Step5: It will prompt you to restart your computer.
Step6: The Disk Check gets initiated as soon as you your computer starts rebooting.
Step7: Allow it to finish.
Hope this helps.
Jan 15, 2011 | ASUS Eee PC 1000HE Netbook
Laptop wont boot it comes up with page saying windows did not start successfully then gives option to start windows normally, in safe mode, safe mode with networking, safe mode with command prompt or...
Windows is corrupted beyond repair, you will have to reinstall it and return the laptop to factory condition. Use the recovery disk that came with the laptop when you bought it an follow the instructions from the manual to the letter.
Dec 20, 2010 | Computers & Internet
My compaq mini notebook wont boot up, when you switch it on it comes to a page saying windows did not start successfully. A recent hardware or software change may have caused this. It then gives you the...
Hi, sounds to me that you are having a software problem. When you boot the laptop choose the Last know good configuration option to see if that will correct the problem.
Dec 20, 2010 | Compaq Computers & Internet
Black screen
- I had the exact same problem with a eMachines W340UA and other machines. I'm not sure what this does, but I resolved it by booting into Safe-Mode. Upon successful boot into Safe-Mode (without Networking), I restarted the computer in the normal mode and it for then after worked. Please try this; though I can make no logical statement as to what occurrs or what gets fixed, I have had this method work on several machines.
INSTRUCTIONS:
Fire up the machine, after BIOS postings, continually press the F8 key. From the list of startup options, choose "Safe Mode (Without Networking). It should boot up in this mode.
After the successful boot, restart the machine and allow it to boot in normal mode. If all goes as it has for me, you will successfuly boot into Windows.
P.S: If anyone knows where the coin battery is on an eMachines w340ua laptop, and hot to get to it, please let me know. Thank you and I hope this helps!
Sincerely;
Glenn T. Kitchen
admin@consultingVisions.com
Oct 16, 2008 | Computers & Internet
Hp laptop
windows is thnking that you have a problem with the system
start windows in safe mode and troubleshoot and see what the problem is if all else fails you might have to to a system restore
or take it into a tech and see what they think
hope this helps
cheers
Jul 20, 2008 | HP Pavilion dv1000 Notebook
EMachine laptop/windows xp problem
ur window had been crashed pls install new window
Jun 15, 2008 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Laptop start up problem
go into bios and turn off virus i assume you have xp
Oct 25, 2007 | Compaq Presario V4000 Notebook
Toshiba Satellite A105-S2716 Notebook Logo
136 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
