Question about Emerson SpongeBob SquarePants TV
13" spongebob Television
The television is getting power as the power light on the front is on. However, there is no picture and no sound.
    Novelist:
    Champion:
  • 211 Answers
Hi Shelly,
It sounds to me like makebe the horizontal output trasnistor is out. This is somethign that will need to be repaired by a technictian. If you are going to change this part yourself ( assuming for sure that is the problem ) always be very careful when opening the back of the TV. Always unplug it first, then discharge the picture tube as there could be as much as 30,000 volts of energy stored in it. The horizontal transistor is the biggest, black, nearly square transistor that is located next to the trasformer that has the large red wire going to the picture tube. You will need to solder it in. I do suggest you do have a qualified technitian do the job since there is some danger in working in the tv set.
I hope this has helped in some way.
Ed
Radio Man
NC Electronics
Mills, Wyoming
Posted on Jul 17, 2008
Westinghouse 19inch model 19h210s has picture no sound
Fix Your Westinghouse SK-19H210S Television - Instructables
www.instructables.com/.../Fix-Your-Westinghouse-SK-19H...
InstructablesI called Westinghouse and they said that I was out of luck because it was no ... on an the screen lights up an then off ?have sound but no picture after start up .
Westinghouse SK-19H210S has picture no sound - Fixya
www.fixya.com/.../t11272945-westinghouse_sk_19h210s_picture_no_s...
Jan 13, 2012 - Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board.
Oct 16, 2015 | Westinghouse Televison & Video
The front panel has a blue light and power , but i am not getting a picture or sound.
The blue light on the front panel merely indicates that power is getting to your TV. It is likely that there is a failure of the internal power supply
Mar 07, 2013 | JVC AV-48WP74 48" Rear Projection...
Power Issue
Now,u plug in the tv u get a solid red standby power red LED light in the front of the LCD panel right?When u push the power button on the remote u hear a clicking sound?Only one clicking sound,not the power supply board problems.It the Tuner board problems.But u can make sure it the power board problems or not.By taking the tv aparts check the power board,that board where the a/c power cord goes into it.Look all around the power supply board check for these leakage capacitors,they alway bulges up it top or puff up it top.No bad leakage capacitors,then it not the power supply board problems.
May 14, 2010 | Haier HLH406BB 40 in. LCD HDTV
Spongebob Squarepants 13" SB315
It is usually the cable. Fiddle with the cable where it connects to the playstation. Disconnect and reconnect to playstation.
Sep 01, 2008 | Emerson SpongeBob SquarePants TV
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
Spongebob television
It may sound silly, but did you check the batteries inside the remote control? I thought I'd ask since you didn't mention it.
Sep 07, 2007 | Emerson SpongeBob SquarePants TV
No sound, no picture and a red light blinks on front panel
If I remember right the set is blinking a code, dont remember which code, but what happened something on the power board failed and knocked out the 5vdc regulation? The power board will most likely need replacement, this should be done by a qualified technincian or someone who knows how to dissassemble/ repair set.
Jul 07, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
No pictures and no sound on Toshiba TW40F80 television
Check soldered-in micro fuses in power supply. Ex.--F851,F852.
If there is a blown fuse, identify which B+ circuit it protects.
Most common - convergence IC's bad===replace.
Need more help? Let me know.....T.
May 21, 2007 | Toshiba TW40F80 40" Rear Projection...
How do I reset the password on the dvd player?
SpongeBob SquarePants 13" TV Is the DVD player in this 13 inch television; if it is then you can ring the product support number 905-940-5089 I hope this is correct for the USA. Or you could try hypnotizing your son to get the password!
Oct 22, 2006 | Emerson SpongeBob SquarePants TV
Emerson SpongeBob SquarePants TV Logo
66 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
