KitchenAid KHMS155LSS 1000 Watts Microwave Oven Logo
Posted on Jan 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
There was a huge pop now it won't microwave anything...it runs but no heat or cooking.
Anonymous
Level 3:
Brigadier General:
  • Master 8,909 Answers
  • Posted on Jan 22, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
8909
Questions
Helped
1541479
Points
28391
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Load test.
A simple safety test.
Place 1/2 litre of water in a glass container. Measure the temperature of the water.
Place in microwave and heat on full power for 1minute.
Measure the temperature after it has stood for 1minute.
If the temperature difference is more than 9 degrees Celcuis the magnetron is working and producing about 700Watts of heat.
If your microwave is labelled with 900 or 1000Watts. That is about right.
If the temperature is less then the magnetron is not working properly and may need replacing.
This a only a rough guide and any doubts you should consult an authorised service agent.
1helpful
Kenmore Microwave model Fan running and light on when door closed.
This is normal. Kenmore microwaves will stay running with fan and light on for a short time after food is cooked. The reason is to air out the microwave after cooking. Things like pop corn, Bacon etc. have strong smells after cooking. The ventilation helps to remove odors.
2answers
Shut's off after cooking popcorn, only popcorn, won't restart for 15 too30min.
Sounds like the magnetron is over heating. Try putting a 4 0z cup of water in the oven along side the popcorn bag. See if this helps. Usually, the oven only runs 2 to 2.5 minutes for a bag of popcorn. You may have to experiment with the slightly different cooking time...
2helpful
Sharp R-1510 1000 watts microwave, not heating
Sounds like the inverter (power supply for cooking) or the magnatron which does the work----neither are cheap parts.
2helpful
Have a kitchenaid microwave KHMS2040WSS brand new. Is there a way to set the popcorn sensor for a smaller bag? Right now it is set for 3.5oz and burns all the popcorn.
I have never seen a microwave that doesn't burn popcorn if you use the "popcorn" button. Why the manufacturers keep putting them on I'll never understand. There's nothing you can do change the presets on an oven since they are built into the controller. Instead of relying on the oven, you should follw the directions on the bag. These tell you to use high power, stay by the oven and stop the cooking when the time between pops drops to 1 or 2 seconds. Stored heat will continue to pop kernels for a bit, and you won't cremate your popcorn. You'll also avoid the possibility of the bag catching fire and damaging the oven, which I have seen several times. Finally, don't expect 100% of the kernels to pop. There wil always be a few duds, and extending the cooking time just results in burned popcorn.
1helpful
Own Whirlpool microwave model MH7100XY, everything works on it, however it does not heat anything, heard a small pop and after that it does not warm or cook anything?????
The pop sound is an indicator the magnetron is gone that heats the food. It is cheaper to replace the microwave oven than have it repaired.
Made a popping sound. Runs but doesn't heat
Remove the outer cover and look for a blown fuse. Change the high voltage diode (pull the power plug first) and the 'stirrer' (a fan-like device located inside the sheet metal waveguide near the port where the microwave energy enters the cooking cavity). It's plastic bearing will arc-over causing a short circuit on the microwave energy.
Everything works except the cooking part/no heating/turntable not turning, help!
you may have gotten a power surge and that can cause some funny things to happen, 1st is there power to the oven, 2nd if so there may be an internal fuse protector built in to the oven, check with the manual for anything of that sort listed. if not you may have to take it in and have it repaired by a pro. there is a lot of voltage in these ovens and unless you know what you are doing a person could get hurt
Top KitchenAid Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
