Out air compressor fan runs for about five minutes then the fan stops turning unit is about 5yrs old
  • 41 Answers
If the compressor stays on for a short time after the fan stops most likly the fan motor has problems could be capactor or bearings dan
Posted on Jul 17, 2008
My 4 year old Ruud home a/c compressor stopped working. inside fan blows but compressor won't turn on...what can I do prior to calling the gas company who installed the unit...
Ruud parts warranty from factory is 5 years, the capacitor has possible gone out, it will be in the contol compartment on the out side unit and is a dual run capacitor that controls the compressor and fan motor. Recommend if capacitor is bad to replace entire capacitor. As Stated above the parts are under warranty if under five years old. To verify age the date code is in the serial number after the "F" **** week/year of manufacture. Also outside unit has independent power supply so check fuses if any and circuit breaker.
Aug 21, 2011 | Ruud UBHC Air Conditioner
Window unit (110) cools for a few minutes then stops cooling just fan air unit is about 6 0r 7 years old
It sounds like your compresssor is shutting off on an overload. After the overload cools down the compressor comes back on until the overload heats up and shuts the compressor off again.The fan keeps running as it is not on the same circuit as your compressor.
Aug 02, 2011 | Carrier YC273D Air Conditioner Window/Wall
Have maytag fridge about 5yrs old and is triggering the safety switch to go off every 5-6hrs , the freezer is ok the fridge is not cooling, what is the problem
Most likely it is short cycling because the start components or condenser fan are defective. This causes the compressor to run for a few minutes and stop because of overheating. The overheating is tripping the breaker. The cycle will not change until the issue with compressor or fan is resolved. To continue to allow it to run like this risk permanent compressor failure. Thanks, Sea Breeze
Feb 20, 2010 | Refrigerators
Carrier Compressor Issues?
When you shut it off and back on it slugged the compressor if you turn it off and back on before the pressures equalize between the high and low sides it will slug the compressor and it will not run should let sit for five minutes or so before restarting. The humming is either the compressor making noise usually common for the compressor to make some noise or the fan motor bearings are getting bad on the outside unit. If the unit works normal probably not much you can do till it breaks if it is the compressor it is more economical to replace the whole unit if it is just the fan motor it is worth changing. You could take an amp draw on the fan motor and the compressor to see if the are within the limits on the name plate of the outside unit.
Jan 25, 2010 | Heating & Cooling
Compressor will not fire suspect caps how to troubleshoot
how old is unit,or i missed it.,caps are a great non compressor start,some caps are "dual-caps" one is for comp and other is for fan,will have 3 terms in that case,they are a good investment if unit is over 5yrs old,they're not cheap,can you put a ("headset")manifold gauge set on and see if low on refrigerant,that will cause same problem/fan but no a/c compressor
Jul 27, 2009 | Coleman Heating & Cooling
When unit starts the condensor fan only comes, not compressor
You need a new fan motor and the correct capacitors for your sydtem I think they are 35 or 45 5 cap. Try a hard start kit on compressor. Are you sure you have the cap wired correctly?Russ
Jul 16, 2009 | Carrier 38CKC036 Air Conditioner
RV air conditioner. Compressor running, fan stops before cool
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
Jun 06, 2009 | Dometic Rooftop RV Air Conditioner
Fan quits and the compressor still runs
is this a split residential system. it sounds like you are talking about the condenser fan either way it seems like the fan is overamping and tripping on thermal overload which is a device in the motor that protects itself. when you shut it off for a while and turn it back on does the fan work. if you turn it off then turn it right back on does the fan work. when it shuts off is the motor really hot. if possible, and you know how, check amp draw. typically you can find the rated amp draw on the motor nameplate.
May 27, 2009 | Carrier 52CQ315 Air Conditioner
Air conditioner fan will not come on and unit will run for 1 minute and stop
You hear the compressor kick in (Hum) but no fan comes on? Will the fan come on when just in fan mode, not cool, or do you have that set-up?
Aug 13, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
