Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Amana 22 side-by-side refrigerator, freezer door opens slightly
When I shut the door to the refrigerator (not slaming it, but normal shutting it, the freezer door is now opening slightly by not enough to light the bulb, but enough to cause frost to start building up. The door does not feel as tightly sealed as the refrigerator. It was made in 1988. Is it time to go looking for a new one?
Bill from Audubon, NJ
  • Anonymous Sep 08, 2008
    Have the same problem - what's the answer?
  • jsjg99 May 02, 2010
    i have a Amana 22 side-by-side refrigerator freezer,it is 12-15 yrs old.meats stay frozen but simple thing like ice cream is not.my temp in freezer is 20degrees right now.
    anyone with any ideas.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
There are three possibilities to this problem:
1. Door seal which should be magnetic is faulty.
2. Ice maker caddy (container) has not socketed properly into ice maker rear drive tang.
3. Door stay closed plastic hing pieces are damaged. These are tapered pieces that fit in hinge area that allow door weight to help close and hold door. Some are black in color and some are white. As far as I know they are interchangeable.
Posted on Jan 01, 2009
    Sergeant:
  • 409 Answers
Sounds you need to replace the freezer gasket. they are made of soft rubber and over time they loosen up. have a technician replace it.
Posted on Sep 13, 2008
I installed a new magnetic seal on my Amana refrigerator. The new seal has been sitting in its box for about ten years. After installation, I realize it has lost its magnetism. Can I rejuvenate it somehow?
No. Never heard of this happening. Make sure that the door stop at the bottom hinge is not bent and keeping the door from shutting all the way. I've seen this alot. Also, if you soak the gasket in hot water for 15 minutes or so, it will soften it up and lay flat when you install it.
Feb 20, 2010 | Amana ATB1832AR Top Freezer Refrigerator
Freezer door opens when you shut the refrigerator door
Adjust the front legs of your refrigerator slightly to raise the refrigerator. and and store items on the freezer door shelves to add weight. This is a problem of pneumatics and a testament to how tight newer refrigerators are. When you close the large refrigerator door it compresses the air in the refrigerator compartment. Both compartments are connected by air passages and thus the pressure change is transferred to the freezer causing the freezer door to pop open.
Raising the front of the refrigerator a tiny bit will help both doors close from the 90 degree point, which is desirable. Adding weight to the shelf will just help the process.
An additional aid in self-closure will be to use vegetable oil on a paper towel to wipe down the hinge side face of both door seals. All these maneuvers should aid in causing the door to stay closed and re-close if it should open slightly. Good Luck
Sep 03, 2009 | Amana Refrigerators
Refrigerator side not sealing tightly when shut.
Sounds like you may need a new magnetic seal. It is worth the money to fix it, saving electric and your food items.
Good Luck
Aug 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Side by side Amana freezer/refrigerator thawing.
The doors not being shut can make it freeze up,Just thaw again and make sure the doors get shut each time and see what happens,just post back details if it doesn't work after thawing
Aug 05, 2009 | Amana ASD2625KE Side by Side Refrigerator
I have a side by side Viking refrigerator and after leaving the door open a little too long the lights went out in both the refrigerator and freezer. I figured that they would go back on automaticlly after...
Remove the center grill of the top grill and shut the power off and back on, the lights should reset
When the lights are working open the Ref door then close the freezer drawer, watching to see if the light in the freezer shuts off. It should shut off when the freezer is about 1" from closing. If it stays on until the door is fully closed then there is a problem with the light switch in the freezer.
Normally when you leave the doors open until the lights shut off, it should reset when both doors are closed
Mar 06, 2009 | Viking DDBB363 Bottom Freezer Refrigerator
Fridge not cooling
hi there.
welcome to fixya.
initially try to defrost the ref and clean it.
Feb 26, 2009 | Amana ASB 2623 Side by Side Refrigerator
Freezer side door opens when large refrgerator door is closed
no promblem when you shut one door it forces air to the other side remove the kick plate at the bottom adjust the rollers till the fridge leans back i set them so when you turn loose of the door slightly past the halfway position it shuts its self that way when it pops open it shuts its self
Feb 15, 2009 | Maytag MSD2454G Side by Side Refrigerator
Amana side-by-side refrigerator/freezer
raise the front legs/rollers so unit is tipped back slightly.its ok if it opens as long as it closes.
Aug 07, 2008 | Amana SCRATCH&DENT 25 Cu. Ft. French Doors...
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
862 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
