Question about Polaroid I533P Digital Camera
Uqqqq my cameraaa!!!!!! the lens are stuCk and it dunt wanna tuRn On hO0w d0O ii FiiX ittt?????!!!!!
I have juSt pErchasied [spelled rOnqq i knO] 3 dayszx aqO and i drOppedd it and it nOw i qO to turn it 0n and it beepsz 3 tiiMes and turnszx 0ff hte sCreen sTayszx blaCk hOw do i fiix it??!!!!!!
pleszxx helpeee mee!!!!!!!!!
  • 4 more comments
  • Mywords2deep Nov 17, 2008
    I have a pink Polaroid l533P digital camera and I dropped it on the lens part and now it wont turn on. At first it turned on I think a couple times but now it wont turn on at all. The green light flashes once and nothing happens. I lost the charger but I've been putting batteries in it. No luck?
    Help?
  • Anonymous Dec 12, 2008
    when i turn it on, the green light turns on, then the screen flashes, then it beeps three times. then sometimes (if its plugged into the comp.) the light turns red. then.... nothing.
  • kmwaltem Jan 11, 2009
    Mine is doing the same thing. The lens won't go back in and when it turns on the green light flashes three times and the screen flashes on but then turns right back off. Any advice?
  • guanjagirl Feb 12, 2009
    My batteries were low and the camera shut down without the lens going in all the way. When I turn it on a green light flashes and it beeps three times, then the screen is blank. Now the lense whont go in all the way out or all the way in. what do I do to fix it?
  • mwestga Apr 03, 2009
    Lens is out but closed, and when you turn it on , it beeps 3 times and shuts off. Help?
  • kaylamarie57 Apr 21, 2009
    My Lens Also Just will not go back in. Yet the blinking light stays on when i turn it on. I wish i could just fix it real quick without having to bring it into the shop.. Can i just push on the lens?
You need to use rechargeable batteries. This was happening with mine when I first bought it too, I took it in and that's what they told me to do. It worked for me.
Posted on Jun 13, 2009
Type correctly and maybe someone will help you.
Posted on Aug 01, 2008
Replace lense cover on camera
You can try doing a Google search for your camera make model. I did and found this - below.
btw - Canon is spelled with one "n" which might help in your search results. I'd go to canon usa and click on their link or search their store for your replacement lens cap. Different lenses have different sized lens caps, so be sure you have the right one.
Lens Caps ' Canon Online Store shop.usa.canon.com/shop/en/catalog/.../ef-lens-accessories/lens-caps
Canon Tips & Tricks When using a lens with IS while on a tripod, ... Canon Tips & Tricks That hole in your battery cover has a purpose! ... Lens Cap 14mm f/2.8L II.
Mar 19, 2013 | Cannon Cameras
The lens cover does not open or close completely. just started happening. the camera is 2 years old and the battery is fully charged
A stuck lens cover is a fairly common problem, but it is normally easy to fix. A single grain of sand jamming the cover mechanism is normally the culprit, and you want to try to dislodge it: 1) Try blowing lots of compressed air around the lens cover to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Use no heat mode if possible. 2) Slide a thin strip of paper between the lens cover shutters and the outer support ring. Work it around 360 degres to clear out any debris that may be in there. 3) With the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. Repeat the above three steps several times. If repeated tries don't work (keeping in mind that it usually does), it then may be necessary to open the lens barrel to access the lens cover mechanism.
You can open the lens barrel up to fiix the covers, but only as a very last resort. The above procedures normally work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty).
Oct 26, 2009 | Cameras
The lens cover on my Canon Power Shot A530 will not close completely. The camera still works fine, but I am concerned about damage to the lens. Is this fixable?
Oct 13, 2009 | Canon PowerShot A530 Digital Camera
Lense will not turn / focus at all - jammed
We need to know what kind of camera you have and the information as to how it was handled in your use.
Was it around any of the following?:
Sand.... spells doom.
Water which gets into any parts... spells doom.
Any kind of impact whatsoever... this can lead to a number of problems.
Since you have not mentioned what your camera is, although you are in the D40 section, I assume it to be some kind of Nikon lens.
My suggestions:
If it is a Nikon lens... consider having Nikon to repair it. Nikon Site
If you do not want to repair it, then consider to sell it as parts or repair or as is on a site such as Ebay.
Aug 31, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Lens protective cover won't close after I dropped it.
You can open the lens barrel up to fiix the covers, but only as a very last resort. The above procedures normally work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Jun 30, 2009 | Canon PowerShot S410 / IXUS 430 Digital...
Lens cover won't close and there is internal dust
A stuck lens cover is a fairly common problem, but it is normally easy to fix. A single grain of sand jamming the cover mechanism is normally the culprit, and you want to try to dislodge it: 1) Try blowing compressed air around the lens cover to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Use no heat mode if possible. 2) Gently slide a thin strip of paper between the lens cover shutters and the outer support ring. Work it around 360 degres to clear out any debris that may be in there. 3) With the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. Repeat the above three steps several times. If repeated tries don't work (keeping in mind that it usually does), it then may be necessary to open the lens barrel to access the lens cover mechanism.
Apr 16, 2009 | Canon PowerShot A560 Digital Camera
Lense will not close properly
Apr 25, 2008 | Canon PowerShot A70 Digital Camera
My sandisk mp3 512 player won´t start
i really dnt kno this happened to me too im tryin to fix it the best thing u can do is call em up on sandisk.com IF u havnt already tried to mess wit it already if u do find out how to fiix it, PLEASE email me at tsingh66@sbcglobal.net
Mar 19, 2007 | SanDisk Sansa m230 MP3 Player
Polaroid I533P Digital Camera Logo
147 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
