Question about Frigidaire PLEF398AC Electric Kitchen Range
Frigidaire cooktop I own a frigidaire smoothtop range model # PLEFM399DCB.I was cooking hot and spicey beef jerky in the oven, temperature 320 degrees.The steam from cooking was coming out of the oven vent which caused water to sit on the smoothtop and then the beeping started and F7 and 20 and 22 kept flashing on the controls.Could the water have got in the control panel.The beeping just keeps coming on.
  • 639 Answers
Hi Bobbiflower,
Happy to help you!
Go online to www.Frigidaire .com and you can enter your model # and download the manual.
if you can not locate the answer in the book,
I think that this problem will be solved only by service!
A & E factory service is good and nation wide!
1-800-905-9505
They answer 24/7
Thank you Neil
PS.Please do not forget to give me a problem solved rating
Posted on Aug 24, 2008
Error Code E0 39 after replacing induction Control module. Our Range is Frigidaire CPCS3085LF, apparently the module is not talking to the panel. is there a fix?
Execute following sequence to force cooktop reconfiguration (Be sure the good ESEC20 UIB is installed into the cooktop)
1-Put all rotary control to the first detent position clockwise (1 o'clock).
2-Put all rotary control to the first detent position counterclockwise (11 o'clock). The system should then reconfigure, showing walking dashes on the cooking zones displays.
3-Put all rotary controls to "Off" position. There should be no more error code and the cooktop is ready for operation.
Frigidaire Range Stove Oven Surface Element Board 318329620 Frigidaire Range Stove Oven Oven Control Board 318347100
Jun 12, 2016 | Frigidaire Kitchen Ranges
How to remove the stove top on frigidaire stove model FFGS3025PS
IF you open the door to the stove, you will see screws under the lip of the cook top, take those out, check the back of the stove for screws and then lift the cook to. On some models you may have to remove the sides of the stove too.
Mar 13, 2016 | Frigidaire Stove/Oven/Range Cooktop -...
Where to purchase
http://www.consumerreports.org/cro/kitchen-ranges.htm
Freestanding electric smoothtop ranges are the big sellers, but you have more choices than ever. Our Ratings include smoothtop ranges, of course, but you'll also find induction and coil-top ranges in the electric category, along with gas, dual-fuel (gas cooktop, electric oven) and pro-style ranges. Choose a single oven or double-oven range, freestanding or slide-in. We test all of these. Consumer Reports offers you buying advice that you can trust. We provide unbiased Ratings and range reviews to help you choose the best range for your needs and budget, and use our buying guide to learn more about range types and features that matter most.
Ratings & recommended kitchen ranges
Electric smoothtop ranges (62)
Our Recommended ranges can do it all and, based on our survey of thousands of readers, do not have brand reliability issues. The Recommended ranges will bring pasta water to a fast boil, hold a big batch of spaghetti sauce or chili at a low simmer, a... More
Recommended electric smoothtop ranges
Electric smoothtop range Ratings
Electric induction ranges (9)
Recommended electric induction ranges
Electric induction range Ratings
Electric coil ranges (10)
Recommended electric coil ranges
Electric coil range Ratings
Gas ranges (43)
Do you love cooking with gas? Our Recommended gas and dual-fuel ranges (which pair a gas cooktop and electric oven) are top scoring and, based on our survey of thousands of readers, do not have brand reliability issues. They have large cooktop burner... More
Recommended gas ranges
Gas range Ratings
Pro-style ranges (34)
Pro-style ranges are stylish, stunning, and make a statement. But despite their high price, they aren't the best ranges we've tested. So before you swipe your credit card check our Ratings. You'll see the top brands, including Viking, Wolf, Thermador... More
Recommended pro-style ranges
Pro-style range Ratings
Jul 19, 2015 | Ovens
Oven doesn't let steam out
Thank you for your inquiry, friend!
From the information you have provided your Frigidaire range is not allowing steam to come out. If your vent is blocked it will not release the hot air or steam. Could you provide me with your model number? You can locate the serial tag (which lists your model number) on the door frame of the lower drawer. With the model number I can provide you further assistance. -Matt
Mar 15, 2015 | Frigidaire Stove/Oven/Range Cooktop -...
Open the cooktop on a frigidaire fef369cgsd range
Hi Gail Muster - Unfortunately from my research for this particular model it is not possible to open the cook-top without a certified service tech.
Jan 15, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire cookstove model no. fgf316wgta oven not getting hot enough
Hello - Does it reach the temperature and then back down, or does it take too long to get to your set temperature? Either you have a faulty element or a bad communication error with the main control board.
Sep 25, 2012 | Frigidaire Kitchen Ranges
Frigidiare electric range time bake and self cleaning
F3 The oven temperature sensor is open Check for open wire connection between EOC (Electronic Oven Control - Clock) and the oven temperature sensor. Replace sensor if no wiring problem. F3 Oven temperature sensor open Check oven temperature sensor, 1100 ohms F3 Oven temperature sensor open Replace oven temperature sensor F3 Oven temperature sensor is open (above 3000 ohms) Check resistance of oven temperature sensor, check for open wiring between oven temperature sensor and control
Nov 26, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire cooktop beeping f7
Hi Bobbiflower,
Happy to help you!
1-800-905-9505
They answer 24/7
Thank you Neil
Jul 19, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Frigidaire electric smoothtop range no longer working...
it sounds like a wire from the bottom element in the oven shorted.check the circuit breakers to see if there tripped,if so reset it and try the oven,let me know.
Dec 29, 2007 | Frigidaire FEF366 Electric Kitchen Range
Frigidaire PLEF398AC Electric Kitchen Range Logo
190 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
