Question about Coleman Heating & Cooling
Condensor fan runs backwards - Coleman Heating & Cooling
  • 41 Answers
If the fan is origanal and was running in the right direction than the new problem is the capacitor they can make the fan run the wrong way just replace the cap. most likly its a dual one so replace with a like unit dan
Posted on Jul 18, 2008
How does it matter which direction condensor fan turns
Yes. The fan is designed to draw air through the condensing unit to expel heat generated by compression and heat exchange in the refrigeration system. If the fan is running the wrong way, heat will not be disipated correctly and the unit will not operate efficiently. You could end up damaging the system.
Aug 18, 2014 | Dometic Rooftop RV Air Conditioner
The fan in the compressor for the HVAC unit quit running last night this morning after 2 attempts it started and ran fine , cooled form 76 to 72 in about 45 minutes, but when I tried to start it again the...
Replace the fan motor and capacitor. If you want to go the cheaper route, change the capacitor first and try to run the unit. The cap. is what gets the fan motor running on start up. Another way to test it is to manually turn the fan bade and while it's still turning, make sure your hands are clear of the blades and turn the condensor on. If the fan runs normally, then it's your fan capacitor.
Jul 02, 2011 | Amana Heating & Cooling
71122 ac model starts but the fan does not blow any air .shuts off within seconds.
which fan shuts down? Outside condensor fan? Or blower inside? If its the outside condensor fan motor you probably have a bad run capacitor or a bad condensor fan motor
Jul 26, 2009 | Heating & Cooling
How do I reverse the direction of the condenser fan motor?
If your condensor fan is running backwards you have a bad capacitor. Change capacitor and it will run the right direction. Russ
Jul 17, 2009 | Goodman Heating & Cooling
Uline combo unit. Condensor fan will not run and
You just answered your question. If no fan is running then the compressor will overheat and the compressor goes off on overload. Do you have the evaporator fan running? If yes then replace the condensor fan. Both fans will run at the same time. If the evap fan is not running then the unit must be in defrost. Since its a hotgas defrost the compressor will run.
Hope this helps
Jul 13, 2009 | U-Line Refrigerator Ice Maker
Air won't cool when the car is stopped on a 2004 chevy cavalier. car temp is normal
make sure electric coolant fan is running.if not check or replace fan relay.the coolant fan has to be running to cool down refrigerant in condensor.so refrigerant in condensor is cooled back down to high pressure liquid so it can go to evaporator.see ifcoolant fan not working.the AC is not going to cool.when you driving the condensor is cooling down from moving air when car is going.when you come to a stop.cooling fan suppose to be on so condensor gased can be cooled down.
Jul 10, 2009 | 2004 Chevrolet Cavalier
Frig stopped cooling. Bad condensor Fan Motor.
sounds like a bad thermostat,that tells unit when to kick on and off.
May 15, 2009 | Maytag Refrigerator Light Switch -...
Maytag Refigerator Condensor Fan not Running
yes it is your getting proper voltage, fan simply went bad, center mullkion was the unit trying to disperse the heat the fan was not able to!
Nov 01, 2008 | Maytag MZD2766GES Side by Side...
True TDD-1 beer kegerator condensor fan not running
cenck for volatge at wire harness and if you get the right volatge then repl condenser motor you can use a small portable fan just face it at compressor while you look for part and tha will kepp compressor from over heating and tripping the relay on it ok
Oct 15, 2008 | Refrigerators
Hot to the touch
Kathy, you probably have a condensor fan that failed. Remove the lower back panel behind the refrigerator. You will see the condensor, condensor fan and compressor. The condensor fan should be running any time the compressor is running. You might have something stopping the fan blades or the motor might be going bad itself. What you are describing is a classic example of a failed condensor fan motor. Catriver.
Apr 19, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Heating & Cooling Logo
67 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
