Question about E-Machines eMachines Desktop PC
Floppy error 40
I was putting in a card reader from another computer and disconnected the floppy to get the reader hooked up. When I plugged everything back in, and booted up, it stops on the floppy error 40. I have a similar computer and checked the connections. I plugged everything back correctly on the one I am working on. I get no light from the drive. When I go to Windows and look for the Drive A, it shows it in Explorer, but doesn't recognize it. I also went into the Bios. It shows the 1.44 drive. All the drive switches are set as they should be. What is going on? This computer was originally built by a one man pc company...did all of our computers.
  • 781 Answers
Check if the cable is in the correct way stripe toward the power plug
Posted on Jul 17, 2008
How do i put videos from download program to micro sd card
Windows Explorer and a SD Card Reader connected via USB or a SD Card reader in your computer where the old Floppy Drive would have gone.
micro sd card reader
Jan 09, 2016 | Tablets & eReaders
NTLDR compressed on a Compaq Presario SR105CL cant enter bios to set to boot
Step 1:
Which operating system ?
Computer is booting from a non-bootable source. Computer hard disk drive is not properly setup in BIOS. Corrupt NTLDR and NTDETECT.COM file. Misconfiguration with the boot.ini file. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT.32 New hard disk drive being added. Corrupt boot sector / master boot record. Seriously corrupted version of Windows 2000 or Windows XP. Loose or Faulty IDE/EIDE hard disk drive cable. Failing to enable USB keyboard support in the BIOS. Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD ROM First verify that no Floppy Diskette or CD is in the computer, unless you are attempting to boot from a diskette. b> Note: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it. If you have any card reader or flash reader make sure that no memory stick is inside the computer. Additionally disconnect all USB drives, cameras, ipods, iphones, etc. from the computer. If you are attempting to BOOT from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files or is corrupt. If you are attempting to install Windows XP or Windows 2000 and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive. Second, when the computer is booting you should receive the below prompt. Press any key to boot from the CD
Mar 10, 2013 | Compaq Presario sr1055cl PC Desktop
When i start my pc it display NTLDR file missing
Here ya go!
http://www.tinyempire.com/notes/ntldrismissing.htm
Jun 14, 2011 | Computers & Internet
Bert.green@health.sa.gov.auI have a Windows 7 system & wish to plu in a stash USB floppy reader but CD only reads in XP or 98?
If you have an external floppy reader, that is USB, it should be plug and play with Windows 7. What error did you get when you plugged it into the computer?
Jun 12, 2011 | IBM USB Portable Diskette Drive (05K9276)...
Memory card reading " card access error" when printing
is this a SDHC card? if so do u have a SDHC card reader?
Sep 17, 2009 | SanDisk Memory Media
Memory card error
Problem is most likely caused by uncompatible sd card size.
Jun 03, 2009 | Panasonic Lumix DMC-FS5 Digital Camera
Mitsumi 7 in 1 card reader
There are two cnnections required on the back of the card reader.
One is for the Floppy drive. It is flat and wide cable.
The other is a black cable with a smaller connector. This is a USB connector that needs to be plugged into your motherboard.
These USB connections are usually near the bottom right of the motherboard where you connect the power switch and LED lights. They usually have 9 pins. See this link and loko at the third picture so see what i'm talking about.
http://www.windowsdevcenter.com/pub/a/windows/2005/02/23/Build_Perfect_BudgetPC.html?page=3
If you don't have a USB connector on the motherboard.. you'll need to purchase an extension card or an adapter that will plug into a usb outlet on the front of back of your computer.
Best wishes...
Dec 08, 2008 | Mitsumi (FA404MBLACK) (fa404m/black)...
There is a white cable fixed to the drive that appears to have
The 7 pin connector is for the media card readers and needs to be plugged into a USB header on your motherboard. Not all motherboards have this header, so consult your motherboard manual. You may have to connect it in place of front USB connectors on your PC case.
The card reader will work without a separate power connection. The power connection is for the floppy drive only, and IS required for the drive to work. You should be able to find the appropriate connector on your power supply.
Nov 20, 2008 | BYTECC (BT144) External Floppy Drive
Mikomi card reader
you may have to check the manufacturers website for a vista compatible driver (as it seems that the generic driver is not working here.)
Oct 22, 2007 | Electronics - Others
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
