Question about Whirlpool Duet GHW9150P Front Load Washer
Water Leak We have a water leak from the two sides of the washer. We are not sure which cycle causes it to leak more, if any. We have the pedestal on the bottom which has had water in before. I don't think it has leaked from the front but you can see the water stains on the sides from the leak.
  • 2 more comments
  • dovev Jul 17, 2008
    I also have water leaking from the 2 sides of the machine. I do not have the pedestal. I just ran the cycle on delicate for the first time in a long time (usually I use normal) and leaked a lot more than usual. Some internet searches taught me that the delicate cycle uses a lot more water. This does not seem to be a door leak like a lot of people are complaining about - the water is coming out of the bottom of the machine. There is a lot more water on the left side than the right.The leak seems to happen while the machine is filling.up. Any guidance would be greatly appreciated.
  • tompowers535 Jul 29, 2008
    There was a big tear in the boot that I didn't notice until I unfolded it. I got one from Ebay and installed it myself in no time at all. Saved me a fortune in repair bills. THANKS.
  • deboggess May 11, 2010
    Lumpy, If there is any way you can tell me how to replace the grey boot around the door, and where to find this boot.I'd appreciate it
  • Toby Norton
    Toby Norton May 11, 2010
    Have you checked you boot (the grey rubber peice just inside the door way that seals it)for holes? They may be hard to see, you might even have to pull back on the flap to see the whole surface of the boot. Even if it's leaking on one side, there is a metal panel on the bottom that the water can run along and give you the wrong area to look at if the washer even has a minor amount of slope. Try removing the lower front panel? (3 1/4" screws or #20 torx bit screws depending on the manufacturing site) on the very bottom front of the panel (you can still access them even if you have a pedestal). This lets you see more clearly the inner workings of the washer and where the water is coming from. Have you tried removing the top of the machine? 3 1/4" or #20 torx screws along the back side of the top panel can be removed and pressure applied to the top to slide it slightly towards the rear and lift it up and out of the way. Can you see where you water has been coming from? Usually water without a rinse aid (like jet dry in your dishwasher) will leave a white film where it has run down the side, boot, strut or whatever. You may need to even run the machine to see it leak. Let me know if you can find any of these sources and if you need more help.
  • 246 Answers
While I do agree with eagle338 that water could be leaking from the fill hoses and the pump area, the rest of the instructions apply more for a top load Maytag washer, instead of the front load Whirlpool washer you reported.
Most likely you will have a hole in the front boot area (grey rubber seal around where the door seats). If you find such a leak, send me a note back and I'll write you up a how to to change it out.
The second most common source of leaks come from holes in the tub. This is the white outer part that holds most of the water in the machine. You will easily be able to see it when you remove the panel as listed above in the clarification instructions.
On rarer occasions, you can have something stuck in the fill tube that goes from the dispenser to the tub. Somehow small items become lodged in there. There will be a water inlet about the 10 o'clock position of your boot (grey rubber seal). Probe gently in there with your finger to see if a sock or similiar item got spun into this area.
Posted on Jul 23, 2008
  • 4,889 Answers
The leaks in a washing machine could be coming from many different places in the washer.
The first place you need to check is behind the washer, check the two fill hoses and the water mixing valve.
The next thing to do is to remove the front panel, set the washer on the regular cycle and turn it on to start filling.
Use a drop light and check all the hoses under the washer as the washer is filling. Make sure to keep your hands away from any moving parts.
If the hoses are ok, check the pump for leaks. When the bearings in the pump wear out, that is when the pump will get noisy and that could cause your Maytag top load washing machine water leaks.
Another place that the washer could leak water from, is the stem & seal on the holding tank. When washer leaks water from the stem & seal, the water leaks down the center of the transmission.
When the stem & seal need to be replace, the tub bearing has to be replace at the same time. This is an expensive repair if you have to pay someone to do it. If you do it yourself it will cost you about $110
Posted on Jul 17, 2008
Dishwasher leaking
When does it start to leak? I mean how much water goes in before the leak starts. I have a problem every once in awhile with mine leaking when the float in the bottom of the washer gets stuck and does not shut off the water. The way to check this is to locate the float, it is near the front left side, and push it up and down a few times to make sure it is not stuck. Try the washer again. If that is not the problem u could have a leak from the drain under the dishwasher. Sometimes the plastic can crack and cause a leak. Also check the discharge line and make sure it is not the problem.
Apr 20, 2014 | Whirlpool DU810SWPU 24" Full Console...
Found water in pedestal of frigidiare affinty washer
Good Afternoon K, thank you for your post!
Water in the pedestal could possibly be a sign of a water leakage coming from your washer. The leak may be occurring from underneath or the side(s) of your appliance. Therefore, either the drain pump/hose is loose or there is a faulty water valve. Regrettably, this is not a simple DIY job. I would strongly recommend connecting with a professional to narrow down the precise issue before investing in parts that may or may not be the root cause. You can often locate a qualified service provider through the manufacturer website.
Nov 23, 2013 | Frigidaire Affinity ATF7000E Front Load...
Dish washer starts ok then check water light comes on. if you reset the m/c it then starts ok but then the check water light comes on again.If you lightly shake machine from side to side the water starts...
This could be a slight water leak that causes the "anti-flood" system to kick in. This device is a polystireen float and a micro switch at the bottom of the washer. Once a small bit of water has leaked it causes the float to rise and activates the anti flood device that just puts the washer in pump out mode and nothing els. You could try tilting tha washer to get rid of the water at the base or dry it if you have the washer open (front or back). The cause is normaly a slight leak on a clamp or a very small hole in a pipe or can also be a rust speck inside the washer that causes the leak. You need to check the float to see if water leak is the problem.
Jul 19, 2011 | Dishwashers
My whirlpool duet is leaking from underneath between the washer and the pedestal. It appears to be during the drain cycle.
1. Find out where the leak is coming from. Does it leak constantly or during one part of the cycle?
A constant leak means the leak is in the valve where the hoses hook to the washer, the supply valves, or the lines to the washer from the water supply.
The other two options are when the washer is agitating or pumping the water out between cycles.
2. See if it leaks during both cycles and the test there would be to lift the lid just as it starts to drain and wait to see if the water stops leaking.
If it doesn't, then run the drain cycle to see if it gets worse or better.
Results may not be immediate as it would take a few minutes for whatever water there to finish dripping.
3. Wait until the water has been pumped out, lift the lid and check the drip again.
When the location of the leak has been determined, unless the washer has been frozen, most leaks can be fixed without parts and just using hand tools.
If you have an older, top load washer, the back or front will come off so you can observe where the leak is coming from.
WARNING. You are working with a moving, electrically hot machine that could flood.
You must take your time and not put your hand or hair in somewhere that can catch you.
You should not have to get into the upper control center, thus reducing the shock hazard.
4. Before turning the machine on, remove a cover. On some washers, there are two screws on the bottom L & R front corners that take the front panel loose.
Once the screws are removed, the front cover is hinged at the top and you simply pull the bottom away from the machine until it comes un-hooked, and set the cover aside.
There shouldn't be many exposed wires or ends, but a few. Don't touch the terminals or lay something metal in the machine that could fall on the terminals.
5. Take a flashlight, look for obvious leaks or better, water stains around nuts, hose clamps, etc.
Most likely you'll see some water residue here and there and that would be normal as a washer is wet. Look for puddles, long white streaks, calcium deposits.
Most likely, you won't find standing water, but some clues of where you should look when the machine is running.
Unless this leak is so obivous you can see what's wrong, you don't need to start it and you should repair the problem.
Once possible areas have been identified, you should start the machine as if you had a load in it and start to watch for the leak.
WARNING- Make sure you have no tools laying in the machine and you are out of the way. There are spinning parts and live wires once you turn the machine on.
Stay clear, and watch your hair and hands.
Once the machine is full and starts its cycle, look for leaks.
Let the machine do its cycle and as it goes into each part of the cycle, look for the leak.
Once you find a drip, stop the machine by lifting the lid or pulling out on the control knob, and now observe more closely.
Remember, water runs down; where it drips is not necessarily the place of origin.
6 Find the leak and make the needed adjustment (which will be all that is necessary most of the time).
If it is a part you need, get the make, model number and serial number of the washer and call an appliance parts dealer or repair service if you don't think you can repair the problem.
If the washing machine leaks water while it is filling, pull it away from the wall and see if the water drips from the inlet hoses or valves as the unit fills.
If it does, tighten the faucet packing nuts. Then, inspect the hoses and replace them if they have become cracked.
Also look for cracks in the casing of the inlet valves. Unplug the unit and lift the top to better inspect the valves.
Replace any valves that are cracked.
Valves usually crack when the hot water in the house water supply is heated to greater than 170 degrees.
They also crack if the house is left cold during the water and water is not drained from the unit. A cracked inlet nozzle can leak during fill.
The leaking water will drip down the outside of the tub and collect under the unit. Be sure that the hose connected to the inlet nozzle is tightly clamped.
Replace the nozzle if you find cracks in it.
If the leaking occurs at some time during the wash sequence other than when the machine is filling with water, unplug the unit, remove the back panel and examine the parts under the machine.
You can make a closer inspection by tipping the unit over onto it's front or side.
Tighten hose clamps that have become loose. If water is leaking from the pump, replace the pump.
The gasket between the tub and the splash guard may wear out and leak. To check the gasket, lift the top and remove the snubber and splash guard.
Replace a worn gasket. A hole in the bottom of the tub can develop.
If the hole is less than 1/4 inch in diameter, remove the agitator and basket and seal the hole.
If the hole is larger, replace the washing machine or tub.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
MAJOR leak in new JUST installed WCVH6800 front load washer
If you hear of a solution, let everyone know. Our machine did the same thing. From the research I have seen, GE makes **** machines and I will NEVER buy a GE product again.
Feb 07, 2010 | General Electric WCVH6800J Front Load...
How to remove drawer on pedestal
You need to remove the 2 screws holding the black rails on both sides of the drawer. Took us a while to figure this one out also.
Jan 01, 2010 | LG WM2487HWMA Front Load Stacked Washer /...
Water leaking at time the washer is being filled, not during wash cycle. Leak appears to be starting a bottom left side of the machine toward the front from the middle of the side. Observation does not...
you say water only leaks when it fills correct? am wondering if its the hose that feeds in to the washer
this would be from the inlet solenoids check the clamps in the machine.
Dec 02, 2009 | Kenmore HE2 Plus Front Load Washer
Whirlpool GHW9300PW water leak
The problem, I suspect, is the door bellow. This is the gray rubber boot on the door and front of the tub. The key is the fact that it only leaks during fill, or when adding water, and only leaks in the front center. The washer fills through a dispenser tube in the door bellow. Water runs through this tube and into the front portion of the tub. If you pull back the rubber folds of the bellow and look, you may have some rips or tears causing the water to drip out. If there are no obvious signs of wear causing the leak, the other two possibilities would be the dispenser tube not inserted through the bellow all the way. That is, the tube may have slipped behind the bellow a bit and may be causing water to drip BEHIND the bellow instead of through the fill port. Another cause would be if one of the clamps that hold the bellow in place has come loose and is not sealing to the front of the tub, or door frame properly. The following link explains how to replace a door bellow:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
I provide this link not only to give you advice in the event that your bellow needs replaced, but also to give you steps necessary to access the bellow in order the check or tighten the clamps. NOTE: An alternate method to checking the rear bellow clamp (located on the front of the tub) is to remove the washer top panel and attempt to access the 7mm clamp nut from the top. The method I have described in the link, however, offers the best access. NOTE: The clamp needs to be seated evenly around the entire perimeter of the tub facing and the clamp should be SNUG. DO NOT overtighten. This will cause damage to the clamp and/or tub facing.
If you require a replacement, you can order on line at appliancepartspros.com. Just type in your model number and look under the "Door and Latch Parts" heading for item number 5. Other items of interest are the rear bellow clamp, item 6 and the front bellow clamp, item 14. In most cases the clamps do not require replacement and can be reused. But, just in case you have to replace them, you now have them identified.
You can perform this repair on your own, if you like and save the cost of expensive labor charges. This is not a difficult repair, if you follow the instructions provided. This repair can usually cost $200 or more (cost of the part, plus the labor) if you have a repairman do it.
The problem could possibly have been caused by excessive vibration, but its hard to tell. Washers mounted on a pedestal can often have vibration problems if the washer is not mounted properly to the pedestal. Make sure all mounting bolts are installed that hold the washer to the pedestal. Make sure they are tight. Also, proper leveling can be an issue. DO NOT attempt to level the feet of the washer on a pedestal. Mount the washer and adjust the feet of the pedestal for proper leveling. Make sure the unit rests on a flat surface and is level front-to-back and side-to-side. A good foundation is also required to ensure the washer does not vibrate. If the flooring under these washers flex (even the slightest) they can cause vibration problems even if it is properly leveled. Flooring in an upstairs laundry room or a mobile home is usually the worst. Another item to consider is the pedestal itself. Look at the back of the pedestal. Is it open in the back, or does it have a back panel that encloses it? If the pedestal back is open, this can cause a condition known as "tin-canning", where the sides of the pedestal waffle in and out and begins to bounce when the washer spins. This can be overcome by purchasing a stiffener kit. Look at your pedestal and let me know if this may be the issue with yours. If so, I can provide you with a part number to order.
If you have further question, please let me know. I hope this helps you.
Feb 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Drops of water inside pedestal of washer.
Sounds like you have a leak around the door bellow somewhere, or your drain pump. The bellow is the rubber gray boot the seals around the wash tub and door. You will need to remove the bottom panel under the door to be sure. Remove the screws under the bottom edge of the panel. Once removed, the panel will drop down, then off. Inspect the washer with a load running. If the bellow leaks, a tell tale sign will be moisture showing up on the concrete counter weight in the front of the washer. Double check your drain pump and hoses as well. The pump is located directly under the wash tub in the front of the washer. The water tends to pool in the cabinet before it leaks out and drops into the pedestal drawer. If the bellow is leaking, make sure inspect it for rips and tears. You may just have a banding clamp that is loose. If the pump is leaking, make sure the clean out trap is on correctly and snug.
PS If you just purchased this washer and are experiencing problems already, this repair is covered under the one year limited warranty. Inspecting for a leak is not going to void the warranty. However, removing any major parts may. Just do an inspection to see if it is something obvious. If you suspect a part failure, get in touch with the retailer. If this was purchased from S**rs, they usually have a 30 day satisfaction guarantee. If you are not happy with the appliance, they should take it back.
Please let me know if you need further assistance.
Jun 01, 2008 | Whirlpool Washing Machines
I have purchased a Maytag washer mtw6300tqo and it leaked from the first day it arrived. It does not leak DURING the cycles but leaks profusely a few hours later. I have had service techs look at it and...
Is there water inside the tub after it starts leaking? If so the valve that lets the water into the machine could have a bad seal and overfilling the machine with water when it is not being used. Or one of your water hose seals could be leaking. Make sure the hoses are tight. Beyond that there is nothing to cause a profuse amount of water when the machine is not being used.
Apr 26, 2008 | Maytag Dependable Care LAT9206
Whirlpool Duet GHW9150P Front Load Washer Logo
321 people viewed this question
Dan Webster
Dan Webster
Sal De
