Question about Cobra GPS
Nav one 2500 won't come on only white strip then it locks up tryed master restart many times on help.
  • herbsmith Jul 17, 2008
    not have sd card tryed update couldnot load.
    what do i have to do to get replaced
    Scholar:
  • 101 Answers
Follow the steps on this page to write new software to your GPS. If that doesn't work, it is hardware failure and has to be replaced.
Posted on Jul 17, 2008
  • Jerrod J
    Jerrod J Jul 17, 2008
    Also, if you are reading data from an SD card, see if the unit locks up without the SD card inserted into the unit. If it doesnt lock up with the SD card removed, then the card probably has corrupt data. If that's true, I will give you instructions to (attempt to) repair the data on the card.
  • Jerrod J
    Depending on where you live, you can contact Cobra directly and see if you can get an RMA authorization for your gps. Alternatively, you can take it back where you bought it (if it's under warranty). If it is out of warranty you may be out of luck.
2003 GMC HD 2500 Brakes are locking up while driving. I have had to loosen the brake line at the master cylinder to be able to move the truck. This is the 3rd time this has happened. HELP
sounds like the serov on the brake system has gone could be the abs side or the master cylinder its self. with engine running can you hear a hissing sound from the master cylinder. ??
Oct 15, 2013 | Chevrolet Cars & Trucks
When i try to unlock my lock or restart it it won;t take the code i wanted
Hi what is your mobile model? if its nokia then trydefault code "0000" or "1234" and if it does not work make a try to reset your mobile by master reset code..try Wickedunlock to get reset code to reset your mobile
Jan 22, 2012 | Cell Phones
I have a riso 4200 and a 4900 that have been setting for a while, when I try to make a master it doesn't make all the copy it has white strips around the ink drum. How do I clean the drum so I can use them...
Since your machine doesn't used long time. This causes the consistency of the ink very loose and it will not go into the drum. Just replace with new ink and try to make several print by making several master and the pump unit will start filling it up. If you know how to go to service mode just use testmode 101. This will help to pump the ink inside by using just one cut of master.
Dec 31, 2009 | Office Equipment & Supplies
Door locks on Ford Expedition stuck
Look under your steering wheel right under the dash. There should be a small white strip with 5 numbers. This is your master code for your vehicle. If you bought the car used and they give you a code, they could have made their own code, but the master will override it. If this don't help, the module for the doors may be going bad.
Dec 15, 2009 | 2000 Ford Expedition
2003 Dodge Ram 2500- window master switch
Alot of times these switches get water from the rain coming in intoo them causing the contacts to short or not make contact at all, unfortunately they are not servicable but you may want to try spraying some electrical cleaner into the switch working the button at the same time this may help
Jul 02, 2009 | Dodge Ram 2500 Cars & Trucks
Need master reset code for vdo dayton sat nav
hi
menu > settings > security > change lock code > apply master code in place of lock code and press ok > enter new code what you want
Apr 17, 2009 | VDO Dayton MS5000 GPS Receiver
Trying to wire nav man gps imput into a 585fcv furuno echo sounder,i no the white wire of the nav man nmea output ,but what coulour wire is the imput for the 585,white and blue.but which one is the signal...
white and blue is correct, white is signal, but be aware that manufacturers screw this up all the time, so try it both ways, and look for pulsing data on digital meter measuring 12V, should see meter jump rhythmically, from 0 to 4-12V. Confirm presence of data to maintain sanity
Aug 17, 2008 | Furuno FCV-582L GPS Receiver
Master vs. repeater confusion
The master/repeater selection is for the purpose of determining which display is in control of the waypoint and route database.
Turn on both units and let them boot up. Do not answer the master/repeater question until both are on. Then press "Set as master" on the preferred one.
The units remember individually if they were set as a master or repeater the last time they were on. If they are powering up to find themselves in a different configuration than they were previously in, that will prompt the whole master/repeater thing to happen.
Sep 18, 2007 | Raymarine E120 GPS Receiver
GPS Logo
223 people viewed this question
Top Cobra GPS Experts
Steve
TO Lady
Are you a Cobra GPS Expert? Answer questions, earn points and help others
