Question about Philips 60P8341 60" Rear Projection Television
I need help on fixing my tv i need to find out how to dind the buttons on my tv they r broke and i need to know how and i where i can get them fixed
  • Philips Master
  • 8,617 Answers
You can get replacement buttons along with the pcb board that go with them at the following link.
http://servicemanuals.vstore.ca/
Posted on Jul 25, 2008
Cable connection broke
Need to know where it broke. If it is the F connector that is attached to the tv then you need to take it apart to fix this. It will be soldered in so you will have to know how to do that or get someone that can. Once you have it out it is a very easy fix.
Mar 12, 2016 | Vizio Televison & Video
How do i fixed the throttle actuator on ford five hundred
First off what's the problem with it , is it in limp mode or limited power or reduced power mode ? If so, need to hook up diagnostic scan tool and see what codes are stored in the ( PCM ) . powertrain control module. What year 2006 ?
Dec 17, 2014 | Ford Cars & Trucks
What would be the solution if this tv wont turn on?
It seems there is hardware problem so i guess you need to take it to service center for the same, as there is no easy fix for the same.
Jun 02, 2014 | Haier HL32R 32 in. LCD TV
Emerson TV SN: 011-40401078 Model TC1379 The power switch came loose and fell inside. I don't know if it broke or came apart. I only found the plastic piece and don't know how it attaches...
Well somtimes buttons break off of tv's because that they are old so its not worth fixing an old tv
now a days most people just buy a new one then instead of fixing the old one. Or you could find someone that fixes old tv's too. To find an old tv like the phiilps one we used to have you would probally need to go to an antique store or and a pawn shop or a secondhand store or a garage sale then. Or the dump because sometimes people put things in the dump like CRT tv's to get rid of them then.
Aug 22, 2011 | Emerson TC1351 13" TV
The kids broke my tv
The only way to fix it is to open the tv up and relocate the button also check that the cables are plugged in properly hopefully no clips have been broken, Make sure you unplug the tv first.
Sep 13, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
TV (RCA model F32705) stuck on one channel
Usually the fix for that on a RCA or GE TV is to go into the menu (the button in on the front of the TV) and find channel settings and let the TV autoprogram itself. This should fix the issue.
Apr 25, 2007 | RCA F32705 32" TV
Shutter button repair
hi it depends on where it broke and if...(the button) if it just fell then u can just take the new button a shove it in untill theres a CLICK if its broke then u will need to pull out the rest and then shove it in DO NOT TRY TO OPEN THE CAMREA IF U DONT KNOW HOW!! you will brake the pins inside when u will and then it will cost u as a new cam good luck windman
Feb 14, 2006 | Canon PowerShot SD200 / IXUS 30 Digital...
Philips 60P8341 60" Rear Projection Television Logo
23 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
