Question about Haier HDP18PA Stainless Steel Free-Standing Dishwasher
Just got the Haier hdt18pa portable dishwasher
I thoght I would be placeing the water inlet tube to the sink by simply screwing it on to the spout part of the faucet, where the water comes out. The manual shows that it is to be hooked to a faucet that has a hot and cold knob. Mine has the one handle on top and I have no clue how to hook this thing up. The manual doesn't give a lot of instructions.
  • msherwin May 11, 2010
    I tried Menard, Home Depot , Plumbing supply stores, they said the the adapter will have to come from Haire
You have to buy an adapter for the faucet that allows the hose to hook up. You an get it at any hardware store. It's easier to get a dishwasher installation kit and just hook it up permanently.
Posted on Aug 05, 2008
Haier dishwasher did not pump out
I had problem like this...one day the washer stopped, still half-full of water. Then, we tried to run again and we could hear the little engine working but it wouldn't let water in OR out, just error beaps.
Then my boyfriend took off the back and gently tapped the water inlet valve solenoid with his screwdriver, and now it works! Starting FILLING actually, not draining, but completed a full cycle finally!
Must have shaken loose a blockage in the mechanics in that solenoid, probably have to replace before long. But for now, success!
Here is a website that helps: http://www.searspartsdirect.com/Haier/dishwasher/model-Esd301-repair/categories/dishwasher-repair/symptom/dish004.html
(See "REPLACE WATER INLET VALVE", half-way down page)
Aug 19, 2013 | Haier 17 in. HDT18PA Built-In Dishwasher
My dishwasher won't drain. It makes a grinding sound and won't drain the water out after the cycles. Any thought's?
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 05, 2010 | Haier 17 in. HDT18PA Built-In Dishwasher
HDT 18PA 17 in. Haier Dishwasher... leaking at bottom of door. Need a new gasket. How do I order one and from whom do I order?
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Mar 03, 2010 | Haier 17 in. HDT18PA Built-In Dishwasher
Dishwsher wont drain. never happened before. do not use dishwasher very often.
I would first check where the drain hose from the dishwasher connects to the drain stub under the sink. Remove the hose from under the sink and place it into a bucket. Close the dishwasher door and cancel the cycle to put the dishwasher in a drain cycle. Listen for the drain pump to activate. If water comes out of the hose check the stub where the hose connects under the sink with a screw driver to make sure the spout is clear of debris. If no water comes out of the hose, empty the dishwasher by hand using a plastic cup and when empty remove the hose at the pump under the dishwasher and check to see if there is any debris at this point. Make sure hose is clear from the dishwasher pump to the drain stub under the sink. You will need to place a towel or two on the floor as water left in the bottom of the dishwasher will come out when you remove the hoses. If still no water comes out you may have to disassemble the bump assembly. Not knowing what make and model you have I can't help you past this point.
I hope this is of some help.
Jan 25, 2010 | Dishwashers
There seems to be ice stuck in the little slide to
the best way to defrost this is use a blow dryer in the comparment and th a towel or shop vac to soak up the water
Sep 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Need service manual for HAIER HDT18PA countertop dishwasher
Click the link, then click the picture of the manual on the page, it will begin loading the manual.
HDT18PA Haier Table Top Dishwasher
Apr 10, 2009 | Haier 17 in. HDT18PA Built-In Dishwasher
Dishwasher drains into sink
As background, the dirty water typically goes from the dishwasher to a small tube within a tube, and that goes to the disposal. This ensures that your dishwasher does not back up in the event of a clog.
The problem is likely that the tube that links the thing you see next to your faucet to the disposal is either totally or, more likely, partially blocked.
I recommend taking the entire flex pipe off and inspecting. In my case it was about 80% blocked, so a simple test whereby water was pored down failed to show the issue.
Once I took it apart and gave the tube a plumbing version of an angioplasty all was well.
Dec 31, 2007 | Tappan 18 in. MDR251RE Built-in Dishwasher
Hose sizes
compactappliance.com has stats on the models they sell.   I think this one's hoses were 4 feet long.
Jun 27, 2007 | Haier 17 in. HDT18PA Built-In Dishwasher
Haier HDP18PA Stainless Steel Free-Standing Dishwasher Logo
374 people viewed this question
Top Haier Dishwashers Experts
Tim Doolittle
Tim Doolittle
Melissa Martin
Melissa Martin
Are you a Haier Dishwasher Expert? Answer questions, earn points and help others
