Bought a leimo hair laser from USA adapter runs off 110 volts. bought another adapter in australia to run off 240 volts. charged for 20 hours but charger light still red. out put of australian adapter is the same and right polarity
SOURCE: When charger is plugged, amber light blinks once and then nothing? E125 not working at all!
The Casio PDAs will quit charging very quickly if the battery is very, very discharged. If you continue to remove and re-insert the charger into the PDA's power socket, the recharging cycle will last longer and longer until finally the stupid thing will fully recharge its battery.
I have two Casio PDA's and three batteries that were recovered after a bit of tedious struggle to force the charging cycle to complete.
Posted on Nov 12, 2007
  • 518 Answers
SOURCE: power conversion
If you have 110 - 120 volts AC at 60Hz, then the mixer must be bad. Unless 50 Watts isn't enough. Does the voltage drop when you plug in the Mixer to the convertor?
Geno
Posted on Mar 05, 2008
Vegggie Boy
  • 28 Answers
SOURCE: Treo 680 charging light flashes red when disconnected from charger
Have you activated phone yet? When phone is activated and in service it flashes green. It's hard to believe it would flash green without a SIM card, as there is no service...unless AT&T is providing emergency service only and you're getting a flashing green which means you're in range of their towers.
Posted on Jun 14, 2008
  • 13 Answers
SOURCE: low batt
Hi car3r0,
You're correct. It doesn't sounds like the Dash is charging. At the very least, it doesn't sound like the Dash is charging properly. If you've got a T-Mobile store near by, you might want to stop by and see what they have to say.
(Note: the Dash battery has a tendency to go bad after about 12-14 months, so it may be as simple as a battery replacement. Worst case scenario, it could be a dead charging port on the device.)
Let us know how things go!
Thanks,
Jonathan
Posted on Oct 03, 2008
SOURCE: really low battery
Get a new battery. or go to a t-mobile store and asks them if you could test a different battery in your phone.
Posted on Oct 10, 2008
What spect of voltage conventer transfer to convent the Voltage 110 to the 220-240 V printer??
110 volt to 220 power converter 220 volt to 110 voltage ...
www.dvdoverseas.com/voltage_converters.htm
110-220 volt voltage converter power transformer 220 volt voltage converters 240 ...run on 120 volt 60 cycles (60hz) and most of the worlds run on 220/240 volt ...
Oct 07, 2015 | Canon F151300 LBP 3100 Mono Laser Printer...
Solis 365 royal hair vac I was wondering if it was possible to use this product in australia due to the voltage difference and if there is a product made to suit australian voltage or if an adaptor...
There are products called Step Up transformers/Step Down (Voltage Converters) that can be used. We use these For our 220VAC Australian manufactured lasers when we need to run them in a Dr.'s office that only has US 110VAC.
Info from a website:
Electrical voltage in USA is 110 voltwhereas; the voltage in most of the foreign countries is 220V to 240 volt. A voltage converter / transformer, also known as power converter are usedto convert electricity coming out of the wall to match the voltage of yourdevice. These Voltage transformers or converters can be used safely withRefrigerators, Microwaves, Juicers, Blenders, Coffee makers, Power Tools,Stereo Systems, TV's, Video Games, DVDs, Hair dryers, Chargers, computersand other electronics when travelling abroad..
Remember to leave at least a 100-percent margin for power surges/spikewhen buying a transformer. Some items, such as Televisions, computermonitors spike when you turn them on. For these products you need to buy avoltage converter transformer that is at least 3 times the items capacity.Power tools, laser printers and heating appliances like coffee makers,toasters, microwaves, Halogen, Fluorescent bulbs you must leave a marginof 3-4 times.
Voltage transformers are made to convert single phase 110 or 220 volt.American 220 Volt consists of 2 phase of 110 Volt and European 220 Voltconsists of 1 phase of 220 volt.
Volts x Amps = Watts (i.e. 110V x 0.5 AMPS = 55W). Please make sure not torun any appliance with higher wattage then voltage transformer's wattage.This might damage both: your appliance and the transformer!
I hope this helps.
PHmaddnes Transformer Purchase Guide
May 06, 2014 | Cell Phones
Philips norelco G370 charger not working..
The prob is simple, the imported ones have adapters made for 110 Volts whereas in India the standard is 240, so ur adapter has simply 'shot out'. I faced the same prob and if u know little electrical stuff, fixing it is a piece of cake. first ull have to buy one of those adapters which have an adjustable output voltage, i found only one online on rediff.
http://shopping.rediff.com/product/all-in-1-power-adaptor/10300314
but i bought mine from kerala for 90bucks. then all u hav to do is cut the pins of both ur new and old adapter, and join the old original pin to ur new adapter, seal the joint with tape, adjust the voltage on the adapter to 1.5V and ur good to go :D
I did this just today and the trimmer is back-and-running!. XD
Hope it helps since this will settle it for 200 bucks flat and since a new original philips charger costs over 1k... :
Jan 28, 2013 | Philips G370 Hair Trimmer
I just bought KitchenAid Artisan Stand Mixer KSM150PS with 110v and 60Hz online and received it today and realised I cannot use it on australia. Can I use transformer which I can get here to convert 110V...
You need a Step Down Voltage Converter (also called a Voltage Transformer)
which steps down 240, 230, 220 volts to 110 volts and
allows you to use 110 volts Devices from USA in 220 v / 230 v / 240 v Countries
Aug 10, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Is a dtxplorer bought in the USA set for 110 volts and therefore do you need to get a converter to use it in a 220/240 volt country?
Yes, the adapter takes 120 volts... Best way might be to get a 220 to 110 trnasformer converter then you can run other stuff as well... Get one of the step down transformers in first column... the 100 watt one would be more than adequate, but for future things you might want higher rating.
http://www.world-import.com/transformers.htm
Apr 06, 2011 | Yamaha DTXplorer 5 Electronic Drum Set
I bought an AOC 2036s monitor in the usa, came back to australia to connect it to my laptop as a second screen. yet it wont seem to work, i keep getting no signal. the box saids compatible with XP, yet...
USA mains equipment operate on 110 volts. Unless the AOC monitor can operate on multi voltages ie 110 to 240 volts, when you connect 110 voltage equipment into 240 volts mains in Australia you most likely will damage the AOC monitor.
To operate equipment that has been designed for 110 volts, you need to purchase a step down transformer from 240 to 110 volts that has suitable wattage rating for the AOC monitor.
Feb 24, 2011 | Computers & Internet
I cant plug my 120v input vamp2 power adapter into a 110v output voltage regulator its dont works
I don't understand why you are plugging this into a 110 volt regulator.. If by chance you are trying to run this from 220 volt power, you DO NOT use a regulator or a converter intended to run hair driers and appliances. You need to use a step-down transformer from 220 to 110 or 240 to 120.
The V\Amp2 is a switching regulator and it will NOT like to be run from another switching regulator such as found in those cheap appliance type convertors.
Here is the type you need: http://www.world-import.com/tc-100a.htm
Jan 07, 2011 | Behringer VAmp 2 Power Supply
Philips norelco G370 charger Not working(Light is not glowing, Power socket is working for other charging) what should be the output Voltage , Mine is 230V in India . Should i use any adapter, It was...
Dear Mr Selvaraj,
We regret the inconvenience faced.
We would request you to share your contact details with us in order to get this issue resolved for you.
Thanks for your patience.
Regards
Philips Consumer Care
1800 102 2929
1860 180 1111
Dec 02, 2010 | Philips G370 Hair Trimmer
I recently purchased the G370 Norelco hair trimmer, I used it only once after a 4 hour recharge, then when came the time to recharge it again, the light on the charger didnt glow and the machine wasnt...
S.O.B! Just bought the bastard 3 weeks ago after I had another one before it that didn't last even a month. THEY WON'T CHARGE A BIT!!! The damn light glows as if it's charging but the device never turns back on. This damn company can GO TO HELL!!
Apr 18, 2010 | Philips G370 Hair Trimmer
Charging Canadian battery tools in Europe
http://www.220converters.com/ GO TO THIS WEB SITE AND YOU CAN FIND ALL THE CONVERTERS YOU NEED ALSO READ THE NOTES ABOUT WHAT YOU NEED TO TAKE WITH YOU BATTERY AND POWER WISE . HAPPY TRAVELS AND HAVE A GOOD TRIP
Jan 12, 2009 | Dewalt 7.2-18.0 Volt One Hour Charger
Computers & Internet Logo
101 people viewed this question
David Payne
David Payne
