Question about Garmin GPS
After down loading the mape file and extracting it then following their directions it fails to install in my Garman nuvi 680
The Garmin is being replaced.. it was the hardware problem..
Posted on Jul 17, 2008
Nuvi 680 screen is frozen
I would suggest you reset the unit, if that doesn't solve the problem, then you will have to update your nuvi.
Frozen nuvi is as result of software problem. So you either reset or update. Update helps to reinstall the operating system file of the nuvi, thereby, putting it back to order.
Performing a Standard Reset
1. Slide the power switch all the way to the left (with the Nuvi's screen facing you).
2. Hold the switch in the position for at least eight seconds.
3. Push the switch to the right to power the Nuvi back on.
Performing a Factory Reset
1. Turn your Nuvi off by sliding the power switch to the left.
2. Press your finger against the bottom right corner of the touchscreen. Hold your finger in this position.
3. Slide the power switch to the right to turn the Nuvi back on. Continue to hold you finger against the screen until you see the factory reset prompt. Tap "Yes" to perform the factory reset.
Follow the procedures below on how to update your garmin nuvi:
1. Plug one end of the USB cable into your GPS and the other end into your desktop or laptop computer. The GPS device will load the appropriate driver automatically, and a message on your GPS tells you that it is connected to your computer via USB.
2. Open your Internet browser of choice and type in the following web addres: "http://www8.garmin.com/support/collection.jsp?product=999-99999-27 "
3. Download the appropriate version of the software for your computer (Windows or Apple) and Install the WebUpdater by following the wizard (accept defaults).
4. Click "Start," "Programs," "Garmin" and " WebUpdater" to update your firmware and your maps. Periodically check and make sure your software is current.
Please let me know if non of the above solves your problem so that I can help you further.
Good luck.
Nov 03, 2011 | Garmin Nuvi 680 GPS Receiver
My nuvi 660 turns on but displays "loading maps"
The problem is that the nuvi 660 gps receiver is jammed and needs to be reformatted.
What you have to do is to disconnect the gps, and connect it to a computer, then format it.
After formatting it, you download the self extracting archive files for your nuvi on to your hard drive, then connect your nuvi to a free USB port on your PC interface cable and allow your nuvi to initialize and enter USB mode, Unzip the files by running the downloaded executable files, then follow the instruction provided by the launched update application on your PC.
Then install it back in your car and turn it on, it will work once again.
Take care and good luck
i hope this helps?
Dec 05, 2010 | Garmin Nuvi 660 GPS Receiver
How do I get to the place to register my new garman?
To register your Garmin nuvi
  1. Connect the satnav to your computer.
  2. Go to www.garmin.com
  3. Select your country from the drop-down list
  4. Click the myGarmin tab
  5. Click "Register your Garmin Product" and follow the prompts.
Nov 17, 2010 | Garmin nuvi 1300 Car GPS Receiver
How do I reset the Garmin 1300t? It is locked up
turn it off and unplug it from power, then press and hold the lower right corner of the screen, then power it on. when it comes on release the power button and you will see a message similar to: do you really want to erase all your data? YES, release your finger when you see that message, then follow the on screen prompts.
bill
Oct 14, 2009 | Garmin nuvi 1300 Car GPS Receiver
Freezes on the loading maps message
Hook up your Nuvi to your computer and go to the Garmin site and download the latest driver software to the 680.
Jul 08, 2009 | Garmin Nuvi 680 GPS Receiver
No Maps on My GARMIN nuvi 200W
I bought the nuvi 200w and when I registered the unit it said that there was an updated map available so I down loaded and installed it. When I turned the unit on, it said no detailed maps available and would not work. I called garmin and they said that to fix it I had to hook the nuvi up to my computer and start>my computer>nuvi>garmin there is a file called gmapprom.img (shows over 1,000,000 mb) delete this file. Open all programs>garmin>mapsource highlight the areas on the map that you want and click on the add to device icon. After doing this, my nuvi is working fine. The explanation was that the original file had files for Canada that were not unlocked. Try this and good luck!
Mar 14, 2009 | Garmin nuvi 200W GPS Receiver
Garmin bluetooth won't disconnect call
Solution below works for NUVI660 as well; ignore everything after step 6 but DO reboot and delete previously existing connections.
good luck
All,
I was having the same problem with my Curve and Nuvi 680. What has fixed this for me is downgrading the Bluetooth firmware version on the Nuvi itself. I was running version 3.0 (you can check your version by going to Settings -> System -> About on the Nuvi) -- I had success after downgrading to version 2.4.
It's a bit of a convoluted process, but here is the procedure I followed:
1. Download the old Nuvi BT firmware from the Garmin Italy website:
http://www.garmin.it/files/FileBluetooth.zip
2. Connect your Nuvi to your PC.
3. Go into the X:GarminRemoteSW and look for a file called 006B055301.GCD (where X: is your Nuvi drive)
4. Back up that file to your
computer, and delete it from the Nuvi.
5. Extract the file in the zip downloaded in step 1 to the X:GarminRemoteSW directory
6. Disconnect your Nuvi from your computer, and let it
reboot
7. Click on "View Map," then touch the "Speed" in the lower left corner.
8. You should have the "Dashboard" view up. Touch and hold the "Moving Average" box for ~15 seconds until the diagnostic screen appears.
9. Press the "next" button until you arrive at the "Bluetooth Status" screen (5-6 screens in)
10. Click "Updt PR" and then click "Yes"
11. Reboot the Nuvi, delete the existing bluetooth pairing, and attempt to re-pair with your BlackBerry.
Seems to work perfectly now -- please let me know if you have any questions. Good luck!
Feb 11, 2009 | Garmin nuvi 265 Car GPS Receiver
Garmin Nuvi 205 keeps saying no maps available ???
This is easy. You have to run your software, select the maps tap and then transfer maps to the device. Chances are good you uploaded a 2009 map on top of the 2008 map. The updater doesn't delete maps.
Your unl file only has one key, you have two maps loaded. Simple go into the garmin directory and delete the map file and the mapsupp file. You can easily find them because they are greater than 500 mb.
Then run mapinstall (google for the file). This will install your most current map to the Nuvi. You are back in business.
Dec 13, 2008 | Garmin nuvi 205 GPS Receiver
Garman 350
Do a hard reset on your GPS.
  1. Start with the device turned off and unplugged from power.
  2. Power on the device.
  3. When the first copyright screen appears press and hold the lower right hand corner of the display portion of the touchscreen.
Apr 02, 2017 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 680 download updates?
not sure if this link will help you but have a look.
how to download updates Garmin Nuvi 680 Google Search
Oct 31, 2017 | GPS
GPS Logo
80 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
