Baby Gear Logo
Posted on Jul 16, 2008
Travel cot by chicco
I recently bought a travel cot made by chicco and it's next to impossible to open it. You open the short ends first by pulling them upwards and they click into position, but when it comes to putting the other two side into position they won't go. Help!
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 21, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
648
Points
7
The secret to open that chicco travel cot is to make sure while opening the upper clips make sure the base is still closed. its a safety thing. then open the base.
2helpful
2answers
Manual instructions for kinderkraft joy travel cot
Hello, Jean -
I only found the video instructions for opening and closing the KinderKraft Joy baby cot (crib) here:
https://kinderkraft.com/en/products/baby-cots/joy2
Scroll down that page to the Joy manual link for the video (with the right facing "play" triangle / arrow.) Click or tap on the "play" icon to run the video.
I suggest you view the video (more than once) and make notes of the steps to follow, so you can keep the handwritten notes with the cot for future reference.
I tried the Support Center link at the bottom of the web page, but it is inoperative.
Best wishes.
How do i collapse hauk travel cot the buttons dont seem to respond to pressing ?
push both buttons in at same time lift up then pull handle that's in bottom of cot
Feb 26, 2015 • Baby Gear
Silver cross dreamsleeper travel cot - how do I fold it up I have lost instructions
Hi there, found this website on a search engine:-
http://www.madeformums.com/reviews/cots-night-time-and-nursery/travel-cots-and-beds/silver-cross-dream-sleeper/review/370.html
Which had the following in the article:-
Folding the Dream Sleeper away is a fairly standard process: press the button in the centre of the sides and ends, pull the lever in the base (this is a little like opening a giant drinks can) and fold everything together so it can be enclosed by the mattress and stowed in the carry bag.
Hope that's what you were looking for!
(I think, if you feel along the top rail, there should be a big clip in the middle of aech rail, try lifting and squeezing, then twisting inwards of the clip - this is a usual method of locating and locking / unlocking the hinges). Pull the mattress out first, there should be a loop to pull the base up too).
From a caring 'daddy' who had trouble himself with something similar!
1helpful
I cant get the ends of the Redkite travel cot to stay straight
hi this could help as most travel cots are the same from 4 mins onwards
http://www.youtube.com/user/Kiddicare#p/search/5/CHXqMSVsUtQ
Nov 02, 2010 • Toys
How do you open a chicco travel system stroller
I have a chicco trio envoy. On my system there are little hooks just below each handle. you pull these hooks up towards the top of the handle while pushing the bar at the back with your foot (like you would a normal stroller). I hope this is of some assistance!
4helpful
2answers
Need raincover for chicco liteway stroller
If you email this addres [email protected] you will be able to purchase this part.
I hope this helps.
How do you put chicco travel system pushchair down
This is relatively straight forward.
Stand behind the pram, pull both triggers on the handles, and then pull the handle loop at the back of the pram which will then enable you to push the pram dowards and fold.
Practice a few times and you will be perfect within a very short time.
I hope this helps.
5helpful
How to put up a TCM Hauck Travel cot....there are no instructions with the cot. It says to press the button but the ends don't seem to want to stay up! Help
With most travel cots, there is a mattress which is also used to cover the cot when folded up, these also usually have the intructions printed on them too.
With most models, you must pull up the horizontal sides in a certain order and you will probably find a lock right in the middle of the cot base (this is normally covered once the mattress is on). Although this is not a complete solution, I hope that this goes someway to helping you resolve your problem.
Sep 20, 2009 • Baby Gear
Chicco C1
hi no it is only forward facing if u have the carry cot or carseat they are rear facing hope this helps
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
ZJ Limited
ZJ Limited
john h
Are you a Baby Gear Expert? Answer questions, earn points and help others
