Need someone whi can fix cranks and other moveable parts of metal casement windows from the 1950s.
    Problem Solver:
  • 63 Answers
PC desktops
Posted on Jul 17, 2008
Why does my car make weird sound when i try to crank it
Most of the used mechanical part of a vehicle make sound!! but when the sound are weird, your car may have a damage in the crankshaft metal, or on the flywhell, some teeth are bad,
If the sound is at the beginning of the crank are the flywhell or the starter motor teeth.
But if the sound is at the runing time are the crankshaft metals...
some little pieces around the supports of the crankshaft
Hurry up to service, the engine need fixed in both cases, flywhell or crankshaft are vitaly to operate.
May 03, 2014 | 1995 Toyota Camry
Honda prelude wont start
You need to go though the basics.
Is it cranking Yes/No
If its an auto is the park switch working to crank up?
Is they a spark at a plug lead. Don't hold it with your hands, the shock can kill. Put a new plug in a lead, lay it on a metal part of the engine, have someone crank up while you watch. Should be a good blue spark. If not, you will have to get expert tech help.
Why did you change the battery and starter?
Don't change parts on a whim without knowing the problem.
When was it last serviced?
How long has it gone without full engine service? Should be 12000 max.
Nov 06, 2013 | Vehicle Parts & Accessories
Please anyone suggest me is it appropriate to choose Casement doors and windows?
The Casement doors and windows are best to to use as they are made up of UPVC which is a cost effective and long lasting. Casement doors and windows are resistant to heat, offer you proper ventilation and they are not prone to termites. So, don't think much, just go 4 dat. If you like more casement doors and design visit
Oct 26, 2013 | Heating & Cooling
Kodak m67 8mm movie projector struck in rev lever can be move to forward but miss run backwards
it is hard to explain but there is a metal pin on one of the mechanisms it can become bent out of place. you need to remove it and heat it up and put back straight. dont try to bend it straight as it will snap or the pin will come out of the metal part.
Oct 13, 2013 | Kodak 1950s/60s Brownie 500 8mm Movie...
Why are double glazed windows rated so highly?
They are made of two panes of glass separated by argon gas. They are good insulators and protect window installations from condensation.
Aug 07, 2013 | Haier 9800BTU Slider/ Casement Window A/C
Door panel removal
To remove the window crank slip a small standard screwdriver behind where the crank mounts to the door.There is a small spring like c-clip pop the clip off and cran Window Handle Operation:
00457_window_handles.jpgReplacement handle for cranking or rolling a side or rear window up or down. It slides over the window crankshaft and uses splines to match the window crank shaft splines as to avoid slippage. It's held in place with a simple spring clip and come in a variety of styles and colors.k will come off.
Jun 27, 2012 | 1994 Suzuki Swift
Casement windows, that crank outward, stick. This makes some of them impossible to close completely without pushing them in from the outside.
Don't know why this is posed in Chainsaws, but here goes. Check if the windows are 'square', meaning that there are good even gaps all around the window when it is closed. If not, the window may need to get shimmed to make it 'square' again. This is especially a problem on casement windows for bay or bow windows as they hang over the edge of the house. When properly installed, the weight of the window frame is tied into the attic rafters (on a ranch house) by wire cable so the window will not sag over time. If there is a framing support under a bay/bow window, it may need to be adjusted to bring the window back to square.
Aug 29, 2011 | Garden
N AND D came off
The N and D are Neutral and Drive. Its for the self propelled feature on the vacuum. The transmission might be out. If you need the self propelled feature, then you need to get that fixed
Jun 29, 2008 | Kirby G5 Bagged Upright Vacuum
Venting for portable air-condioners
They make special window units designed specifically for casement windows. They are taller and skinnier than standard window a/c's. They are no where near as common as standard window a/c's so you might have to look a little harder, but they are out there.
Jun 17, 2008 | Amana Heating & Cooling
Casement Window Placement of Unit Meant for Double Hung Windows
Heres an option for you I'm afraid you cant install an a/c unit In any position other than upright. Theres a unit size and type for every conceivable application though. GL!
Jun 11, 2008 | Daewoo High Energy Efficiency Air...
Computers & Internet Logo
David Payne
David Payne
