Question about Whirlpool Washing Machines
Whirlpool washer, LSQ8543JQ0, will agitate strong 3 min 45 secs, then clicking noise and week agitation 2 min 45 secs. replaced coupler. What is causing the clicking noise?
    Genius:
  • 1,028 Answers
Possible gearcase
Posted on Jul 17, 2008
Know when clutch going bad
Needs agitator dogs in agitator.
Mar 13, 2014 | Whirlpool Washing Machines
Will not spin
Sound to me like a simple drive coupler replacement is needed. Go to youtube and look for 285753 replacement
May 15, 2013 | Whirlpool Ultimate Care II LSQ9549L Top...
I transported my used washer on it's back, and noticed a couple spoonfuls of oil had leaked. The washer ran for a week, then would not agitate any more. Was this oil from the gearcase (smelled like...
Hello Robert, A leading thing that will make Whirlpool washers not agitate is a broken motor coupler, i have included a video that shows how to replace the coupler. If you take it apart as shown and move the 3 legged cog part of the coupler by hand the transmission should move both directions if you can turn it one way and it spins yet turning it the other direction it does not agaitate the trans. is indeed locked up. Good luck, i hope i have helped you to figure out what is wrong with your washer.
Aug 13, 2011 | Whirlpool Washing Machines
Whirlpool ETW4100SQ washer. Unit stopped agitating, grinding noise appeared. Tub is loose, agitator is free, was able to empty the drum.
while your washer will draining, in addation to the noise during the agitate cycle is it making a similar noise during the drain/spin cycle?
if that is the case the motor coupler is broken
i have attached a youtube video that will show you step by step how to replace the coupler
http://youtu.be/9K1KHEogf3c
the part number indicated in that video is the exact part number for the coupler
GOOD LUCK,
GENE
Jul 26, 2011 | Washing Machines
Loud while agitating
CHECK COUP-LER BETWEEN MOTOR AND GEARBOX.if coupler good,then gearbox bad.
Feb 12, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool washer agitates but makes a very loud noise
It sounds like the agitator teeth, that are plastic, are worn out. To check this, take the agitator cap off with a strong knife or flat-head screw driver, and check the circular teeth inside, to see if they are worn out. These plastic teeth are the agitator part of the washer, where as the spinning part is a metal set of teeth, at the bottom of the agitator. You see the metal teeth, when you take the agitator completely out. You will have to replace the agitator if the teeth are worn out.
Jan 11, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ8543JQ0 WON'T SPIN
really sounds like a coupler issue. May look fine but if one of the teeth are busted it will do this. You can get a tutorial for fixing this here. http://www.shop.washermd.com/category.sc?categoryId=4
Jan 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Kemore elite top loader won't fully agitate
If you have a whirlpool built machine th problem is probably the agitator dogs. They are located inside the agitator. My guess since you say it doesn't fully agitate. If changing the dogs does bot fix the problem then the coupler is probably bad and that connects the motor to the agitator.
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool washer spin cycle noise
Likely you need either an agitator repair kit or need to replace the direct drive clutch assembly. The drive coupler is a fail-safe device and generally fails for a reason. In order to repair the agitator, you will need to acquire an agitator hub nut wrench.
Feb 18, 2008 | Washing Machines
Will not agitate,spin or drain
There's a coupler that normaly goes.just tip the machine over and loosen the motor.the coupler will be 3 legged and plastic.just replace and it should be ok.
Feb 22, 2007 | Whirlpool LSR5132PQ Top Load Washer
Washing Machines Logo
119 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
