Question about Breadman TR2500BC Bread Maker
The bread pan will not stay locked down. My husband toke it out and set it in again and it will start up again and 2-3 rounds of pladel and it pops out again. When will we go back to selling American made products?????? The man I talked to was named Stan ,ID# 1192 was rude , I guess he was having a dad day, He ask what thwe problem was and and said a new pan will be shiped out in 7-10 days. I"m upset with how he handel the problem. Did I say he was short and rude!!!!!!
  • 3 Answers
With a strong pair of needle nosed pliers bend the tabs upwards on the side of the pan, not the spring clips attached to the pan cavity, to a full 90 degree position relative to the pan. After doing this I have made 10-12 loaves with no problems.
Posted on Nov 09, 2008
After contacting Breadman and following their instructions of repositioning the spring clips on the sides of the pan cavity, to no avail, I came up with a solution at least for me. With a strong pair of needle nose pliers I bent the tabs upwards on the pan itself to a full 90 degree position relative to the pan. I have made 10-12 loaves since with no problems.
Bread pan comes loose and bangs around during kneading cycle--how to fix?
Hello....I wrote this for those with bread pan problems....be sure to read the part about how to restore the "spring" of your bread pan clips...
Bread pan removal:
I am assuming you have the type of bread machine that has the little metal spring clips inside the oven compartment. Before inserting the pan always check on the bottom of the pan (underneath) to see how the impeller "T" is aligned and turn it with your fingers or turne the paddle with your fingers so the "T" will fit into the gaps of the impeller in the bottom of the oven. Once you have aligned them then place the pan in the oven and "pop" push the pan in place so the spring clips grab the matching clips on the sides of the pan. Also look to see if your pan has the word "front" stenciled in the lip edge of the pan. If so, be sure that edge is towards the front of the machine. If your pan still won't pop into place when you push down your spring clips may need to be gently pulled out because they can become "slack" over time. Take the pan out and reach in and pull each spring clip up until you start to feel it bend a little and bend them out. Pop your pan into place and if the clips don's start to grab your pan repeat the process of bending the clips out and repeat that until they do. Summary:
1) make sure if your pan is marked "front" that it is aligned properly
2) make sure the paddle and the T underneath the pan aren't in conflict with the matching drive impeller in the bottom of the oven. Just turn the paddle so they are opposite of each other and can engage
3) Restore the "springiness" to your clips by bending them out with your fingers. Be careful though because the spring edges are fine edges so get underneath them when you pull up
For bread machine parts, good used bread machines etc. visit breadmachineshelp.com
Apr 01, 2013 | Breadman Tr2500bc Ultimate Plus 2-pound...
I cannot get my bread pan out of the bread maker, no matter how I try to lift it! The instructions say to tilt it to the left and then pull- which did not work then I followed the suggestion of lifting it...
Most bread machines are held in by 2 little spring clips...one on each side.
They are under tension when the pan is in the oven and that is how it stays stable when kneading is taking place. So to get it out you have to release that tension and that is going take what I call the stern "pop". Grab the handle of the pan right in the center with both hands and put a little slack in it by lowering the handle down about an inch and then "pop" it straight up the little clips will release ther hold on your pan......magic!!
Sep 11, 2011 | Cuisinart CBK-200 Bread Maker
Bread pan stuck-brand new machine Model CBK200WS
They are under tension when the pan is in the oven and that is how it stays stable when kneading is taking place. So to get it out you have to release that tension and that is going take what I call the little "pop". Grab the handle of the pan right in the center with both hands and put a little slack in it by lowering the handle down about an inch and then "pop" it straight up the little clips will release ther hold on your pan......magic!!
Apr 18, 2011 | Cuisinart CBK-200 Bread Maker
I cannot remove baking pan
Mar 18, 2011 | Sunbeam 5890 ExpressBake Bread Maker
The bread pan is stuck in machine at the bottom. How can it be removed?
Feb 23, 2011 | Cuisinart CBK-200 Bread Maker
How to remove the pan from the bread maker
Jan 20, 2011 | Cuisinart CBK-200 Bread Maker
Bread pan pops out during kneading, hard to remove after baking
I have Breadman Ultimate for over 12 years now. I make bread 2-3 times a week for the past 10 years. I found that the bread pan popping out only happens when the motor shaft and the kneading paddle are not tightly engaged. I find this problem in the following two scenarios: 1. The bread pan was not pushed down all the way as described by cassie_hobbs and tlcquiltnut. 2. Debris filled up the motor-shaft bowl underneath the bread pan to prevent a tight engagement of the motor shaft and the kneading paddle. These debris are generated during the kneading process; part of the ingredients is pushed out of the shallow horizontal pan and accumulated underneath. To avoid the problem, I have to periodically remove debris from the shaft bowl and make sure the pan pushed all the way down. To reduce the debris, I made a simple cover for the bread pan by cutting an old aluminum baking dish. I always remove the cover after the kneading cycle to prevent the rising dough from reaching the bottom of the cover. Hope this helps. Wendy
Feb 22, 2009 | Breadman TR2200C Ultimate Bread Maker
TR440 Breadman won't begin kneading once "start" button is pushed
Hi Mindy.......it takes 30 minutes to PREHEAT this silly machine for wheat bread. I thought I did something wrong, too........I stopped it twice after it preheated for about 15 minutes. I did not want to waste anything so I let it stay in the machine.....I just went to check the machine and it started after 30 minutes of preheating.
I wish they would mention this in the book!!!
Julie from TX
Jan 11, 2009 | Breadman TR875 Bread Maker
Breadman TR2500 BC
See my posts on this problem.
Do not mess up the clips.
Aug 21, 2007 | Breadman TR2200C Ultimate Bread Maker
Bread pan jumps off of its fastener clips.
I have the answer to the TR2500BC pan popping off the base!! My husband and I made a loaf for testing the jump off. Ah HAH! I set the pan in, ok. felt it was down all the way. When it started to knead the ball and stop to reverse...it popped off. We looked at the side hook on top. ok. It popped off again. It was when my husband made sure the two tabs on the under side of the pan was in the opposit direction of the two buds in the base. at that point you MUST set the pan down with force until you get that distinctive click, click. Rock the pan front to back a bit as you push down. It has worked every time since I started that process. I make two loafs of bread a week with no problem of it hopping off. ENJOY.
Oct 09, 2006 | Breadman TR2500BC Bread Maker
Breadman TR2500BC Bread Maker Logo
129 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Dave Kristol
Level 1 Expert
Irene Tulloch
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
