Windchaser portable a/c hose that connects to back of a/c model # pacr 10
Hose is accordian style , connects to back of a/c which lets hot air out of a/c unit.
The hose in the back of the a/c unit will not stay connected to the out flow at the window. Wind Chaser PACR 10
Posted on Sep 12, 2008
Need a manual for a Windchime PAC9 Model SA 12059 Air Conditioner, or advise on how to bet alarm light to turn off so unit will work
on the WEB
Windchaser PACR9S Instructions Manual - ManualsLib
www.manualslib.com > ... > Air Conditioner > PACR9S
View and Download Windchaser PACR9S instructions manual online. WindChaserProducts Inc. Instruction and Maintence Manual Portable Air Conditioner ...
Aug 04, 2015 | Windchaser Heating & Cooling
My model no. is PACR 93S
This company is out of business, so the parts are not currently available. However many people have visited lowes or home depot and managed to rig up a fix that works sufficiently.
Jun 24, 2015 | Windchaser PAC9 Air Conditioner
What causes the exhaust hose to get hot on a windchaser portable AC
make sure its not obstructed, then wrap it up with a towel or other insulative material. it heats up because the heat exhausts through that hose out the window.
Jun 28, 2014 | Windchaser PAC9 Air Conditioner
How to get attachment for hose to back of a/c
If it's a major manufacturer of appliances you can use any parts supplier like, 1st Source Servall, All Appliance Parts, Marcone. If it's a off brand you have to go back to the manufacturer for there local supplier. Just Google the name and model number. Good luck
May 07, 2014 | Windchaser PAC9 Air Conditioner
I got a Blue Way KYD35 portable airconditioner. Wondering if I need to keep the lids behind the unit open or closed. If I open them hot air blows up into the room defeating the airconditioning. I cannot...
Yes, hopefully it has 2 of them, 1 for removing air from outdoors rather than ejecting indoor air to the outdoors, again fighting itself in the process due to infiltration of outdoor air to compensate for the amount being ejected to the outdoors.
The old style portables were designed this way and were not optimal as they pull in warm air as they reject the hot air from condensing the refrigerant gas to a liquid.
With 2 hoses only outdoor air is used to condense the refrigerant and this same air is rejected back outdoors thereby avoiding the negative pressure created by the old single hose design.
You need to install the hose/hoses/ducts to reject the hot air outdoors at minimum.
Oct 10, 2013 | Heating & Cooling
Unit shuts off, getting an E5 error. sounds like there is a lot of water inside. the customer service numbers for Windchaser are disconnected. PLEASE HELP!!!!
E5 is the fault code for Compressor overheat/malfunction it coulb be caused by the exhaust hose being too long or kinked, remove the exhaust hose and run the unit for an hour and see if your problem goes away, if so re-route the exhaust hose, if not you need to contact the manufacture
Jul 22, 2011 | Windchaser PACR10 Portable Air Conditioner
I need an exhaust hose for a Windchaser 9000 portable ac with remote
You and get flex duct at lowes 6" 25' to a box that should work the same, In the heating cooling section.
Aug 28, 2010 | Windchaser PAC9 Air Conditioner
Windchaser PACRWC-HP Portable Air Drainage Issue
obviously condensate sensor is fault. You may need to replace it. Yes it okey to turn it on now.
Oct 11, 2009 | Windchaser Portable Air Conditioner
Narrow tube v. plug and cap?
If the unit stops working and some kind of a 'water level full' indicator appears then un bend it and un plug it and then let the water drain into a bucket.  If it continues to indicate that the internal water tank if full you may want to run a hose to a drain in the floor or into a bucket to let the water drain away and the unit keep running without stopping.
Jun 13, 2008 | Windchaser PACR10 Portable Air Conditioner
Heating & Cooling Logo
138 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
