Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Code 37 -
Washing machine full of clothes and went thru the level sensing mode then code 37 came on "I need service - call service technician" showed on panel
  • 1,498 Answers
Fault code 37 pump fault, not draining etc.
It's in need of a service call
Hope this helps,
Mike
Posted on Jul 17, 2008
    Brigadier General:
  • 6,966 Answers
To my knowledge, Error Code 37 on a Fisher & Paykel machine refers to "drain fault" which could either mean that the drain valve will not open or that the drain pump will not run. The easiest user intervention that could be performed is to check for any blockage/clog at the drain filter, drain pipe, drain pump impeller and drain valve.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • Tony Margetts Sep 17, 2011
    Found the drain valve solenoid open circuit on my washer - expect to get a new one tomorrow - hoping it won't burn out ;-)
How do i fix my washing machine,it only drains water instead of washing clothes.
call a service technician as it may be a faulty program board
Nov 20, 2015 | Washing Machines
Fisher and paykel washer
Here is the service manual.
Start on page 35 to get to "Settings menu" and read thru to page 37 (scroll down to factory default).
Fisher and Paykel WL26CW1 Manual
Hope this helps to reset the machine.
Aug 03, 2014 | Fisher and Paykel Washing Machines
My washing machine toshiba aw-9760s Kept showing this "E2 -3" problem. Whenever i close the lid to start washing my cloths. Anyone here can help me? In need of answers A.S.A.P
I also have a Toshiba AW-9790S, and encountered similar problem. The E2-3 would occur sporadically and halt the washing programme. E2-3 error occurs when the washing machine detects that the lid is not properly seated and locked during the rinse or spin cycles. I took mine apart and resolved my problem by cleaning the contacts for the switches. There are 2 contact switches at the lower right side; 1 for sensing the lid is closed and 1 for sensing that the lid lock is engaged. Both the switches were slightly oxidized which prevented current flow and the sensors from working properly.
Nov 02, 2013 | Washing Machines
Code error for my front loadef panasonic washing machine reads U 11
U codes are User "Error" Codes.
CODE U11
The washing machine cannot drain.
Check that filter is not blocked or obstructed.
Check drain hose is clear of any blockage or obstruction.
Check wiring to drain pump (Done only by a Service Technician.)
Check drain pump is not defective (Done only by a Service Technician.)
Check level sensor or switch (Done only by a Service Technician.)
Check wiring to level sensor (Done only by a Service Technician.)
Many Panasonic washing machines seem to have a problem spinning with heavy loads; they become unbalanced and give a U13 "load out of balance" code. Most other brand machines can spin the same "heavy" load with no problem.
Mar 11, 2013 | Washing Machines
No problem just want to know if one can put clothes soaking in bucket into the machine and go straight to spin to get excess water out without going thru the whole washing process. Cheerz!
Hi - yes theres a few options start it on the final rinse and set your water level to low or auto sense then spin speed (this will add more water to stabilesde the spin cycle)
Could go direct to spin as well but you will need to adjust the clothing proper prior to starting of the cycle..
Jul 10, 2011 | Fisher and Paykel GWL11 Top Load Washer
Not lit up to show power
You may have overloaded your washer. Some washers have a safety trip feature that activates when the motor is overloaded. Try unplugging the washer and removing the clothes. Once you have done this, go ahead and start the washer again. If you that doesn't work, you made need to check if you have blown an internal fuse or call a qualified technician. I hope this helps. Good luck.
Jul 23, 2010 | Fisher Paykel EcoSmart GWL15
Soap left in clothes
Is the machine a FAV6800A or FAV9800A? Do you take the “Sd” error code for high level of suds? If we are talking about a FAV6800A or FAV99800A and the series is 12 or more you have a 2 level sensing pressure switch. This will give you about 3.5” for mid fill and 7” for high fill. I have only seen the Bulky wash cycle fill to High level fill.
Are you using HE detergent and the amounts called for in Use & Care section of the FAV6800A/FAV9800A Service Manual ?
If you have a series 10 thru 12 FAV6800A you will have 3 Level pressures switch sensing. Disregard the Low Fill setting IMOP it doesn’t put enough water in the machine for adequate wash. I believe that is why Maytag did away with it and went to 2 level sensing pressure switch in later series…………Rich
Jul 03, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My washing machine is beeping and is full of water, I am trying to wash a load of clothes. Used it yesterday and it worked great.
Water level sensor not sensing. Check the small tube that connected to switch. switch off power. Remove the tube and refix.
Mar 31, 2010 | Fisher and Paykel Fisher & Paykel Washer
My washer flashes "h" and "f" then stops.
1st, unplug the washer from receptacle. Wait one minute and replug. This will (in many cases) reset the logic board because of some fault it sensed while the machine was running. Now try the machine to see if it operates normally. If still not working, look in your instruction manual to see if there is a section that shows problem (fault) code letters. Some manuals show this info and some do not. If you see a trouble shooting section, it ma y have this info. See what fault code letters match waht flashes on the machine.
Most codes are for imbalanced load while spinning, water inlet valve interuption, overload of machine (too much clothes), power interuption (temporary loss of power while operating, overfill of water level (again usually do to too much clothes or too much detergent suds), a backup of discharge water. If disconnecting power & reconnecting does not reset the machine, check each of the possible problems mentioned. If still no results, you need a service tech visit. Good luck. Macgivor
Sep 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Screen has code 37 on it
Hi, welcome!
Code 37 is a "pump blocked error" code. Typically this code is triggered when the machine does not sense a change in the water level when called for. Check for debris caught in the pump, either in the impeller for moving water or in some cases, the external cooling fan impeller (exposed underneath the machine) gets snagged with a piece of fabric softener sheet (such as "bounce") and this will stall the pump and trigger a code 37.
I hope you find this info useful and thanks for using Fixya.
Jan 26, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
1,896 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
