Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Mower doesn't seem to be charging. Charger light remains green instead of red when plugged into mower to charge it.
  • nmpegelow Sep 27, 2008
    After mowing a lawn and plugging the mower back in, the red light changed to green sometime overnight. I went to mow the back lawn the next day and the mower had hardly enough power to turn the blade. The indicator light remains green whether the mower is plugged in or not. Hopefully it's just the charger.
    Champion:
  • 313 Answers
Is this a cmm1200 24v mower. if i am right then the charger should be replace.
Posted on Jul 19, 2008
I would like to use my snowblower for the season. I've never used before, my husband used to do it. He said that I need to charge it first before using it. How do I go that
hopefully you will find the charger near the machine ? ( a plug with a lead ) simply plug it into an electric outlet ( plug hole ) and connect it to the blower ( you will see a hole in the blower the same shape as the end of the lead on the charger) if the charger has lights on it ( usually red and green ) you will see the red light come on,leave it charging until the green light comes on. or charge it over night...hope this helps
Nov 19, 2015 | Garden
I just purchased a Toro e-cycler cordless mower, model # 20360. I tried plugging in the charger to the Ac outlet and the mower receptacle. My understanding is that the charger light is suppossed to be...
It could be that the batterys don't need to be changed and shouldn't be unless fully discharged, if u charge before the batteries are fully discharged u run the risk of damaging the batteries. The problem is sometimes batteries get what is called a memory charge, this means if u use your lawnmower for a short time than charge it and u do this repeatedly the batteries will only discharge for this sort time and will only charge for a sort time. Than if u need it for a big job it will seem that u have only operated it for a little time and u need to plug it in. The only way to fix the batteries is buy new ones, that way they always tell u to always fully discharge before recharging your batteries.
Sep 15, 2011 | Toro Garden
The yard trimmer's battery won't take the charge. It charged overnight but I see the light is flashing red on the charger instead of green.
Time to replace the battery, most auto parts stores have battery testers to see if its bad or not.
Jun 02, 2011 | Garden
No power
I think you should check the charging system. You said you replaced the battery a few weeks ago. Even with the charging system not working, the battery might have enough power for a dozen or more start-ups; but using the lights may have drained what power was left. Get or borrow a battery charger and charge your battery. If mower then seems to be working fine, measure the voltage across the battery when the mower engine is running at normal speed (not idling). It should be 13.5 volts or more if the charging system is working. 12 volts or less means it's probably not working. Either test or replace the regulator/rectifier. Please rate me if you think this helped, thanks!
May 31, 2010 | Craftsman 26 Hp 54" Deck Yard Tractor
Black&D'er CMM1200 24V is running very slow unable to chew grass
Sounds like a battery problem, you could have a defective cell which is causing a very low voltage to be sent to the motor which = slow spin.
Yes the charge indicator could be related.
You can take the battery apart and find out what type of cell it is and have it replaced...but personally I hate cordless lawn mowers for this exact reason so I would go but a manual push or a gas model.
May 05, 2010 | Black & Decker 19" Electric Lawnhog...
Mower not starting.
The internal battery may not be charging.
Apr 15, 2010 | Black & Decker 19" Electric Lawnhog...
Black & Decker CMM1000 Cordless Mulcing Mower Won't Start
The gauge is only active when the mower is running! (See page 6 of the INSTRUCTION MANUAL)
Sep 12, 2009 | Black & Decker 19" Electric Lawnhog...
Not Charging.
I have the same problem with my CMM1000. We replaced the batteries but the problem persists. Does anyone have an idea of what the problem could be?
Sep 03, 2009 | Black & Decker 19" Electric Lawnhog...
Black & Decker CMM1200 cordless mower - charger not working
Possibly the handle must e folder for it to charge. Possibly the on/off switch was on. More than likely it must be off to charge. Sorry that is all I can offer without seeing the mower in person.
Aug 02, 2009 | Black & Decker 19" Electric Lawnhog...
Battery Charger displays green blinking light
This is likely a code from the computer system on the CMM1200 that the batteries no longer hold a charge. If you have a voltmeter, a "quick test" is to put the batteries on the charger for at least 8 hours and then test the DC voltage of the batteries. Test each battery separately by taking the cables off and testing the battery at the positive and negative lead. If they read less than 11.5 volts, you need a new battery set. You can get replacements from www.batteryinternational.com/universal-battery-ub12180-batteries-by-brand-universal-battery-nb.html. The model you have requires two of these batteries. Hope this helps.
Dec 25, 2008 | Black & Decker 19" Electric Lawnhog...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
479 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
EugenesDIYDen
EugenesDIYDen
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
