Question about Goodman CLJ36AR42 Air Conditioner
How often should a central air conditioner be charged
You need to charge your system only once. If you have to recharge the system with freon ever so often ,It means that you have a leak somewhere in the line.
Posted on Jan 02, 2009
  • 417 Answers
Every Couple days To Give The Best Performance
But You Will Automatically know when it needs a charge
Posted on Jul 17, 2008
Central heating&cooling
sounds like your compressor is getting hot and shutting down have you washed your outside condenser coil? Could be dirty causeing high head pressure and shuts your compressor down. Try washing your condenser coil I think this will help you. If not you may be low on charge of Freon.
Aug 17, 2014 | Rheem 13AJN30A01 Central Air Conditioner
Hello, usually when a air conditioner does not cool it falls into a airflow problem or a low refrigerant charge. The first thing to check is the condition of your air filter, blower wheel, and evaporator coil make sure they are clean. If that checks out good then most likely your air conditioner has a low refrigerant charge due to a leak. In this case you will need a technician to come out and repair the leak.
Mar 22, 2011 | GE Heating & Cooling
I have a central air unit that the line has frozen. How do i fix this?
Shut it down and keep the fan on so it will thaw out...then check the filter and have someone check the freon charge...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
Aug 21, 2010 | Weather King 12AJA4801AH Air Conditioner
Leaking freon somewhere have to have it charged at least twice a year
try HVACR additive/sealant and remind tech it is illegal to just charge a system if it is loseing more than 15% of total chare during the cours of a year
Sep 29, 2009 | Ruud Central System Air Conditioner
I have a Concord air conditioner, central heat and
You can try getting it serviced. Vacuuming the system and charging it up with new refrigerant, as well as replacing the reciever drier, will help tweak your AC system. This is no guarantee though. It might be able to bring the temp in your house down several more degrees. Also try cleaning the condenser outside. You can spray it with water to clean off dirt which block air from passing through. This hepls a bit and you can do it yourself.
Jun 28, 2009 | Heating & Cooling
How do i put freon in my central heat and air my central heat and air unit is a payne
This job is best done by service tech. You have to know what your doing to be able to charge a system. Plus you have to have EPA card to handle Refrigerant. You need to call service tech. Remember if you have to put gas in there isa leak. Make sure they look for one if you ahve it recharged. A unit can run forever on the same gas. Cost of chargeing an AC can very from 100 to 300 dollars. My suggestion is to ask for a free estimate. So you know up front what it will cost. Rus
Jun 21, 2009 | Whirlwind FH-778 Air Conditioner
Charging a central air conditioner in the cold weather
The copper tubing has cracked and water has leaked onto my roof. I have shut off the water valve that runs to the aircodtioner but cannot get someone over until the morning. It is a cold night. Will this be sufficient until I can get someone over in the morning. It's not that cold but there is a possible storm coming thru.
Oct 05, 2008 | Goodman CLQ36AR49 Air Conditioner
Central air conditioner
check the filter also sounds like a low freon charge.
Jul 29, 2008 | Ruud UBHC Air Conditioner
Goodman CLJ36AR42 Air Conditioner Logo
171 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
