Question about Belkin Computers & Internet
I MISPLACE THE INSTALLATION CD FOR MY WIRELESS G ROUTER, AND NOW I CANNOT INSTALL MY ROUTER.
  • Brian Canute May 11, 2010
    what make & model
  • 89 Answers
A router does not need an installation cd for it to work. You could be referring to the manual cd that came with your device. Connect the router to your PC via LAN cable, and use a browser like IE or firefox to access the configuration system of teh router. Usually, you will type the address http://192.168.0.1 or http://192.168.1.1 to access the router. Please check the back or underside of the router for the correct address and account info to use.
Posted on Jul 17, 2008
Nstallation cd is missing for DIR-600...Hello, If you don't have the installation disc anymore, you can...
open the setup page of the router and change the settings manually.
Like other routers, you can install wireless router without installation CD also,
Read how to setup router without installation CD
Jul 04, 2012 | D-Link DIR-600 Router
How to instal
You'll wanna check out: ftp://downloads.netgear.com/files/WNR1000_SM_WW_23Jan09.pdf
Look for "installation"..
To help you set up your router and get on the Internet quickly, the Resource CD contains a Smart Wizard™ Installation Assistant. The Installation Assistant walks you through the steps required to connect your router, modem, and PC(s); configure your wireless settings; and enable wireless security for your network. When you have finished, you will be Internet ready!
You can set up your wireless router using one of two methods:
• Smart Wizard Setup: The Smart Wizard Installation Assistant setup is available on your Resource CD. See "Installing Your Router Using the Smart Wizard" on page 9 to use the Smart Wizard Installation Assistant.
- This is the easiest option. The wizard guides you through the setup process. It automates many of the steps and verifies that the steps have been successfully completed.
- Smart Wizard requires a PC running Microsoft Windows.
• Manual Setup: If you cannot or prefer not to use the Smart Wizard Installation Assistant, see "Manually Installing Your Router" on page 13. For example, if you are connecting to a Mac, are using a Linux operating system, or are technically knowledgeable, select this option. If you choose to use this option and install your router manually, for best results, install and set up your router in this order:
Failure to follow these guidelines can result in significant performance degradation or an inability to wirelessly connect to the Internet.
NETGEAR does not recommend or support adding a NETGEAR router behind another router, or replacing a gateway with a a NETGEAR router.
If you have a Macintosh or Linux system, you must use the manual installation method (see "Manually Installing Your Router" on page 13).Getting to Know Your Wireless Router 7
1. Install and connect your wireless router to your network (see "Connecting Your Wireless Router" on page 14).
2. Set up your wireless router for Internet access (see "Setting Up Your Router for Internet Access" on page 18).
3. Configure your wireless network and select wireless security settings to protect your wireless network (see "Configuring Your Wireless Network" on page 21)
Feb 04, 2011 | NetGear WNR1000 Router
I have DI-604 in line between Windows Vista computer and cable modem. Works fine. Bought DIR-615 (wireless). Several places instructions say, ""Insert the DIR-615 CD into computer and click Install Router....
Contrary to the many warnings not to install the router before starting the installation with the CD, I got the installation to complete only AFTER I installed the router inline thusly:
1. Power everything off.
2. Remove DI-604.
2. Install and connect 615 router to computer and to modem.
3. Apply power to router and modem.
4. Apply power to computer and wait until Windows loads.
5. Insert 615 installation CD.
6. Follow the directions.
Nov 22, 2009 | D-Link DIR-615 Wireless Router
I need to download the installation cd
You do not need to install any software in order for a router to opperate.
Jul 22, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Lost wireless router CD
You can make the router working even without using the CD. Who is your ISP? Are you having concern with wired or wireless connection?
Jun 28, 2009 | Linksys Wireless-G WRT54G Router
Router not connecting
The problem here is that the WRT54GS is an old model, so naturally the installation CD is also old. This is especially a problem if you are running Vista. I ran into the same problem when I was installing my wireless card; my computer would detect it on boot up, but when I installed the drivers from the CD, it said the card wasn't plugged in.
The solution would be to download the lastest installation and driver files from the LinkSys website and use those instead of the installation CD that came with it. You may have to hunt for it, as some companies would rather push new products than update older ones, but since the router is still on the market, they should have the updated drivers and installation files.
Feb 11, 2009 | Linksys Wireless-G WRT54GS Router...
Install 2wire 1701hg without installation CD
I have the same modem.
You don't need any installation cd.
Just follow the instructions at this web page:
http://support.2wire.com/?page=view&article=60
Nov 04, 2008 | 2wire (1000-400108-001) Router
No Start Up CD
Do you have the user manual? If so, you can still configure the router manually by following the instructions in the manual.
Jan 10, 2008 | Linksys Wireless-G WRT54GS Router...
Computers & Internet Logo
26 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
