Mr. Heater MH175KT Open Flame Utility Logo
Posted on Jan 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Gas Tank for my Mr. Heater has a ( for some unknow reason) plug in it on the bottom it is leaking and i need it fixed.
Kens Repair
Level 2:
Habit-Forming:
New Friend:
  • Expert 67 Answers
  • Posted on Jan 23, 2011
Kens Repair
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
67
Questions
Helped
23953
Points
115
Go to Mr Heater .com and you can order one direct
I am installing a MHU45LP heater in my cottage. What will I need for the gas hookup to a 100# propane tank and is a regulator required??
Yes, you will need a regulator at the tank that can handle the maximum Btu Output of the heater. In addition to that, you also need enough 1/2" Flexible Copper Gas piping to run from the tank valve to the heater. In the line passes through a brick, cinder block or concrete wall, the gas line MUST be sleeved with either Black Iron Pipe or Rigid PVC Pipe. You'll also need assorted flair nuts and connectors.. As well as , a Inline Gas Shut Off Valve within a minimum of 2' from the heater. You will alos need a pipe bender for flexible copper pipe.
Having a friend who has a lot of knowledge and tools for installing gas appliances (running lines, making leak-less connections, etc) really helps.
My Mr Heater Buddy heater 4000 to 9000 btu unit work fine with 1 lb propane tank but when I connect it to my 20 lb tank with hose it will not stay lit. Acts like there is not enough gas pressure. My 20 lb...
it could be down to the draw off the tank pipe too small or reg is not for a 20lb tank , going to lock out check reg pressure should say on the side , or take hoes and reg off tank , put it back on and turn gas on slowly see if this helps
My heater stays lit for a few minutes then goes out. Also it has a high pitch whistle when on low.
Here is some research I did on Mr. Heaters--
your Mr. Heater the model that uses two small one pound cylinders or you have the choice to hook it up to a single larger tank? if so, you must use the special filter connected to the Mr. Heater and then your hose to tank.
This happened to me and after I hooked up the filter my problem was fixed.
Ron
large and sealed of an area are you using it in? I ask because those units have a low oxygen sensor which will shut it down if there is not enough oxygen in the space.(kinda prevents that pesky suffocation thing). Otherwise if using it in larger cold spaces, the issue is can be from the smaller tanks. As mentioned above, a larger tank can solve this, because these units have a fairly good input rate, which will cause the smaller tanks to freeze, and lower the propane temperature and evaporation rate, basically runs out of gas until the tank warms back up.
just one new cylinder, it will run on just one, to verify a problem with the cylinders. Also it could be the pilot light, sit and watch the pilot light to see if it goes out for some reason. If it does the heater will shutdown automatically, but you already know that.
Let me know if we can help you further
Mack B
1helpful
Put a new tank on and no gas coming through to the ignition. Was stored in the garge and got dusty, if plugged how do you clean or other possible issues
You will have to clean (possibly with a fine wire) the gas line orifice due to spider web blockage or rust. Not a big job, just start from the full tank and test the hose to see if gas blows through it. Then go to the next component, check on down the path. You'll find something.
I have an Enviro propane fireplace insert installed last year & it worked fine. The tank & regulator were changed because I got another gas supplier. For some reason now I have a low flame....
It sounds to me like you need to increse gas pressure. Most propane fired units need at least a 11 inch water column of pressure for proper operation. This relates closely 7.5 ounces. I would have regulator checked out by qualified service techs. Thank you
2answers
Leeking water from bottom
I wrote a page on leaking water heaters with resources and information:
Page lists things to check.
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html
Also run hand over tank to find warm spot that says where leak is coming from
A rusted tank cannot be repaired.
If your tank is rusted out, it might burst open and flood the area.
Hot water inside tank is under pressure.
Turn off heat source to water heater.
Turn off water valve located above tank.
Open tub faucet on hot side and relieve pressure from tank.
You can limp along with a leaking water heater by turning it on when hot water is needed.
For example a shower uses 5-9 gallons hot water.
Turn gas water heater on for 15-20 minutes.
Turn electric on for 20-30 minutes.
To conserve resources with next heater:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Have a Mr. Heater 175000 BTU that is leaking at the bottom were the drain plug is located. The O-ring is cracked, I need a replacement for the O-ring. What size do I get?
Tip the heater up so that the fuel is away from the drain plug hole and take the plug to an auto parts store. They have bulk o-rings there and can fit the needed O'ring to your plug.
I checked the parts manual:
http://www.mrheater.com/upload/newsletter/mh_50_75_125_150_175_210_BL.pdf
There is no drain plug listed for the tank. Only the tank assy. (Item 2)
You might even be able to get a copper crush washer similar to what is used on an automobile or motorcycle oil drain plug.
Kelly
1helpful
It runs but it puffs smoke every 3 - 5 seconds.
I am not real familiar with the Mr Heater units, although I have been around Reddy Heaters for well over 30 years. The principal is the same, after all, Mr heater is a foreign knock-off of the Reddy Heater.
Check, in this order:
1. shine a flashlight in the tank- look for water droplets rolling around on the bottom.
2. check the fuel filter for restriction. A blocked filter will cause starvation.
3. with soapy water check for air leaks from the air pump to the nozzle. An air leak will cause reduced fuel delivery.
4. check the pump pressure, bring up to factory specs.
5. If you have turned the adjustment screw, move #5 up to #1.
6. check or replace the nozzle.
7. If the fuel delivery system checks out OK then you have an electronics problem, and I’ve been told that Mr Heater parts are rare and hard to come by.
Top Mr. Heater Heating & Cooling Experts
Paul Carew
Jay Finke
Jay Finke
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
