Question about Kenmore Elite 45986 Front Load Washer
Kenmore HE 110.4751 front load
I went to open my washer and the metal ring (with spring) was dislodged from the rubber seal to tub washer . The rubber tub seal is not ripped. I can not get the metal ring back around the tub opening and cannot find a repair diagram that shows me how it is to be positioned.
Help!
  • Anonymous Mar 17, 2014
    Show me video on how to open washer main panel and remove the large diameter rubber holes that connects to the bottom of pump to the bottom of outer tub
    Genius:
  • 1,028 Answers
Soild metal part fits in groove around door boot spring goes in at bottom they can be tough to get back on after inserting in groove around seal you'll have to stretch the spring and pop it under at the same time band will try to come back out and roll seal back off lip..good luck
Posted on Jul 17, 2008
The metal wire ring fell off the rubber seal at opening and the seal is also off centered I have a matag epic washer
With it being off centered and the seal retainer coming off what needs to checked is the concrete counterweight thats bolted to the front of the tub has come loose and wobbling free.
Gene
Aug 05, 2011 | Maytag EPIC MFW9700S Front Load Washer
Inserting loose rubber seal on front load washer
you can try holdthe one side and use a screw driver on the other end try to put the rmetal ring in the gasket. is batter if you have to persons...
Apr 10, 2010 | Bosch WFMC2100UC Nexxt Essence Washer
Rubber Seal leaks
You have to replace the whole door seal.It can be done through the port hole,difficult but achievable or you can strip the front of the appliance off and do the inner part easier.
Unplug the appliance.
Open the door and take the seal retaining ring out of the door seal.
Peel the door seal off the front panel and fold it inside.
Take the seal retaining ring/spring out of the tub side of the seal.
Pull the seal off and take it out of the appliance.
Fit the new seal to the tub,look at the seal and tub for matching arrow marks to help align it.
Fit the retaining ring/spring into the groove in the seal and over the lip of the tub.
Fit the seal to the front panel and then fit the retaining ring into the seal.
Restore the power to the appliance and leak test it.
If you find you can't get the seal on.
Take the top off the appliance.
Take the dispenser out.
Take out the screws revealed.
Take out the screws holding the door lock.
Take off the plastic cover below the door and remove the screws revealed.
Take the front panel off.
If the panel won't come down and off there will be a hidden screw that requires the facia panel to be removed.It's snap together plastic,just release the catches and carefully remove the facia.
Take the screw out, take the panel off.
Fit the inner part of the seal to the tub.
Reassemble the front of the appliance.
Fit the seal to the front.
Leak test the appliance.
Apr 06, 2010 | EuroTech EWF150 Front Load Washer
Wire ring that holds rubber seal on next 100 washer has come off
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer how to put back on wire ring, with a spring for tension, that holds the inner rubber seal in place.
This video will show you how to change a door seal on this Bosch front loader washing machine and also how to get back on, the metal ring around the seal.
we have all bosch repairs in our channel.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 24, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Kenmore HE 3t Front Loading washer, rubber seal torn
fix ya..do it your self and save big,,im going to talk you through..and give you the part number...what you need is the bellows part # 8182119...ok vack unplug unit..open the door,,now you see the front lip of the bellow theres a wire with a spring stick a srew driver and pull off,,wire off ..ok now look in the unit right behind the front panel and in front of the tub in the upper right hand corner of tub font or bellows backside there a nut take screwdiver and losen pull bellows off,,easy to put back just reverse but open clamp a bit on back...onthejob
Jan 27, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore door to tub spring has come off
If you are talking about the inner spring that holds the door bellow to the tub, it's going to require two hands to get the spring to go back in the groove. You will need to carefully remove the bellow from the front opening of the door, first. On the 417 models, such as yours, the bellow is usually glued in place aorund the door frame and held in place by a spring to the tub. Use a putty knife to carefully peel the rubber form the washer facing. Once completed, you can glue it back in place with some appliance adhesive. To get the spring back in the groove on the tub facing, you will need to start at the top and have someone hold it on place as you work your way around the the tub. It's a real bear to get back in at times. Let me know if this helps you. Please post back if you have questions.
Dec 22, 2008 | Kenmore Elite 45986 Front Load Washer
Gasket came loose and rapped around laundry-tub seems loose
if your metal ring (clamp) came off it is most likely due to you shocks or the spring at the top are worn out and need to be replaced. this will happen more often if the cycles are off balance or the washer is over loaded
Nov 26, 2008 | Whirlpool GHW9400 Front Load Washer
Rubber sean and wire spring came off
Hi
Spring should be a the 6 o'clock . you may need someones help have some hold the wire on at 15 and 45 ... when you pull the spring apart and slided it under the bellows. be careful as the spring can fly off. good luck and keep trying...
Apr 05, 2008 | Bosch WFR 145 Front Load Washer
Metal ring aroound rubber seal fell off.
Start with the spring at the bottom, work the retainer around until the seal starts to pull away from the washer. Now grip the loop that the spring attaches to on the side that isn't in place and open the retainer. Push the retainer in place and release the spring.
Jan 09, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washer door seal is loose
The rubber seal fits over the lip around the door opening. Carefully seat the rubber seal all the way around the door opening first. Then, place the wire hoop in the crease where the rubber seal fits over the lip. Insert the hoop with the spring pointing at the bottom. Starting at the top and work your way around the door opening to the 4 and 8 o'clock positions. While holding the hoop in place, stretch the spring apart enough to allow the rest of the hoop to snap into the crease at the bottom of the door opening. You may need a second pair of hands to help you with this. Good luck and I hope this helps you.
Sep 16, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
558 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
