Question about Dryers
Dryer works good. But when dryer is first started if squeals for a couple of minutes. Recently the squealing is lasting for almost entire drying time. Model RES7648KQ0 Roper
  • 4 more comments
  • tucke987 Jul 16, 2008
    Thanks for your suggestion! Does this mean that the belt itself probably is NOT the problem? Also, my husband is very handy. Are these replacements that he should be able to make?
    Thanks Mike! We will take your advice and I will let you know how this project turns out. I probably should mention.....the dryer IS 7 years old......but I would love to repair rather than replace.
  • tucke987 Jul 19, 2008
    Thanks so much. We ordered the parts and my husband installed them in less than an hour. You saved us losts of worry and money.
  • Tina McGrath Aug 31, 2008
    dryers squeals until it gets warm. then it stops
  • Anonymous Mar 25, 2014
    dryer turns on and heats but turns off after a couple minutes
    my roper electric dryer turns on but only runs a couple minutes and shuts off
  • 481 Answers
The squealing is coming from either the drum support rollers or the belt tensioner roller. Dryer works good.  But - 3aef099.jpg
Posted on Jul 16, 2008
  • Mike Durland
    Mike Durland Jul 16, 2008
    you can check the belt while your in there but it usually does not make any noise, it just breaks. yes if he can take out the drum he can replace these parts.
    let me know if you need help
    Mike
Squeals while drying clothescould this be a bad belt ?
It can come from two things, belt for sure when you over load the dryer or it is getting worn an second the rubber wheels the drum sets on can squeal.
Mar 29, 2014 | Kenmore Elite HE4 Electric Dryer
Squealing dryer
Sounds like the drum bearings are going bad, or at the very least need lubrication. thats what your problem is.
Jan 25, 2008 | Estate TGDS740JQ Gas Dryer
How do I know if motor is bad on a kenmore 90 series dryer
you have reassembled it incorrectly and now the motor cannot drive the drum
Nov 25, 2017 | Kenmore 62602 Electric Dryer
Squealing noise on start up drying still works
This dryer needs to be taken apart to lubricate any and all moving parts. Idler pulley and rollers, if they are worn out in any way, replace them.
Also, consider a new belt.
Nov 16, 2009 | AEG T58840 Dryer Electric
Hoover Maxi 6 TC50 Tumble Dryer making squealing noise
Have you fixed this problem? I also have a Hoover condenser dryer, only a few months old, and has started to make a squeal/whistle. I'm thinking it might be the front fan needing some WD40, OR too much water vapour around the belt that moves the drum causing the sounds.
If it's the fan, lubricating the shaft and its components should fix the problem, if a wet fan then I'd think maybe fully cleaning the condenser filter, reservoir ect will fix the problem.
The problem seems to go away though "mostly" 15 or so minutes after you start the dryer, so that makes me think ones it gets warm something is expanding to allow more "give" so maybe the belt.
Aug 26, 2009 | Hoover Dryers
Squealing dryer
Most dryers have a vented access panel on the back on the bottom that is held in place by a couple of screws so you can get to the motor & pully assy. Check to see if the grease has dried up on either the iddler pulley or drive pulley. If needed, push down on the iddler to release pressure on the belt and give the pulleys a spin. If they seem fine then it will be the belt or possibly an overloading problem.
Jul 09, 2009 | Kenmore 98702 Stacked Washer/Dryer
Load squeal
if you can take your dryer apart, you'll have to take the drum out and lubricate the bearing that is located in the center under the drum while there check wellness of your heat element if located there. Anyway use high temp grease on this bearing looks more like a ball
Feb 21, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore 400 dryer squealing noise
A little lubricant on the pulleys near the belts will go along way. Its vereasy to access these parts front the back of the machine with a 1/4 hex head screwdriver.
Jan 19, 2009 | Kenmore 63942 Dryer
Dryer Squeals
my sears kenmore 417 stacking get things caught every time in the dryer and leaves some brown stuff on all my clothes.
How can I keep things from getting caught??
Jul 13, 2008 | Kenmore 98702 Stacked Washer/Dryer
Squealing!!
the noise is coming from the drum axle bushing that allows the drum to spin on it's axle. Gain access to the rear of machine and apply some high temperature grease that is found in automotive parts stores to the bushing. run it while observing spinning drum at rear for any possible other problem where squeal can be found such as drum slides.
Dec 26, 2007 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
330 people viewed this question
Top Dryers Experts
