Norton is blocking my outgoing e-mails - Computers & Internet
  • 56 Answers
Is it norton 360 if so remove and download avg 8 free version
Posted on Jul 16, 2008
Can recieve email but cannot send?
Check if the details for outgoing e-mails (SMTP) at the settings for your provider. If this is OK check if there is some security issue with your e-mail client that might block your outgoing e-mails. Good luck!
Dec 18, 2010 | Compaq Computers & Internet
All of my outgoing e-mails are blocked. I can receive e-mail, that is all pls help
check to make sure that your outgoing mail server has the correct settings
if it is what os are your running
Oct 21, 2010 | Computers & Internet
Norton not running and e-mail malfunctioning
Norton modifies your email settings to point to your local machine, so that incoming and outgoing mail is scanned before sending/receiving.
If you no longer wish to use Norton you will need to find your mail server settings from your ISP, and put these back in to your mail client for it to work without Norton.
Hope that helps!
Oct 17, 2010 | Computers & Internet
Please can you help,i can recieve emails but not send them , how can i fix this. roger
Most often this problem occurs when your internet service provider (ISP) blocks their sending port from use by other servers.
Example: If your internet service provider is bellsouth for example and your outgoing mail server is set to mail.yahoo.com or smtp.yahoo.com or mail.yourdomainname.com etc.... it may be getting blocked by bellsouth. The do this to avoid spammers from using their systems.
To fix it, contact your internet service provider and ask what your outgoing mail server should be. For Bellsouth it would be mail.bellsouth.net. Replace your outgoing mail server information with the information provided by your ISP and all should work well.
Here is the link to Microsofts step by step instructions on changing this information in Outlook
Express:
http://www.microsoft.com/windows/IE/community/columns/mailserver.mspx
Oct 16, 2010 | Microsoft Outlook Express
Receive duplicate emails and error messages: pop
Look for your Security Email Firewall settings (Mcafee, Norton , etc ). Got to Email protection > Disable Incoming \ Outgoing mail protection. That should do it.
Mar 31, 2010 | Microsoft Windows XP Home Edition
Can recieve e mails,cannot send or reply to in-comming mail.all messages come up as failed delivery.no problem when first connected
1. Change the settings in your email software so that the email account you're using designates an Outgoing Email Service that your internet service provider won't block. Your internet service provider should provide you with the address of an acceptable Outgoing SMTP Mail Server. This information is often listed on their website; if it isn't, call their technical support and ask them the address of their Outgoing Email Server. Then go into your email software and change your current Outgoing SMTP Address to the one your ISP requires.
2. After you designate a SMTP address not restricted by your ISP, you may still receive the following error:
Port: 25, Secure(SSL): No, Server Error: 530, Error Number: 0x800CCC78
Now you are reaching the Outgoing SMTP Mail Server, but it won't process your request without further authorization. You will need to go into your Email Software and find the setting that indicates that your Outgoing SMTP requires further authorization. Select this setting and enter the username and password required by your ISP (or reqired by who ever is the administrator of the Outgoing SMTP Mail Server that's not blocked by your ISP). For example, at the time this article was written MSN Internet Service's SMTP Address was: (secure.smtp.email.msn.com). However, this email server won't allow you to use it unless you send your MSN username and password along with your request to send email.
Feb 22, 2010 | Computers & Internet
Getting error code for sending e mails from Windows Vista home. Ox8OOCCCOD
Third Party Solution Found: From Microsoft
Error 0x800CCC0D
Problem: When you try to send or receive email, you get an error message. It
says the error number is 0x800ccc0D.
Solution: This error is basically saying that your computer cannot connect
to the mail server. The most common and obvious cause of this is that you
are not connected to the internet at all. To test whether this is the case,
try opening a news web page like news.com or doing a Google search (just
opening your homepage is not a good enough test, because it may be saved, or
"cached", on your computer's hard drive). If this test fails, then the
problem is not with e-mail specifically, but rather with the internet
connection. For users on dial-up, you need to dial in first, and then you
should be able to check your email. If Windows is indicating that you are
already connected, try disconnecting and then dial in again. If that fails,
try restarting the computer and then connecting again. If that fails, you
may have spyware or your modem may have gone bad.
If, on the other hand, you are able to pull up web pages, yet still get
error 0x800CCC0D, you should check to make sure the mail servers are typed
in correctly. To check this in Outlook Express, open the Tools menu, select
Accounts, click on the Mail tab, click on the Properties button, then click
on the Servers tab. Or, if you use a different email program, follow the
equivalent procedure for that program. The incoming mail server should be
pop3.vcn.com unless your email address doesn't end with @vcn.com, in which
case put in whatever your address ends with instead of vcn.com (for example,
if your address is person@wavecom.net, enter in pop3.wavecom.net ). The
outgoing mail server should be smtp.vcn.com or substitute whatever your
email address ends with for vcn.com.
Make sure to check the mail servers for all your mail accounts if you have
multiple email addresses.
If you still get error 0x800CCC0D, and definitely can pull up web pages
(that is, the rest of the internet is working fine, only email is having a
problem):
* Restart your computer. This is simple, so you might as well try.
* Try disabling e-mail scanning in your anti-virus program. To do this
in Norton, double-click on the yellow picture for Norton down at the bottom
of your screen by your clock to open Norton. Then click the Options button
at the top of the window (if a drop-down menu appears, choose anti-virus),
then click the word Email on the menu on the left side. Uncheck both Scan
Incoming and Scan Outgoing. Click OK, then close Norton. Try checking your
messages again.
* Disable your firewall. It could be blocking Outlook Express, or
whatever your email program is, from accessing the internet. McAfee firewall
will usually not turn off even when you tell it to, so you'll have to go
into the firewall settings and delete your e-mail program from the blocked
list, or just uninstall McAfee firewall entirely using the Add/Remove
Programs control panel.
* Make sure you recieve replies when you ping the mail server. If you
cannot, something strange is going on.
* Try checking email using a different mail program such as Thunderbird,
or through webmail on our web site, and see if that works.
Other Cases
You may be able to get mail when you first open Outlook Express, but then
get error 0x800CCC0D from then on. To solve this, go to the Tools Menu >
Options > Connection tab, and uncheck "Hang up after sending and receiving".
Your email works fine, but error 0x800CCC0D keeps constantly popping up over
and over. In Microsoft Outlook, Tools > Options > Mail Setup tab > Send and
Receive, and uncheck "Schedule an automatic send/receive every 5 minutes"
(older versions of Outlook will have a similar option under the Mail
Delivery tab). In Outlook Express, go to Tools > Options, and uncheck "check
for messages every ... minutes".
Shenan Stanley
MS-MVP
Quoted and pasted by Jack Isaacs for FixYa
Hope This Helps.
Jack Isaacs
Jan 29, 2010 | Microsoft Windows XP Home Edition
The mail function works fine on my home wireless network, but won't work on the office wireless network. I've occasionally found this problem with some hotel wireless systems. Other internet functions...
the mail is needing two servers to work:
- pop server to get your mail, you can acces to it everywhere
- smtp server to send mail, you can only use it from your home wifi.
To send mail from evrywhere, you had to go on your provider website
Dec 29, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Send/receive error on 'Microsoft Outlook'
first of all check if you are using the correct account information which include incomming and outgoing mail servers.
secondly disable the firewall of the norton in the norton settings
Jun 23, 2009 | Norton Internet Security 2005...
Blocked outgoing e-mails
It might be because your outgoing port is being blocked by Mcafee. try disabling your firewall (don't worry its only for a little while) and try to send an e-mail.
Apr 17, 2008 | Dell Inspiron E1505 Notebook
Computers & Internet Logo
David Payne
David Payne
