Question about Monster Cable MPA3250SS 3-Channel Amplifier
Monster Amplifier MPA 3250
I bought a Monster mpa 3250 in 2004 and it has worked fine until recently. I had a tech out from Ultimate Electronic and we discovered a hum when the speakers were hooked up. He said it was a ground issue inside the amp and to send it back to Monster. I weighs 100+ lbs. and I would have to ship it from Las Vegas to Virginia for analysis. Any ideas on what I could do myself? I am not electronics savy but have friends who are. Thanks.
  • rrogers1958 Jul 17, 2008
    1) I do not believe the hum was there when the inputs were disconnected.
    2) The hum did get a bit louder with volume increase but not proportional.
    3) These amp (I have another one also) have always run hot so I don't know if it is hotter than normal.
    4) It is on both channels
    5) Just noticed when the tech was out. It could have been there since the first installation.
    6) It is out of warranty
    Thanks for your help.
  • 1,512 Answers
Hi rrogers1958
Not to discount what your tech has already said, there are a few things that can cause hum. Just want to get info direct from you regarding this problem. Then, I can attempt to point you in the right direction if you can provide me with answers of a few questions
  1. is the hum still there when you disconnect the inputs
  2. does the hum increase in vol when you turn up the preamp
  3. does the amp run hotter than normal
  4. is the problem on both channels
  5. did any event or contributing factor induce the hum or did it just start out of the blue
  6. do you have any warranty on the amp
If you could answer these questions for me, then I will convey what I think to you. Cheers
regards
robotek
Posted on Jul 17, 2008
Turn off the led on the front that should take care of the hum.
Posted on Oct 26, 2008
Monster mpa 5150 ss amp
the unit is not able to tune above that channel .
means its a failure of components in the control board.
Jun 29, 2008 | Monster Cable MPA 5150 SS Amplifier
Hi, Bought a 5150 off EBAY new in the box. NOS. After the amp warms up channel 4 (Right Front) starts to distort. Then a minute or two later it goes into protection mode. Shuts on and off repeatedly. I...
You should contact the seller and get them to sought this problem out by supplying you with a new one or getting your money back. If you can't sought it contact Monster.
Jun 27, 2011 | Monster Cable Signature MPA 5150 SS...
Hi i have a mpa 5150 when it warms up their is a static sound on the right front speaker. Any idea what is causing this ?
I have the same problem only its the left front speaker. I took my mp 5150 amp to a professional and he told me the problem is a modulator or the MU-1 part. This is a special part on the board that is designed by Monster and no one will have in stock. Each amplifier in this unit has its own MU-1. I am currently waiting further information.
Nov 03, 2010 | Monster Cable MPA 5150 SS Amplifier
Mpa 5150 continuosly shuts off after around 40 to 45 minutes wiring is good and everything is connected correctly have checked several times what could the problem be
This could be a semiconductor overheating, so when it's left running it acts up. But when cool it plays again. Could be in the power or something that effects all channels. You might be able to find it with Servisol Freezer spray. Wait for the suspect part to heat/act up, then spray it. It should burst into life, when you do so. To be certain apply a soldering iron to it (metal piece). This will cause it to act up quicker, then spray again, to confirm.
Feb 17, 2010 | Monster Cable MPA 5150 SS Amplifier
Looking for manual Realistic MPA-40 35W
I have a realistic mpa-40 35 -watt pa amplifier owner's manual
cat, no, 32-2032A
You can conyact me @ ltlerock@aol.com
Jan 03, 2010 | Audio Players & Recorders
Monster MPA 5150SS
Might be a failing semiconductor component (usually an old transistor) in the amplifier's front end. This caused by the oxidation through the component legs or pin. I usually touch and move each transistor's body to exaggerate the noise. You can research also what kind of noise is it producing- intermittent, static, etc.
hope this helps..
Sep 20, 2008 | Monster Cable MPA 5150 SS Amplifier
As It was mentioned on the premium post, if after removing the fuse(s) from it, the amp powers up and stays ON; the failure is on the transistors or mosfets and they will need to be replace to get the amp working again on channel 4.
I would suggest to contact the manufacturers to get an authorized repair center to fix it under warranty if your amp is less then a year old.
Good Luck.
Jun 30, 2008 | Monster Cable MPA 5150 SS Amplifier
4th channel turns on and then it turns off; 5th channel does not turn on
Hi Alex323a
Nice amps. There is really only one check you can do without getting into the internals of the amp to help you resolve the issue. Disconnect the input and speakers from that channel,and see if it is able to turn on. If are up to it, checking over the poweramp board for that channel for dry or cracked solder joints, and in turn resoldering any you find may fix the problem. If not, the amp will have a problem on that channel and will need a tech to look at it. If it is under warranty still, Monster are pretty good for service I have heard, and they would be your first port of call. Other than that, Call you local HiFi specialist store and see if they can recommend a good audio tech in your area.
regards
robotek
Jun 28, 2008 | Monster Cable MPA 5150 SS Amplifier
Monster Cable MPA3250SS 3-Channel Amplifier Logo
782 people viewed this question
Top Monster Cable Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Monster Cable Audio Player and Recorder Expert? Answer questions, earn points and help others
