Question about Canon Rebel XT / EOS 350D Digital Camera
Printer repair hi, i ve been tryin to install my printer and the usb cable to the back of the printer keeps falling out...how do i fix this...do i need to bring it somewhere
  • 797 Answers
Is the cable connector correct for the kind of cable?
Are you putting pressure on the cable in some way to cause it to pull out of the printer?
Disconnect the printer from the power. Then turn the printer up so that you can inspect the connector. Now compare carefully the connector from the cable to the printer. You should be able to see the problem, if any is there.
Posted on Jul 19, 2008
TSP 700 printer on 32 bit windows 7. It doesn't stop printing and the paper just keep coming out. I've tried to reinstall driver and swapped the printer with the same model with another comput
Check if interface at the back of printer is interchangeable to the type of port your computer will support it. Direct USB to USB or direct connection is recommended to avoid future issues.
Oct 04, 2012 | Star Manufacturing Star TSP700 Receipt...
My printer is a HP- 6210, Message: "remove and
Hello Cliff, welcome to FixYa.
Hard Reset the printer by doing the following:
  • Remove all the ink cartridges.
  • While the printer in ON, unplugged the power cable from the power source.
  • Disconnect the USB cable at the back of the printer (if your printer is connected through a USB cable)
  • Restart your computer.
  • Connect back the USB cable.
  • Plug the power cable to its power source.
  • Turn ON the printer if it does not turn ON automatically.
  • Install the ink cartridges.
  • If the printer prompts for an print head alignment, please do so.
If the problem persists, replace the ink cartridge. The cartridge might be defective since you already have tried to clean the contacts.
Keep me posted.
Jas
Sep 28, 2011 | HP Photosmart 2610 All-In-One InkJet...
Out of the blue my printer stopped working. I've checked drivers. Not sure what else to do
Hi
1. Check first the USB cable connection by unplug and plugging it back the USB cable connections and then check the printer icon if it says READY.
2. Check for the printer driver that might be corrupted. Adding again the printer using the add printer wizard will install new printer for your computer. If still the same, try to uninstall and reinstall the printer driver and then re add again the printer and if it prints the test page, then it solves your problem.
3. Check the print spooler service if it locks up. Try this link to restart the print spooler. http://www.fixya.com/support/r8758623-check_fix_print_spooler_service_causes.
Regards
Jun 29, 2011 | Dell 3100cn Laser Printer
I've put a new printer cartridge into my printer and its keep flashing a red light where the X is i would b grateful if u could send me steps on how to reset the printer and for the new cartridge to...
Please remove all cartridges. Using a moist cloth clean the golden contacts on cartridge as well as printer. DO NOT touch nozzle of cartridge. Dont insert the cartridge yet.
Please do this :
1. Remove the power cable from printer. Remove the USB cable that connects printer to computer (remove it from printer as well as computer's usb port)
2. Press the printer power button and keep pressed for 3 minutes then release
3. Now plug in the power cable and usb cable (connect printer to computer) and power on the printer.
Now insert cartridges and see if error goes away.
You can also click the link below for any future troubleshooting with the printer. It's a self help guide.
Click Here
Regards,
Shrey
P.S. If this did not help, please let me know and will be glad to help you further.
Jun 01, 2011 | HP PSC 1410 All-In-One InkJet Printer
How to manually reset printer
my kodak esp3 printer keeps showing usb port at the back of the printer not conected purchased new usb cable problem not fixed
Nov 28, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
My grandmother recently had her computer repaired and when she got her computer back the printer was not printing. It keeps telling her that there is new hardware, but the printer was installed before it...
I asume the printer is connected wth an USB cable. If you disconnect a USB cable and plug it in, in a different USB port, it will tell you new hardware found. The best way is, reinstall the printer software or let the computer find the new hardeware (Printer)
Oct 03, 2010 | Lexmark P4350 All-In-One InkJet Printer
My psp ver 4.01 is not working. Help me guyz!
psp firmware is corrupted, you be need to continue thats update..
1. update via UMD, the umd that are use must have same firmware version or higher (5.03). check it in other psp. make sure you have a fully battery, then turn on psp.
2. update using sony media go, it a pc client for sony device.. connect psp to pc via usb cable, you will need a internet connection on pc. and it will update to the latest version - 5.51.
hope this help..
Aug 28, 2009 | Sony PlayStation Portable (PSP) Console
Cannot install hp2015 usb printer in windows 98
Make sure you the full install program/download. We're going to back pedal and try it again.
First:
  • Disconnect the Printer cable.
  • Click Start
  • Click Control Panel
  • Click Printers
  • If your printer shows up here, remove it
Then:
  • Run the Install program again
  • Only plug in the cable when prompted to do so
When you plug the cable in it should now recognize the printer.
Best regards,
Mike
Apr 15, 2009 | HP LaserJet P2015 Printer
How to get the usb to work
MCT makes a USB to RS232 9pin adapter. If you need the cable you can buy from them too.
The drivers they provide will help you with your problem. Follow the link, download the driver, and then install.
http://www.mct.com.tw/web_e/html/technology_2.asp?ParentCID=0001
  1. Remove the cable
  2. Install the drivers
  3. Re-connect the cable.
This should solve your problem.
Aug 12, 2008 | Microsoft Windows XP Home Edition
Scanning error - cannot scan error code 2,155,0 ???
Hi
I had the same problem, at first I thought that it was the original drivers (the ones I got with the printer) so I donwloaded the drivers from the canon website, this did not resolve the problem. What I also tried and it worked for me was connecting the printer to the computer with it's original usb cable. I bought a couple of weekes ago a usb extension cable (about 5 m long). With this extension cable I can print but I can't scan any document, it just gives me the same error. Hope this works also for you.
Bye
PS: My printer is a Canon Pixma MP190
Sep 21, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Canon Rebel XT / EOS 350D Digital Camera Logo
21 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
