Question about Sony VAIO VGN-FJ290P1 (VGNFJ290P1R) PC Notebook
It turns off within 5 minutes of it turning on
My computer will not stay on. Everytime i turn it on, it will start up and I can't click on anything and no programs will load. Then it just gets a black screen and turns off. It also gets really hot. I don't think the fan is working. could it be overheating?
Have you checked the battery. I had the same problem, found out that battery wasn't put well. How about you pull out the battery and put it back gain.
Posted on Jul 16, 2008
    Genius:
  • 2,028 Answers
Yes, this could be caused by overheating. If this is due to overheating, it's most likely that the processor has burnt up. You will need to take it in for a professional hands-on diagnostic in order to find the exact cause of the problem. Overheating can cause several different issues within a machine.
How can i have hp psc 1510 driver and valid Win32
Here's the fix:
* First uninstall your current HP installation.*
Step one: Uninstall the printer driver and software
1.
Disconnect the universal serial bus (USB) cable from the computer.
2.
Insert the printer software CD into the computer.
3.
A prompt to uninstall the software displays. Follow the on-screen instructions to uninstall the software.
4.
Restart the computer.
Step two: Turn off the Terminate and Stay Resident (TSR) programs and other background programs
When the computer is turned on, a software group called the Terminate and Stay Resident (TSR) programs automatically loads. These programs activate some of the computer utilities such as the anti-virus software but are not required for the computer to function. Occasionally, TSRs prevent the printer software from loading so that it does not install properly.
In Microsoft Windows 98, Windows ME, and Windows XP, use the MSCONFIG utility to prevent TSR programs and services from starting up.
1. Click Start and then click Run. The Run window opens.
2. In the Open: box, type msconfig, and then click OK. The MSCONFIG utility window opens.
3. Click the General tab.
4. Select Selective Startup.
5. If there is a check mark next to Load Startup items, click the check mark to remove it.
6. For Windows XP systems only - Click the Services tab and place a check mark in the Hide All Microsoft Services box. Select Disable All.
7. Click Apply and then click Close.
8. Click Restart to restart the computer.
Unplug your USB printer cable and reinstall. That's it!
Visit the HP Help Documentation Page for this error.
Here's the text from their page in case the URL for this changes:
Issue
The printer software installation stops and the Printer Driver Unknown error message displays on the computer. This document applies only to products connected with a USB cable.
Figure 1: Printer Driver Unknown error message
Solution: Follow the steps below to resolve this issue.
NOTE: These instructions do not apply to Windows 2000 because the MSCONFIG utility used in Step two does not exist in Windows 2000.
1.
2.
3.
4.
NOTE: This step does not apply to Windows 2000 because the MSCONFIG utility does not exist in Windows 2000.
1.
2.
3.
4.
5.
6.
7.
8.
Step three: Install the product software
Listed below are several options for installing the product software. If the product software CD is not available, HP recommends downloading and installing the product software from the HP Website at www.hp.com.
Method one: Install the product software from the CD
1.
If the product software CD is still in the computer CD drive, remove it and re-insert it in the CD drive.
2.
If the software installation does not start automatically, follow the steps below.
1.
2.
In the Open: box, type D:\setup.exe, where D is the letter of the CD-ROM drive.
Follow the on-screen instructions to complete the software installation.
Method two: Download the software from hp.com
1.
Go to www.hp.com and click Software and driver downloads.
2.
Type the model number of your product in the Search box.
3.
Select the operating system of the computer to which the device is connected.
4.
Click the downloaded software to start the software installer.
5.
Follow the on-screen instructions to install the software.
Step four: Use the MSCONFIG utility to enable the Startup software
1.
2.
In the Open: box, type MSCONFIG and then click OK to start the MSCONFIG utility.
3.
On the General tab, select Normal Startup to automatically enable all features the next time the computer is started. In Windows XP, click the Services tab and select Enable All.
4.
5.
Click Restart to apply the changes to the computer.
Jan 20, 2015 | HP Computers & Internet
After changing my fuel pump i reconnected everything took it for a drive and now when i go to start it i hear a clicking sound from the starter and my security system comes on how do i turn the security...
There is a process known as the computer relearn process. Remove the negative battery cable for 10 minutes. When you reattach the cable turn the key forward to the on position but do not start the carl. Stay in this position for 7 minutes start the vehicle and idle 7 additional minutes. Turn the car off. Turn key forward to in position for 5 more minutes and the job is
Jul 22, 2014 | 1993 Jeep Grand Cherokee
Igniter starts to glow for 3-5 sec while making noise every minute or so
Check the thermocouple it is going bad or already has and that is why the gas valve is not staying open.
Jul 08, 2017 | Whirlpool GGW9200L Gas Dryer
Cannot programme to anything but a cold wash
The computer switch needs replacing (start control)
Jan 21, 2018 | Beko Dishwashers
Program tries to load every .dll file on my hard drive upon booting up
Dll errors occur due to various reasons incomplete installation or removal of a program, missing, corrupt, or incorrect .dll file paths, and more. Failure to fix these errors can result with severe PC problems click start right click on my computer you should see your drive usually C: select properties click tools check now tick both boxes automatically fix files and scan for and attempt recovery on any bad sectors or you could tick one box and wait until its finished then return and tick the other box then select check now start should schedule this task when restart do not do anything while the chkdsk utility is in progress any input may damage your computer also download a registry cleaner http://download.cnet.com/jetclean/3000-18512_4-75627788.html JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again. Hope it helps.
Dec 27, 2012 | Sony ACID Music Studio 9
Hi, I have a Pontiac Montana 2003 for a year and is running well, it has 148000 km. Today I went from Toronto to Niagara Falls and park my car for a couple of hours and when I turned on the engine the...
replaced the oil and re set computer to fresh oil change
thes older models will only go aproxamitly 5000k on oil change
it may not have been reset at last oil change
key on run motor off depressed gas pedal to floor 3 times within 5 seconds of key on run
then start motor to re set oil life system
Apr 09, 2011 | 2003 Pontiac Montana
Everytime I turn my computer on it will freeze
You have a corrupted registry, try rebooting and depressing the F8 key to access safe mode..you will see a black and white screen with boot choices.
Choose "best last boot config" reboot and hope for the best.
If still no go reload windows with the disk and choose option "Reload windows WITHOUT FORMAT". It will replace windows and retain all you saved files. HOWEVER, you will need to reload all other programs, eg Office suite, games etc
Apr 30, 2010 | HP KT334AA Pavilion Media Center M8530F...
How would I reset my 2001 Grand Am Gt! The security light stays on when I turn it to on....and no gas is getting to the engine! So everyone says that I need to reset it! BUT DONT KNOW HOW TO?
Turn key to run, click the engine but do not let it start then relax back to the run position. You will now see the security light on
After about ten minutes light will go off.
Turn key off and back on to run within 5 seconds
Repeat above procedure for a total of 3 ten minute relearns.
After done turn key off and Then start engine.
Dec 02, 2009 | 2001 Pontiac Grand Am SE
Sony VAIO VGN-FJ290P1 (VGNFJ290P1R) PC Notebook Logo
238 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
