Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
WASHER IT WILL FILL WITH WATER . BUT WILL NOT WASH OR SPIN. BUT YOU CAN HEAR THE TIMER BUZZ.
    Problem Solver:
  • 6 Answers
Tip the washer over forward so you can look underneath it. Check to see if the belt is secure and tight. Have you tried advancing the cycle knob on the control panel ahead one click at a time manually? Sometimes they get stuck between function settings.
Posted on Jul 29, 2008
Washer tub does not move to spin or wash
You either have a bad solenoid, timer, loose belt, or water level sensor.
Dec 15, 2013 | Haier HLP21E Top Load Washer
Washer will fill and drain but will not wash or spin
you have a motor problem. do you hear the motor working? if so it may just be the belt.
Nov 11, 2013 | GE Washing Machines
Hello. I have a Amana top laod washer. My washer will spin(i can hear it spin and see it shakes as it spin). My washer will not fill with water when I turn it to a washer cycle. No water will fill in this...
If you're not getting any water (hot or cold), you'll need to check voltage coming to the solenoid valve. This is the valve the hoses connect to on the back of the washer. If you're not getting voltage during the fill cycle, your timer is the most likely culprit.
Jan 01, 2018 | Amana Washing Machines
Hello. My washer kemnore Mod. 110.29822800 NO WASH
Sounds like the timer is faulty and needs to be replaced.
Jul 16, 2010 | Kenmore Washing Machines
Washer doesn't work and the water doesn't come on.
Check the water valves work, fill then wash, then drain then spin, if it doesn't fill it won't wash
Nov 12, 2009 | Maytag LSE7806A Top Load Stacked...
Front load kenmore washer model 417 will not enter any wash cycle. It will do the rinse and spin cycle but not a wash
will it fill with water? if not listen by the water hose when you press start to wash and see if you hear a faint buzz/humming sound. If so you need to replace the water inlet valve. cheers
Mar 25, 2009 | Washing Machines
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Washer will not fill
not your timer / if anything its eather the water valve or the water slector switch
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer model 110.49722990 it will not go into the drain or spin part of the cycle, just sits there and hums, won't do anything. It will fill with water and wash,but thats all it won't finish the...
Does it fill with "cold" water?Will it spin?Drain?If the machine will fill up with cold water,will the timer advance by itself to finish?Or if you place the timer in spin cycle will it spin?First off if your not getting "Cold" water to fill inside :Replace the water valve (because when the timer stops after the agitation cycle it wont advance because it cant fill up with cold water.
May 23, 2008 | Kenmore Washing Machines
70 series Kenmore washer
POWERUP, YOUR WASHER COULD BE THE LID SWITCH OR THE COLD WATER VALVE. AT THE END OF THE WASH CYCLE, THE MOTOR WILL SPIN OUT THE WATER, BUT ONLY IF THE LID SWITCH IS ACTUATED. IF THE SWITCH IS BAD, IT WILL NOT SPIN OUT THE WATER AND THE TIMER WILL NOT ADVANCE FROM THAT POINT.
IF THE WASHER SPINS, THE NEXT STEP IS TO FILL WITH WATER FOR THE RINSE CYCLE. MOST WASHERS USE COLD WATER FOR RINSES. IF THE COLD WATER VALVE IS RESTRICTED OR FAULTY, THE WASHER WON'T FILL. IF THE WASHER WON'T FILL, THE WATER LEVEL SWITCH WON'T ACTIVATE AND THE TIMER WON'T ADVANCE TO THE NEXT STEP.
Mar 31, 2008 | Kenmore 22422 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
44 people viewed this question
Dan Webster
Dan Webster
Sal De
