Question about Dryers
Dryer takes too long to dry clothes. it usually takes two complete cycles to dry . ( dryer is a kenmore approx. 3 years old, but out of warranty
  • rich_cox54 Jul 19, 2008
    thanks so much for the input. my problem was an air flow issue. my dryer vents from the roof, and the screen on the vent was completely clogged. i cleaned it off and the dryer works perfectly.
    again, thanks so much for the help.
  • 481 Answers
This is an airflow problem. make sure you are using a rigid metal duct behind the machine and not a flexible one. clean out the exhaust duct behind the dryer and in the wall all the way to the  outside. any residue of lint inside these ducts will increase drying time dramatically. basically clean everywhere the air flows.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Posted on Jul 16, 2008
Taking to long to dry clothes
How long does it take you to dry your clothes? Normally, it takes 50 minutes (1 cycle) to 1.5 hours to completely dry clothes. However, if it's taking you at least 3 cycles (probably 2.5 to 3 hours) to dry a single batch of clothes, then, there might be a problem with your dryer's igniter.
Jan 09, 2014 | Speed Queen AGS17AWF Gas Dryer
Dryer heats up, but does not dry clothes. Vent is clean
As you can see, your heating element has 5 heating coils. If one or more of these coils have opened you dryer will still work and heat but not at well as it would if all coils worked together. You can check each coil with an ohm meter to verify if one or more is open.
Jan 01, 2012 | Kenmore 64742 Electric Dryer
The Dryer heats up but does not completely dry clothes. It takes 2-3 cycles to dry them.
If your
dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about
Dryer Maintenance
heatman101
Jan 30, 2011 | Kenmore 63942 Dryer
My kenmore 70 series dryer will not heat upa nd
bad ignitor
or bad solonoids on your gas vale
check your lint filter
and exhaust outside to be clear of cloggs with good airflow while running
Oct 05, 2009 | Kenmore 73952 Gas Dryer
Model/stock #...66904/669. Having to run 3-4 cycles to completly dry clothes
Sounds like your problem could be the thermostats or the heating element, they will normally cause the dryer to take a long time to dry the clothes
Sep 26, 2009 | Kenmore Dryers
2 to 3 cycles to fully dry clothes
if the clothes are warm after the cycle then you need to make sure the vent to the outside of the house is not plugged if they are not warm then it is in the heating circuit of the dryer wether it be the element or a fuse will have to be tested. to dry clothes it takes heat and air flow if you dont have one of the two they will not dry correctly
May 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
It takes my whirlpool dryer three or four cycles to dry clothes
Kenmore Dryers are almost all the same therefore am sending this;
http://www.youtube.com/watch?v=lHkIK8oy1K4
How to Clean a Dryer Vent Video
http://www.youtube.com/watch?v=5Dj4im31lRY&feature=related
Why is so inportant to clean the lint?
http://www.youtube.com/watch?v=9kxbF31Oh4s&NR=1
It was helpful?
May 15, 2009 | Whirlpool Dryers
Poor drying quality
repl/ thermistor, also remember that these dryer have smart sensor drying,, there are 2 metal strips inside use rubbing alcohol and clean this will fix your probablem
Jan 02, 2009 | Kenmore Elite HE4 Electric Dryer
Gas smell from dryer
your igniter needs to be replaced.
Jan 26, 2007 | Kenmore 74842 Gas Dryer
Dryers Logo
107 people viewed this question
Top Dryers Experts
