Question about Volfenhag ZX-8200 Car Audio Amplifier
ZX-8100 I have a ZX-8100 that has a blown transistor (Q43) but, it is burnt so bad I cannot identify any numbers on it. Do you know what it is or where I can view some schematics?
  • mikedef Jul 16, 2008
  • 631 Answers
I'm not familiar with that particular amp but generally, the only transistors that burn are the ones in the power supply. If the adjacent transistors had numbers like IRFZ44, IRF3205 or similar, the burned transistor is likely the same as the ones next to it.
Confirm that the center and right-most leg of the burned transistor and the transistor next to it are directly connected by large traces on the circuit board. Also confirm that the center leg goes to the large windings of the power transformer. If it passes these tests, the transistor is one of the power supply FETs. The numbers on the adjacent (parallel connected) parts will be the same as the burned one.
Posted on Jul 17, 2008
Does the remote bass control have to be hooked up on a volfenhag zx-8100 for it to work
No, it's only use to control the gain or level from zero to what u set it to
May 28, 2015 | Volfenhag ZX-8100 Car Audio Amplifier
Value of a transistor at the amplifier sction
Transistors don't really have values, just a number on them. Most Japanese transistors are numbered with a letter first, A, B, C, K, and then a number. When searching for a replacement you add the this at the start "2S" so 2SB500 for one marked B500. If you can't read a number due to damage, with stereo amps the two channels are the same. So if the left channel transistor has burnt up look at the right channel one, you will quickly see the parts around it will be arranged the same as the blown channel.
Feb 08, 2014 | Audio Players & Recorders
Channel A on my PMP 1280s is blown
This website appears to have diagram for it. You will have to register to log in. http://elektrotanya.com/?q=hu/content/how-change-site-language-english
May of been some other component burnt out. Only way is by test meter and testing. Quite possible transistor burnt out.
You should be able to test it in circuit for Short circuits.
If output transistors faulty make sure you check driver transistors as well. Hope some of that helps.
Nov 19, 2013 | Audio Players & Recorders
AVR2106 blown channel parts list
Though any transistor(s) might well have gone and the capacitor could be changed, I see no reason to change any resistor unless it's burnt up or giving an incorrect resistance reading. A multi-meter will tell you if a resistor is working or not, if it's not dead or weak it won't make a lot of difference to the circuit, but replacing it will simply cost you more money!
Apr 05, 2010 | Denon AVR-2106 Receiver
Zx-8100 amplifier is red lighting.
try wiring them differently. here is a link for u to go to http://www.crutchfield.com/learn/learningcenter/car/subwoofers_wiring.html . once there find your amp configuration (ie. mono, or 2 channel) then down to the type of subs an how many subs ( ie. 2 dvc (dual voice coil) 4 ohm subs) an that will show u how the subs should be wired and wired to the amp.
Mar 21, 2010 | Volfenhag ZX-8100 Car Audio Amplifier
Power transistor number
Hi again! Been thinking about this and you might not need to wait for someone to answer. I assume the transistor in question has blown apart or burnt up so you can't read the number?
However does it come off the heatsink as part of the main amp? If it does then it might have a brother around it. For if it is say the left or right channel transistor, then the other channel will have the same type transistor. Remember the left and right channels are copies of one another. If you see 4 transistors on the heat sink then it's a push-pull amp. They work in pairs, one pair for each channel. By the way it's best to replace the pair, even if only one is blown.
If on the other hand the blown transistor is from the power supply section, then you will have to wait for someone to help, or get the service manual.
Jan 24, 2010 | Audio Players & Recorders
Need help please...
If you unplugged the fuses, the amp won't come on at all. I'd say its a blown transistor, you can test this by opening up the amp and using a multimeter to check resistance on the transistors.
Aug 03, 2009 | Volfenhag ZX-8400 Car Audio Amplifier
Mitsubishi CS-40503 Zapped by high voltage
the only option is to bring your x-former as sample or take a pic of it and post it.
Mar 26, 2009 | Mitsubishi CS-40503 TV
Tv will not come on
HELLO. it sounds like it could be a couple of things why your set will not come on. 1. you could have a blown fuse.on the chassis. 2. you could have a bad power supplly transformer. 3. you could have a bad horizontal output transistor and a bad fly back transformer. it could be one of them or both of them as well as a blown fuse. because the fuse is blown from the horizontal output transistor burning out or the fly back transformer burning up. check and see if you have a burnt fuse, the size iof the fuse will be 5 amp to 6.3 amp fuse on the chassis right inside where the 110 ac cord comes in and hooks to the chassis. the fuse should be right there, look for it. hope this helps you"GOOD LUCK"
Aug 09, 2008 | Televison & Video
No power.its plugged into the outlet and it works. red power buttom not on tv
Volfenhag ZX-8200 Car Audio Amplifier Logo
119 people viewed this question
Top Volfenhag Car Audio & Video Experts
Robert Rankin
hoyzee1
Are you a Volfenhag Car Audio and Video Expert? Answer questions, earn points and help others
