Just purchased 2000 model accent for my daughter, gear change is nice and smooth however when workind back to slow down going from 4th to 3rd it seems to be sticking there is a slight crunch sound what could this be please
When you press in the Overdrive (OD) switch, this simply allows your gearbox to use the highest gear (when it needs to). For example, if your transmission has 1,2 & D gears, the OD acts as a 4th gear. This is useful on open roads and will help with economy.
If the OD light remains ON, then you have deactivated the 4th gear. This means the car will change up to 3rd gear only, until you depress the OD switch again.
Deactivating the OD is useful, when you wish to "manually" change down to 3rd gear, to climb a hill, or need better acceleration.
Probably a shift solinoid in the gear box. My commodore has 2 (1st & 2nd) & (3rd & 4th) my 3 / 4 solinoid went so went 1st 2nd 3rd but not to 4th until I replaced it.
if you used the car with a bad cluth you may have damaged the syncromesh, it nearly always happens in 3rd gear. Sounds like the fault, the syncromesh is part of the gearbox and most often cannot be fixed without a new gearbox.
CHECK ENGINE light??? Whenever the 'CHECK ENGINE' (Service Engine Soon) light comes on, the ECU (Engine Control Unit) sets a Diagnostic Trouble Code (DTC). These codes identify the particular engine management system which caused the light to come on.
You'll need to use/find an OBDII (On-Board Diagnostic) Scanner to retrieve any code which have been stored in the ECU computer. Afterward, we might be able to help you DIAGNOSE the problem and perhaps eventually fix the problem.
hi fro uk this is a common problem on many cars not just hyundai and ita most common cause of synchro mesh failure on2nd and 3rd gear is believe or not a bad driving habit! it goes like this when you set off in 1st then cange up 2nd gear whilst accellerating holding gearstick? in back position then change up 3rd gear still holding gearstick! in a forward position then? when up to 4th gear we let go of gearstick?? now just by holding g/stick whilst in 2nd and 3rd the slightest pressure also brings the synchro ring into play whilst gear already selected! so inevitably the synchro ring wears away to extent that they no longer work properly so the gearbox is none synchromesh on 2nd 3rd gears and on occasions? on 5 speed box 4th gear can become a victim ? hope you understand ? just quietly observe some peoples habits with manual boxes? as for repairs?cost? this is not a difficult job to replace all synchro rings but box has to be stripped and assesed ? the cost could escalate? but if you want quick turnround? a matter of hours? a recon box with warranty? is other option ? BUT would not advise risking a 2nd hand box probably worse or same as ? whichever choice you take you can check clutch at same time if milage is high? now some good advice! personally this is not a dire problem just a niggleproblem which if you take time in changing gears you can o/come gritty gear change save money for now till it is more affordable ? if you know any old timers truck drivers ? these are the guys who will show you how to drive /change gears none synchro mesh before it was ever invented ? hope this helps daughter but practice on gears and rid of the bad driving habit so many do not realise they have will make her a better experienced!driver
I read your problem, and I think Reliable-Store has the solution of your problem, Just visit the link I attached here, I'm sure you will get the solution of your problem forsure. Best Manuals
