Question about Timeslips 11 (TSW11RT) for PC
Yellow or red envelopes next to slip entries
I am not the administrator of our software but cannot get a straight answer from our administrator about what the yellow or red envelope designation next to a slip entry indicates. Oddly, some slip entries have no envelope next to them yet I find the slip entry has in fact been billed and sent to a client. I am sooo confused..
2 Suggested Answers
iqbal_del
  • 655 Answers
SOURCE: Slip Entries Printing out of Sequence
try to see in manual.. there should be details how to use.
Posted on Apr 26, 2008
Provider entry msafd tcpip could not perform simple loopback communication error 10050
click start control panel administrative tools computer management then select event viewer depending on what operating system you have this may vary
extend the events there you will ((see errors in red)) you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
you will have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled or
you could click start control panel administration tools computer management device manager look for network adapters + expand Ethernet driver if you see a yellow question exclamation mark or a red X you will need to update/reinstall the driver for the device if you computer came with a motherboard disk the driver could be on it
hope this helps
Nov 19, 2011 | Microsoft Windows XP Professional
Certificate file missing
1. Fix registry permissions
a. Click on "Start" choose "Run", then type "regedit" and click "OK".
b. In the Registry Editor, click on the "+" next to "HKEY_Local_Machine".
c. Now click on the "+" next to "Software".
d. Right-click on the key (folder) called "Roxio" and choose "Permissions".
e. Make sure that "Administrators" and "System" have checkmarks for "Full Control" - "Allow".( This does not apply in win2000!)
2.
f. If you had to add those checkmarks, click on "Apply".
g. Click on "Advanced".
h. Put a checkmark in "Replace permission entries on all child objects with the entries shown here that apply to child objects".
i. Click "OK".
j. Click "OK" again.
k. Now close the Registry Editor
Sep 19, 2010 | Roxio Easy Media Creator 10 Suite
How to get tv to work with dvd player
You need a RCA cable with 3 heads : yellow, red and white. Then you must connect the corresponding yellow, red and white connectors from the dvd player (on the back)  to the tv (on the left side) - just make sure all the connectors are next to each other in the same box. The al you have to do is to play a disk and select the correct AV entry from the remote of the tv.
Aug 17, 2010 | Olevia 227-S11 27 in. LCD TV
Ink is smudged on envelope. How do I stop that from happening?
i bet you're printing in Black,
what happens is when black is selected, the 3 colored drums lift up 2 mm annd only the K drum is engaged, amd there is no static in the transfer belt under the CMY drums.
envelopes have air in them and can bounce along the bely after the black has printed, and seeing the toner is powder and not yet fused on, the toner touches the cyan drum as the envelope hits the fuser entry point as well as dragging on the Left transfer belt Blue lift handle(take out the belt and spring the handle off).
If you open the lid in this print mode, and lift out the cyan drum, turn it over and pull back the cover for the OPC drum, you will see the black toner on the green drum.
FIX 1. In the art work place a tiny dot of yellow. this will run the print mode in color and enagage all the drums. gaurantee your print will be fine, and know one ever sees that yellow dot.Problem is, this then runs down your CMY drums for black only printing.
FIX2.
If you have a later machine, downlaod iQueue from Xante.com (free) fantastic software. and get the machine updated with the latest X1.11 firmware from your dealer.
This allows with iQueue, to set the machine to print Black only, and you run the machine without the CMY drums installed....it works, it's great...
Aug 10, 2010 | Xante Ilumina Digital Color Press Printer
When I print bills, it says "4 bills prepared and not printed"?????
When you prepare bills, you can set your options to only print bills that have activity. However, there may be clients in your criteria selection that do not have any new slips to bill, but you may have posted payments. You will not be printing bills for the clients that only have payments but no other activity. Even if you do not print the bill, the program "processes" the clients with the payments, so you will see the "yellow envelope" next to the client payment, even though you are not sendin them a bill
Jul 23, 2009 | Timeslips 2005 (tsw2005rt) for PC
LEXMARK X1240 WON'T PRINT ENVELOPES
I was so pissed off that so many on the web had this same problem that I spent many hours trying to get it to work. I am sure that this is not how it is designed to work but my envelopes got printed.First I went under File, Print, Properties to Page Set-up for envelope #10. I also ********** print colour images in black and white which someone else had suggested- although it might not be necessary. I selected quick print but normal should probably work too. I then closed out these two windows. Then under tools, I selected Letters and Mailing, then envelopes and labels, typed in the addresses, went under options and changed the feed from automatic to default tray, which automatically changes the feed method to the 4th one out of 6 which wasn't what I wanted but ignore it. Check off face up. Putting the envelope into the printer was bizarre- it has to be inserted very far into the printer until only 2-3 inches of the envelope stick above the horizontal surface of the printer. It must be inserted into the middle of the paper holder, until it is just 2-3 inches sticking up, and then slide it all the way over to the right where the printer indicates the envelope should be- nice and straight against the right margin. Do not use the movable paper holders that they suggest you swing over to the right to hold your envelope- or printing won't occur for some odd reason. Press O.K. on envelopes and labels and then press print. Good luck- it worked for me.
Jun 01, 2009 | Office Equipment & Supplies
Envelopes print in color and I want black only
First you need to change the settings in the software you are trying to print the envelope. Open the program (for example MS Word), go to the option from which you print envelopes and labels. Set the font color to black, not "automatic", and in Word, click "default", which sets the color as black rather than allowing the printer or its software to select the wrong color. Then try to print on the envelope and let us know if you are able to print the envelope in black only.
Apr 20, 2009 | Office Equipment & Supplies
I bought a second hand nano not working
Locate the iPod in Device Manager
  1. Connect iPod to the computer.
  2. Quit iTunes if it launches.
  3. On the Start menu, click Control Panel.
  4. In Control Panel, open Administrative Tools. Note: If you don't see Administrative Tools, look at the left column in Control Panel for a link that says, "Switch to Classic View," and click it.
  5. Double click the Computer Management shortcut.
  6. In the left column, click on Device Manager.
  7. In the right column, click the plus (+) icon next to Universal Serial Bus controllers to expand this selection. ts1538_1.jpg
  8. Locate the iPod in this list. In some cases one of the entries will have "iPod" in its name. If no such entries are present, the iPod is most likely represented by "USB Mass Storage Device." ts1538_2.jpg ts1538_3.jpg
Note: A red "X" appearing next to the iPod's entry in Device Manager indicates this device is disabled. To enable this device, right-click its entry in Device Manager and choose Enable from the shortcut menu.
ts1538_4.jpg Update the USB driver
  1. Right-click the iPod's entry in Device Manager and choose Update Driver from the shortcut menu.
  2. In the Hardware Update Wizard that appears, select "Yes, this time only" to allow Windows to connect to the Windows Update Website. Click Next. ts1538_5.jpg
  3. Select "Install the software automatically (Recommended)" and click Next. Windows searches for updated drivers and installs any it finds. If Windows is unable to find updated drivers on its own, continue with step #4.
  4. Click Back.
  5. Select "Install from a list or specific location (Advanced)" and click Next.
  6. Select "Search for the best driver in these locations."
  7. Select "Include this location in the search" and type the following in the field below: C:\Windows\INF ts1538_6.jpg
  8. Click Next. Windows searches this location for drivers and installs any it finds. If Windows is unable to find updated drivers on its own, you must reinstall the USB drivers as shown below.
Note: During installation, if a message appears stating that the software you are installing "has not passed Windows Logo testing" click Continue Anyway to continue installing the drivers.
Reinstall USB driver
  1. Right-click the iPod's entry in Device Manager and choose Uninstall from the shortcut menu. ts1538_7.jpg
  2. In the resulting dialog box, click OK.
  3. In the Device Manager window, right-click Universal Serial Bus controllers and choose Scan for hardware changes from the shortcut menu.
ts1538_8.jpg Windows automatically reinstalls the necessary USB drivers and attempt to remount the iPod.
Try these and reply me about the current status of the ipod..
Feb 11, 2009 | Apple iPod nano 3rd Generation
How to print an envelop
nstructions Use the following steps to ensure that you are ready to print envelopes. Your printer can have either a single envelope or multiple envelopes loaded and ready for printing.
  • If you are printing a single envelope, you can use the single envelope slot and leave your paper in the lower (IN) tray. This allows you to print the envelope and then a letter.
  • If you are printing a stack of envelopes, use the lower (IN) tray for loading the stack of envelopes.
To Load a Single Envelope
  1. Do not remove the paper from the lower (IN) tray. Be sure the card guide is in the down position, before using the single envelope slot.
  2. Remove a single envelope from its packaging.
  3. Slide the envelope evenly into the single envelope slot. The single envelope slot is located on the right side of the upper (OUT) tray. The envelope should be loaded with the address side down (flap side up).
  4. Make sure the creased flap edge of the envelope aligns with the right side of the single envelope slot.
  5. Slide the envelope through the slot until it stops. Make sure the envelope is not bent and is straight in the envelope slot.
    NOTE: To minimize print skew, use envelopes with rectangular flaps rather than triangular flaps.
To Load Multiple Envelopes
  1. Slide the paper width adjuster to its leftmost position.
  2. Pull out the paper length adjuster and remove any paper from the IN tray.
  3. Remove up to 20 envelopes from their packing and tap the short edge of the envelopes on a flat surface to even the stack.
  4. Slide the envelopes evenly into the IN tray, address side down (flap side up).
  5. Slide the paper width adjuster to the right until it gently touches the left edge of the envelope stack.
  6. For size Invitation A2 and C6 Envelopes, press the inside of the paper length adjuster handle to release and lower it.
  7. For all sizes of envelopes, push the paper length adjuster in toward the envelopes until it stops. Make sure the envelopes are flat in the lower tray and not bent.
Set up the Printer Properties
  1. Select Start on the taskbar. Choose Settings, then Printers. Right-click the printer. Select Properties from the pop-up menu.
  2. Select the Paper or Setup tab depending on the version of the printer driver software.
  3. In the Paper Options section, select the desired envelope size from the Paper Size drop-down box.
  4. Click OK.
Print Print the envelope from your chosen program. From most applications, just select the File menu, then choose Print. After Printing the Envelopes Reset the printer and the printer properties for the kind of printing you will be doing next.
  1. Remove any remaining envelopes from the lower (IN) tray.
  2. Slide the paper width adjuster to its leftmost position.
  3. Load the desired paper into the lower (IN) tray.
  4. On the computer, Select Start on the taskbar. Choose Settings, then Printers. Right-click the printer. Select Properties from the pop-up menu.
  5. Select the Paper or Setup tab depending on the version of the printer driver software.
  6. In the Paper Options section, select the desired paper size from the Paper Size drop-down box.
  7. Click OK.
Jan 19, 2009 | HP LaserJet 1600 Printer
Printer
This would depend upon the software you wish to use. For instance MS Word has an envelope printing utility built in. Access it through TOOLS > LETTERS & MAILINGS > ENVELOPES & LABELS, use the HELP feature to read help info on the settings required. If you wish to use a simlple text editor like Word pad, simply set the PAGE SETUP settings to reflect the media you are using; for instancce set paper size to ENVELOPE C5, and then the margins to something like Left = 60 Right = 100 Top = 80 Bottom = 50 Click OK and this will then mean when you print your document the text will be kept toward the center of the envelope. Change the envelope and margins to whatever suits you best. Slip the envelope into the printer (face up and flap to the bottom) and push the guard up. You should be good to go.
Mar 27, 2007 | Epson Stylus Photo R220 InkJet Printer
Timeslips 11 (TSW11RT) for PC Logo
81 people viewed this question
Top Timeslips Computers & Internet Experts
Iqbal Husain
Iqbal Husain
Neal Marrison
Richard Daigle
Are you a Timeslips Computer and Internet Expert? Answer questions, earn points and help others
