Question about HP Computers & Internet
I RECEIVED AN E-MAIL TYPLE PERRY IT HAD A VIDEO CLIP WHEN I TRIED TO PLAY IT. It would play and stop play and stop every time i try to play a video it does what is the problem I BOUGHT THIS COMPUTER 8-O7- 07 I HAD THIS PROBLEM THE WHOLE TIME
    Problem Solver:
  • 63 Answers
I wonder if you're having an issue with just this specific video clip or all video clips? If it's just one video clip then I suspect htat it's a file corruption with this one clip. Have the person who sent it to you resend.
Posted on Jul 17, 2008
I can't watch Youtube videos, and I can't see the ebooks in "Borders" on my Nextbook 2
In your app store search for vlc player. Install and next time you click on a video if it gives you the option select play with VLC
May 31, 2013 | Nextbook Next 2 E reader
Can you please tell me how to delete individual frames without deleting everything. I have had a bad experience and don't want to repeat it. I can't find my manual....Thanks
Video clip cutting (extracting)
Display the video clip from which you wish to extract a segment.
Display the NORMAL Mode
Playback Menu (page 37), select
"EDIT VIDEO, and press the
button.
Select CUT!! and press the SET
button.
The Cutting Screen appears.
Specify the start point of the extract.
Use the procedure below to specify the frame from which the video clip extract will start.
• Play the video clip until approximately the desired point, pause the video clip, then play the video clip one frame at a time, stopping at
start point of the extract. This will be the first frame of the extract.
• If the start point of the video clip is also the start point of the extract, proceed to step 5.
Play:
After pausing playback, press and hold the SET button to the right
about 2 seconds for forward playback, or to the left for reverse playback.
Pause:
During playback, press the SET button.
Accelerated playback:
During playback, toggle the SET button to the left or right to change the playback speed.
Single frame:
After pausing playback, toggle the SET button to the right to move forward one frame, or to the left to move back one frame.
5
Toggle the SET button up.
• The start point of the video clip
extract is set, and the screen
•Specify the end point of the
extract by following the same
procedure as in step 5.
a. Toggle the SET button down.
Each time the SET button
toggled down, the sections
delete and the sections to
save are reversed.
b. Specify the end point of the extract. The frame following
end point of the extract will
the start point of the latter portion to be joined.
6
Press the VIDEO CAMERA button.
A screen appears for you to select either to save the edited video clip as a new (separate) file, or to delete the original video clip and replace it with the edited video clip.
SAVE AS NEW:
The edited video clip will be saved as a new file. The original video clip remains unchanged.
OVERWRITE:
The original video clip will be deleted. Only the edited video clip will be saved.
REVIEW CLIP:
Play back the edited video clip before saving it.
7
Select the desired option, and press the SET button.
• Editing starts.
• When editing ends, you are returned to the NORMAL Mode Playback
Menu.
I think this is what you are after if this isn't what you need you can find the manual at
http://www.retrevo.com/support/Sanyo-VPC-CG9-Camcorders-manual/id/18378dj397/t/2/
Jun 17, 2011 | Sanyo Xacti VPC-CG9 Digital Camera
How do i play whats on the memory card nothing plays video only audio. or what do i need to convert it
First, make sure you have it on CARD (and not DISK), and on the "playback" (and not record) mode. Next, does the camera play back other video clips normally, but just not a specific clip ?
Does the selected video clip frame (index) shown on the LCD screen have a picture ? If not, i.e. it is blank (dark), then it is likely that no video was recorded (i.e. just the audio) when you were shooting that video clip.
If there is a picture (of the video clip frame index on the LCD screen) and only audio is playing, try downloading the clip (from the SD card) to your computer, or simply try to play the video on the SD card (inserted directly into your SD card reader on your computer, or via a USB SD card reader) and see if the video clip will play normally on your computer.
Jan 09, 2011 | Samsung SC-DC173 DVD Camcorder
How can i watch video from Samsung s1050 in my computer?
Hi, Here is the procedure on how to play the video clip on your camera. Play mode If you have turned on the camera by pressing the POWER button, you can press the PLAY MODE button once to switch to Play mode and press it again to switch to Recording mode. You can turn the power on with the play mode button. The camera is turned on in play mode. Press the play mode button again and the camera will be turned off. You can set up the PLAY mode function by using the camera buttons and LCD
monitor. Playing back a still image
1. Select the PLAY mode by pressing the play mode button.
2. The last image stored on the memory is displayed on the LCD monitor.
3. Select the recorded movie clip and press the Play & Pause button to play back.
- To pause a movie clip file while playing it back, press the play & pause button again. ac0dd93.png
- Pressing the play & pause button again will cause the movie clip file restart.
- To rewind the movie clip while it is playing, press the LEFT button. To fast forward the movie clip, press the RIGHT button.
- To stop playback of the movie clip, press the play & pause button, and then press the LEFT or RIGHT button. 0e83d9c.png
Apr 13, 2010 | Samsung S1050 Digital Camera
How can I video with the memory chip in my camera GR-DX307
Insert memory card, set to camera mode and set to memory, then hit the E-MAIL/INFO button and then you can press rec start/stop button as if your are recording on tape. It is a low quality video(email clip). To play, slide the power button to PLAY and press select(beside E-MAIL Button) and choose E-MAIL CLIP. Thats it. Good Luck
Mar 09, 2010 | JVC GR-D370 Mini DV Digital Camcorder
I am not able to play any video file in my sigmatel-t33i mobile
ur phones video format is china avi (.avi) try it if u not have any converter then send ur mail address i give u ok now say thanks
Aug 30, 2009 | Cell Phones
FLIP VIDEO f260B
Return it for a refund.
Jul 23, 2017 | Pure Digital F260B Camcorder
When i go on you tube or try to down load any video and play it the video skips and stops (video stops) starts again but never plays all the way through without some tpye of interuption. when the video...
hai from your mail i have understood that you are having some troubles on playing clip that is downloaded from youtube.i thing flash player 10 that you use will not be installed properly.kindly check your instalesion progress and reinstall it.hope the provided information is help full.thank you for contacting FxYa.com
Mar 21, 2009 | YouTube Videos
Showing a video clip
Sounds like it could possible be a codec problem on the computer http://www.free-codecs.com/ try there for the appropiate codec for the file type your trying to play hope that helps
Mar 22, 2007 | Canon LV-LP18 Projector Lamp for - LV7220,...
Computers & Internet Logo
44 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
