Question about Proscan PS36500 36" TV
Vertical line picture
Thanks in advance
my proscan TV 36 in ( 10 years old ). Suddenly the picture went to a narrow verical line - you can see the colors are working and sound is just fine
there is no vertical line adjust on the outside of the unit like very old TV's had
Any ideas much appreciated
  • 89 Answers
Problem is caused by the loss of horizontal deflection signal. It is quite surprising that the entire unit is still working, since usually, a loss of H-Out will disable the entire set. Problem can be as simple as loose solder connection to a more complicated defective horizontal circuit. I would suggest havint it checked by a professional TV tech.
Posted on Jul 17, 2008
My 3 year old Proscan 42" LCD TV picture suddenly
On the far left and right inside the back on panel are inverter boards. Replace or look for capacitors buldged, swollen, or cracked on their tops. Replace defective caps with original value and make sure replacements are 105 degree for longevity. Common problem, let me know if this helped.
Sam Farrell
Feb 17, 2011 | Proscan 42LA45H 42 in. LCD TV
Tv is about 4 years old. Suddenly developed two
Your plasma screen is made up of 1080 verticle lines and now a few of these lines are not working. This is the screen itself and needs replacing.
May 22, 2010 | Samsung HP-T4254 42 in. Plasma Television
Sony Trinitron 20" TV (KV-2093R) Suddenly Shut Off
2 things that will cause that vertical IC or Yoke! Listen to this one went on service call 2wks ago Customer had a 50 INCH1988 pioneer big screen replaced 3 capacitors resolder poor connections TV is now working like New ?
Jun 23, 2009 | Sony KP-51HW40 51" Rear Projection...
Distorted picture on my 32" Proscan TV...(about 15 years old)
The RCA GE sets have a problem with bad solder connections in the tuner unit which also causes numerous symptoms including poor regulation, no vertical deflection, low audio or dead set.
Pulling in from the sides is either poor regulation or a bad eeprom/solder join issue
Mar 13, 2009 | Proscan PS36123 TV
PROSCAN 42' LCD COLOR TV MODEL 42LA45H
I am sorry Sir, the display panel is bad. If you purchased it new, it should under factory's warranty. Please call Proscan for a warranty repair.
Proscan Customer Service:
1-800-968-9853 (US and Canada)
May 31, 2017 | Proscan 42LA45H 42 in. LCD TV
Proscan PS27123 TV Problem
just to be sure, is it vertical or horizontal? Anyway, if it is vertical, it could point out to the vertical Ic section or some loose contacts along the lines. If it is horizontal, it could be a filter capacitor along the horizontal Circuitry. Mark the high voltage capacitors along the high voltage sections.
regards,
chris
Jul 23, 2008 | Proscan PS27123 TV
Problem with my insignia tube tv!!!!
if that look like horizontal line shuld be vertical problem. check vertical ic around it of resistor& capacitor. good luck!
May 26, 2008 | Insignia NS- 27" TV27 TV
Hitachi 51GWX Scrambled Picture
STK392-560 STKS convergence CHIPs Replace both of them.
Feb 24, 2008 | Hitachi 51GWX20B 51" Rear Projection...
Sharp 27G-S60 no vertical picture
your problem is due to vertical section failure.
 as you say it was intermittent for a while, but now is permanent
please check the followings as given
  • remember you should keep brightness as low as possible to avoid crt burn.
  • there might be loose contact in print or connector loose for deflection coil.
  • check supply to vertical output section
  • check components in vertical output section like electrolytic capacitors & low value resistirs.
  • check verical outout ic .
  • hope this will help
  • good luck.
Oct 13, 2007 | Sharp 27G-S60 TV
Proscan PS36500 36" TV Logo
199 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
